Macintosh Color Classic Capacitor Replacement Guide
Replacing electrolytic capacitors (recapping) in your Macintosh Color Classic is essential for restoring power stability, ensuring clean video output, and preventing long-term damage due to leakage. The Color Classic's unique all-in-one design with color CRT requires special attention to both analog and logic board capacitors that have likely degraded after 30+ years of operation.[1]
Capacitor Inspection
  • Bulging Tops – Swollen or domed caps indicate internal gas buildup and imminent failure.
  • Electrolyte Leakage – Brown/white crust or residue near leads shows active leakage.
  • Corroded Pads or Traces – PCB staining or green corrosion suggests acid damage.
  • Discoloration – Heat damage or age-related darkening of the capacitor body.
If any symptoms are present, immediate replacement is advised to prevent further board damage.
Macintosh Color Classic Capacitor List
The Color Classic contains two primary boards requiring capacitor replacement: the analog board (power supply and CRT drive) and the logic board (digital circuitry). Both boards are critical for proper operation.
Analog Board Capacitors
The Color Classic analog board provides power regulation and CRT drive circuits. The most critical failure-prone capacitor is the 3300µF 16V capacitor located near the center of the board, which commonly causes display issues when it fails.[2]
⚠️ Important Note: Complete analog board capacitor specifications vary by board revision. The critical capacitors most prone to failure include:
  • 3300µF 16V - Main filter capacitor (center of board) - causes display problems when failed
  • Various electrolytic capacitors in power regulation circuits
  • **Audio circuit capacitors** around the sound DAC chip (343S0129)
For complete analog board specifications, consult:
  • Console5 capacitor kits for part numbers 630-0349 / 630-0355[3]
  • Recap-a-Mac visual guide at recapamac.com.au
  • Community forums at 68kMLA.org for board-specific information[4]
Macintosh Color Classic Analog Board Recap
Known Critical Analog Board Capacitors
Capacitance Voltage Qty Notes
3300 µF 16 V 1 Main filter - most failure-prone
Various Various ~20+ Complete kit recommended
Note: High voltage capacitors (250V) require special handling and quality replacements.
Logic Board Capacitors
The Color Classic logic board contains the 68030 processor, RAM, and support circuitry. All capacitors are surface-mount tantalum types.[5]
Macintosh Colour Clasic Recap
Macintosh Color Classic Logic Board Capacitor Specifications
Capacitance Voltage Qty Recommended Part Number
47 µF 16 V 6 KEMET T491D476K016AT
100 µF 6.3 V 2 KEMET T491D107K006AT
10 µF 16 V 1 KEMET T491C106K016AT
Note: Some early revisions may have fewer capacitors. Always verify against your specific board.
PRAM Battery Considerations
The Color Classic uses a 3.6V lithium PRAM battery that can leak and damage nearby capacitors and traces. During recap:[6]
  • Remove the old battery regardless of condition
  • Clean any corrosion with white vinegar followed by isopropyl alcohol
  • Inspect nearby capacitors for acid damage
  • Install a new high-quality battery or battery holder for easy replacement
Required Tools
  • Temperature-controlled soldering iron (15-25W with fine tip)
  • Desoldering braid or vacuum pump
  • Leaded solder (60/40 or 63/37), 0.5-0.8mm diameter
  • 99% isopropyl alcohol
  • ESD-safe brush or cotton swabs
  • Digital multimeter
  • Magnifying glass or loupe
  • Anti-static wrist strap
  • Safety goggles
Step-by-Step Process
1. Preparation
  • Discharge the CRT following proper CRT Discharge Procedure[7]
  • Document connections with photos before disconnecting cables
  • Remove the logic board carefully, noting cable routing
  • Remove the analog board with extreme caution due to high voltage components
2. Logic Board Recap
Start with the logic board as it's safer and builds confidence:
  • Identify all capacitors using the specification table
  • Heat the solder joints and remove old capacitors with desoldering braid
  • Clean the PCB thoroughly with 99% IPA to remove flux residue
  • Install new capacitors observing correct polarity (negative stripe orientation)
  • Solder carefully ensuring clean, shiny joints without cold solder bridges
  • Trim excess leads and clean with IPA again
3. Analog Board Recap
⚠️ WARNING: Analog board contains high voltage components. Ensure CRT is discharged.[8]
  • Work systematically from low voltage to high voltage sections
  • Pay special attention to polarity - incorrect installation can cause damage
  • Use high-quality capacitors especially for 250V rated components
  • Check for proper lead spacing before soldering
  • Verify no solder bridges between adjacent components
4. Quality Control
  • Visual inspection of all solder joints under magnification
  • Continuity testing to ensure no shorts between power rails
  • Resistance testing across capacitor leads (should show initial low resistance, then increase)
  • Clean all flux residue with IPA for professional appearance
Voltage Verification
After reassembly, measure voltages at test points before full power-on:
Test Points
  • Floppy drive connector - easily accessible for initial testing
  • Logic board power input - verify proper supply voltages
  • Video DAC supply - ensure stable color generation
Expected Voltages
  • +5V rail: 4.90V - 5.15V (±3%)
  • +12V rail: 11.9V - 12.7V (±5%)
  • -12V rail: -10.8V - -13.2V (±10%)
  • +3.3V rail: 3.20V - 3.45V (±5%)
If voltages are outside tolerance, check:
  • Analog board voltage adjustment (trimmer resistor)
  • Capacitor polarity and proper installation
  • Solder joint quality and potential shorts
Common Issues and Solutions
Power Supply Problems
  • No power - Check main filter capacitors C1, C2, C8
  • Voltage instability - Replace regulation circuit capacitors C3, C9, C21
  • Ripple on power rails - Check all filter capacitors in power section
Video Issues
  • Color bleeding or poor convergence - Check video DAC supply capacitors
  • Geometry problems - Replace deflection circuit capacitors C15, C16, C17
  • Dim or dark display - Check CRT drive circuit capacitors
Audio Problems
  • Distorted sound - Replace audio circuit capacitors around the sound DAC chip (343S0129)[9]
  • No audio output - Check power supply to audio section
Choose high-quality capacitors from reputable manufacturers:[10]
  • Nichicon - Excellent temperature stability and long life
  • Panasonic - High reliability and consistent performance
  • Rubycon - Good value with reliable operation
  • Elna - Suitable for audio applications
  • Avoid - Generic or no-name brands that may fail prematurely
  • Temperature rating - Minimum 85°C, prefer 105°C for longevity
  • Voltage rating - Use exact or higher voltage ratings
  • Capacitance tolerance - ±20% is acceptable for most applications
  • ESR rating - Lower ESR preferred for switching applications
Post-Recap Testing
After successful recap and reassembly:
  • Initial power-on test - Check for proper boot sequence
  • Extended burn-in - Run for several hours to verify stability
  • Thermal testing - Monitor for excessive heat buildup
  • Functionality test - Verify all ports and features work correctly
Maintenance Tips
  • Regular inspection - Check capacitors annually for signs of aging
  • Environmental control - Avoid extreme temperatures and humidity
  • Periodic operation - Power on monthly to maintain capacitor health
  • Clean storage - Store in dry, temperature-controlled environment
Troubleshooting Recap Issues
If problems persist after recap:
  • Double-check polarity - Reversed capacitors can cause damage
  • Verify capacitor values - Wrong values can cause instability
  • Check solder joints - Cold joints cause intermittent problems
  • Test individual capacitors - Some may have failed during installation
Safety Reminders
  • Always discharge the CRT before working on analog board[11]
  • Use proper ESD protection when handling sensitive components
  • Work in well-ventilated area when soldering
  • Keep fire extinguisher nearby when working with electronics
  • Never work alone on high-voltage repairs
  1. Macintosh Color Classic, Caps Wiki—link(accessed 2025-01-07)
  2. Macintosh Colo(u)r Classic Analog Board, Recap-a-Mac—link(accessed 2025-01-07)
  3. Macintosh Color Classic / Macintosh TV Analog PCB Cap Kit, Console5—link(accessed 2025-01-07)
  4. Cap list for Macintosh Color Classic and Macintosh Classic II?, 68kMLA—link(accessed 2025-01-07)
  5. Macintosh Colo(u)r Classic, Recap-a-Mac—link(accessed 2025-01-07)
  6. Macintosh Color Classic, Caps Wiki—link(accessed 2025-01-07)
  7. CRT Discharge Procedure, RetroTechCollection—link(accessed 2025-01-07)
  8. Macintosh Color Classic repair adventure, 68kMLA—link(accessed 2025-01-07)
  9. Macintosh Color Classic Sound Issue, 68kMLA—link(accessed 2025-01-07)
  10. Replacing aging capacitors on old Macintosh Analogue boards, VOGONS—link(accessed 2025-01-07)
  11. CRT Discharge Procedure, RetroTechCollection—link(accessed 2025-01-07)
