Atari 1050 Documentation
Revision as of 21:45, 1 October 2026 by Josh (talk | contribs) (New page: describe the hosted service manual, Sams service data and owner's guide, with contents and gaps)
The Atari 1050 documentation below comprises Atari's field service manual for the Atari 1050 disk drive, Howard W. Sams & Co.'s Computerfacts service data for it, and Atari's owner's guide.
Atari 1050 Disk Drive Field Service Manual
The 1050 Disk Drive Field Service Manual is Atari's service manual for the drive, part number FD100330. A separate scan of the Rev. 03 edition, dated October 1985, carries that part number on its cover.[1] The copy hosted here is a 77-page rebuilt scan without the cover, with the original schematic sheets and cleaner redrawn copies of them; its contents and page numbers match the Rev. 03 scan, which lacks many pages of sections 1 to 3.[2]
Contents
Section Title Pages
Introduction v
1 Theory of operation: front and back panels, mechanical theory (case, drive mechanism, head carriage, drive and stepper motors), power supply and power-up logic, electronics theory (clock, 6507, ROM, RAM, 6532, 2793, write/erase, write protect and read logic, heads), serial bus line assignments, electrical specification and protocol 1-1 to 1-21
2 Test equipment and diagnostic tests: equipment, hook-up, mechanical checks, power-up test, diagnostic diskette, speed calibration, alignment tests, burn-in, error printout, track zero sensor calibration 2-1 to 2-11
3 Disassembly and assembly, including plug polarity (figure 3-1) 3-1 to 3-2
4 Symptom checklist, then signal waveforms for the motor, tachometer, stepper, diskette enable, track 00, read, write, erase, clock, write protect, power supply and data lines 4-1 to 4-17
5 Drawings and parts list: schematics (Tandon, four sheets), silkscreen, 1050 parts list (Tandon) 5-1 to 5-11
6 Appendix 6A, 1050 specifications 6A-1 to 6A-3
7 Service bulletins: Tech Tip 21, 30 September 1983 (ROM revision E or F)
  • Capacitor values in the parts list. The list gives mechanical assemblies, semiconductors, inductors, the trimmers and the variable capacitor; capacitor values and ratings appear only on the four schematic sheets.
  • Parts for the World Storage Technology mechanism. The parts list and schematics are for the Tandon TM50-1 version.
  • A head azimuth adjustment. Atari replaces the mechanism if azimuth is out of specification.
  • Any lubrication procedure.
Pages that cite this manual
Download: Atari 1050 Disk Drive Field Service Manual.pdf
Sams Computerfacts CD13, Atari Model 1050 Disk Drive
Computerfacts CD13 is Howard W. Sams & Co.'s technical service data for the 1050, dated February 1987, 22 pages including a fold-out schematic and an enclosed set of preliminary service checks.[3]
Contents
From the index (printed page numbers): schematic, 2; main board photographs, 3, 4, 13 and 14; grid location guide for the main board, 5; test equipment and troubleshooting, 6; parts list, 7 to 9; logic chart, 10 and 11; line definitions and schematic notes, 11; chassis top view, 12; IC pinouts and terminal guides, 16 and 17; general operating instructions, 17. The enclosed preliminary service checks (pages i to viii) cover disassembly, a numbered list of service checks keyed to photographs, and general preventive maintenance.[3]
  • Voltage ratings for most electrolytic capacitors. The parts list rates only C2 (0.68 µF 35 V) and C41 (4.7 µF 16 V); the schematic gives values only.
  • Atari part numbers. Sams lists replacement parts by description and gives no Atari numbers.
Pages that cite this document
Download: Sams Computerfacts CD13 Atari 1050 Disk Drive.pdf
Atari 1050 Disk Drive Owner's Guide
The Atari 1050 Disk Drive Owner's Guide (Atari, 1982) is the 8-page guide packed with the drive. It covers connecting the drive and its adaptor, daisy-chaining up to four drives, the drive select switches, the DOS manuals supplied with the drive and the care of diskettes. It contains no specifications and no service information.
Pages that cite this guide
Download: Atari 1050 Disk Drive Owner's Guide.pdf
  1. ↑ Internet Archive item atari1050diskdrivefieldservicemanualrev.031985atari, "Atari 1050 Disk Drive Field Service Manual, Rev. 03 (1985)", 40-page scan with cover.
  2. ↑ Internet Archive item 1050FSMRebuiltAKH, "1050 Field Service Manual", described there as complete and with cleaner schematics.
  3. ↑ 3.0 3.1 Howard W. Sams & Co., Computerfacts CD13, Atari Model 1050 Disk Drive (1987), index page.
