Power Macintosh 6100
Revision as of 13:41, 10 February 2026 by Josh (talk | contribs) (Converted from redirect to full article with specifications)
The Power Macintosh 6100 is a personal computer introduced by Apple Computer on March 14, 1994.[1] It was one of the first three Power Macintosh models released, alongside the Power Macintosh 7100 and Power Macintosh 8100, marking Apple's transition from Motorola 68k processors to the PowerPC architecture. Based on the "PDM" (Piltdown Man) architecture, the 6100 used the same low-profile desktop case as the Macintosh Centris 610 and Macintosh Quadra 610.
TypePersonal Computer
ReleasedMarch 14, 1994
DiscontinuedOctober 14, 1995
Intro priceUS$1,750–$2,350
CPUPowerPC 601 @ 60–66 MHz
Memory8 MB RAM (expandable to 136 MB)
Storage160–500 MB SCSI hard drive, 1.44 MB floppy, optional 2X CD-ROM
Display640×480 @ 16-bit (max without video card)
SoundStereo 16-bit audio
Dimensions3.4" H × 16.3" W × 15.6" D (8.6 × 41.4 × 39.6 cm)
Weight14.0 lbs (6.4 kg)
OS / FirmwareSystem 7.1.2 – Mac OS 9.1
PredecessorMacintosh Quadra 610
SuccessorPower Macintosh 6200
CodenamePDM (Piltdown Man)
Model no.M1596
Model Variants
The Power Macintosh 6100 was available in two processor configurations with various sub-models:
Model Release Processor Bus L2 Cache Standard RAM Hard Drive CD-ROM Price (USD)
6100/60 March 1994 60 MHz 30 MHz Optional 256k 8 MB 160 MB Optional 2X $1,820
6100/60 March 1994 60 MHz 30 MHz Optional 256k 8 MB 160 MB 2X $2,000
6100/60 March 1994 60 MHz 30 MHz Optional 256k 16 MB 250 MB 2X $2,350
6100/66 January 1995 66 MHz 33 MHz 256k 8 MB 350 MB Optional 2X $1,750
6100/66 January 1995 66 MHz 33 MHz 256k 8 MB 350 MB 2X $1,950
DOS Compatible Version
A PC-compatible version was also available, featuring a 66 MHz Intel 486DX2 processor on a NuBus card. This allowed users to run DOS and Windows alongside Mac OS. The PC card could be configured with up to 32 MB of dedicated RAM.
  • Performa 6110CD, 6112CD, 6115CD, 6116CD, 6117CD, 6118CD: Consumer versions with bundled software
  • Workgroup Server 6150: Server version with additional networking features
The Power Macintosh 6100 uses the PowerPC 601 processor, Apple's first PowerPC chip developed in collaboration with IBM and Motorola (the "AIM Alliance").[2]
Processor Specifications
  • Processor: PowerPC 601
  • Clock Speed: 60 MHz or 66 MHz
  • Architecture: 32-bit processor with 64-bit data path
  • FPU: Integrated
  • System Bus: 30 MHz (6100/60) or 33 MHz (6100/66)
Cache Configuration
  • L1 Cache: 32 KB (on-die)
  • L2 Cache: 256 KB (optional on 6100/60, standard on 6100/66)
ROM
  • ROM Size: 4 MB
  • ROM Type: Macintosh ROM
Memory and Storage
RAM Configuration
  • RAM Type: 72-pin SIMM (80 ns minimum)
  • RAM Slots: 2 (SIMMs must be installed in matching pairs)
  • Onboard RAM: 8 MB
  • Standard RAM: 8–16 MB (varies by configuration)
  • Maximum RAM: 72 MB (official), 136 MB (with 2× 64 MB SIMMs)
Storage Systems
  • Hard Drive: 160–500 MB SCSI (varies by configuration)
  • Hard Drive Interface: SCSI
  • Floppy Drive: 1.44 MB 3.5" (manual eject)
  • CD-ROM: 2X (optional on some configurations)
Display and Graphics
The Power Macintosh 6100 uses integrated video that shares 640 KB of system RAM.
Supported Resolutions
Resolution Color Depth
512×384 16-bit (thousands)
640×480 16-bit (thousands)
832×624 8-bit (256 colors)
Video RAM cannot be upgraded. A second display can be supported with the addition of a NuBus video card (requires PDS-to-NuBus adapter).
Audio Capabilities
The Power Macintosh 6100 includes stereo 16-bit audio with standard input and output ports.
Input/Output and Expansion
Port Configuration
  • Serial Ports: 2× Geoport (printer and modem)
  • ADB Ports: 1× Apple Desktop Bus
  • SCSI: External 25-pin HDI-30 connector
  • Video Out: DB-15 monitor port
  • Audio: Stereo audio in/out
  • Ethernet: AAUI-15
Expansion
  • PDS Slot: 1× 601 Processor Direct Slot
  • NuBus: Available with PDS-to-NuBus adapter card (M1402LL/A)
  • Drive Bay: 1× front-facing 5.25" bay (if CD-ROM not installed)
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and general upkeep, refer to the dedicated Power Macintosh 6100 General Maintenance page.
A comprehensive troubleshooting guide addressing common issues such as power problems, startup failures, and video issues is available on the Power Macintosh 6100 Troubleshooting page.
Detailed capacitor replacement guidelines can be found on the Power Macintosh 6100 Capacitor Replacement Guide page.
Full technical specifications are available on the Power Macintosh 6100 Specifications page.
Sub-system Specification (Power Macintosh 6100, 1994–1995)
CPU PowerPC 601 @ 60–66 MHz
Bus width 32-bit processor, 64-bit data path
System Bus 30–33 MHz
ROM 4 MB
RAM 8–16 MB standard (136 MB max)
Video 640 KB shared RAM, 640×480 @ 16-bit max
Sound Stereo 16-bit
Storage 160–500 MB SCSI, optional 2X CD-ROM
Ports Serial ×2, ADB, SCSI, Ethernet (AAUI-15)
Expansion 1× PDS (NuBus via adapter)
  1. ↑ Power Macintosh 6100/60 Specs, EveryMac.com—link(accessed 2026-02-10)
  2. ↑ Power Macintosh 6100/66 Specs, EveryMac.com—link(accessed 2026-02-10)
