IBM PS2 Model 30 286 Guide to Operations
Revision as of 21:36, 30 September 2026 by Josh (talk | contribs) (Section list from the scan with page numbers (Section 2 options and Section 4 testing were missing or misplaced); J13 reset; remove uncited 'commonest way to destroy a supply')
The IBM Personal System/2 Model 30 286 Guide to Operations is the 69-page owner's guide shipped with the PS/2 Model 30 286 (8530-E models), First Edition, September 1988. It covers setting up, expanding, operating and testing the machine at user level.
Contents
The scan has no contents page; the sections, with printed page numbers, are:
  • Before You Begin (p. iv): where to find the model, serial and cover-lock key numbers. A cover lock is fitted only to systems with a fixed disk drive.
  • Section 1, Getting Started (p. 1-1): unpacking, removing the diskette shipping inserts, connecting the keyboard, setting the voltage selector switch (p. 1-3), connecting the display and power cords; using the Starter Diskette to view the learning program, set date and time, back up the diskette and set the configuration (p. 1-7).
  • Section 2, Installing Your Options (p. 2-1): cover removal (p. 2-2), the 512 KB and 2 MB memory expansion kits, the 80287 math coprocessor, adapters (p. 2-11), external options, and cover installation (p. 2-15).
  • Section 3, Operating Your System (p. 3-1): the power-on self-test (up to 90 seconds), passwords (power-on password, network server mode, keyboard password, pp. 3-3 to 3-7), power-on password reset (pp. 3-4 to 3-5), diskettes, and installing IBM Disk Cache (p. 3-11).
  • Section 4, Testing Your System (p. 4-1): running the Starter Diskette tests, and troubleshooting charts from p. 4-4 that give the user action for each error message (161, 162, 163, 164, 199 and others), plus display and external option tests.
  • Appendix, Hardware Reference (p. A-1): locations of the hardware features and IBM power cord specifications; glossary and index.
It is a user guide. There are no FRU numbers, service removal procedures, symptom-to-FRU index, supply voltages, schematics or component values. The service manual for the same machine is the IBM PS2 Model 30 286 Hardware Maintenance Reference.
What it settles
The voltage selector switch, where fitted: for a 90-137 V supply slide it to the right (115 V), which is the setting for the United States and Canada (100-125 V); for a 180-265 V supply slide it to the left (230 V) (p. 1-3).
A forgotten power-on password is reset with jumper J13 on the system board. If it covers pins 1 and 2 move it to pins 2 and 3, or the other way round, and leave it in the new position until the next reset; then set a new password (pp. 3-4 to 3-5).
Pages that cite this document
Download: IBM PS2 Model 30 286 Guide to Operations.pdf
