Acorn Atom
Acorn Atom
Acorn Atom
TypeHome Computer
ReleasedMarch 1980
Discontinued1983
Intro priceKit: £120, Assembled: £170 (1980)
CPUMOS Technology 6502 @ 1 MHz
Memory2 KB RAM (expandable to 12 KB), 8 KB ROM (expandable to 12 KB)
StorageCassette tape interface (CUTS, 300 baud), optional floppy disk
Display256×192 monochrome graphics, 32×16 text mode (MC6847)
Sound1 channel, internal speaker
Dimensions381 mm × 241 mm × 64 mm
OS / FirmwareAcorn MOS with Atom BASIC
PredecessorAcorn System 3
SuccessorBBC Micro Model A/B
Model no.PCB 202,000
The Acorn Atom was a home computer made by Acorn Computers Ltd from 1980 to 1983, when it was replaced by the Acorn Electron and the BBC Micro as Acorn's low-cost option.[1] It was a cut-down Acorn System 3 built into a case with an integral keyboard and a cassette interface, sold in kit or assembled form. The Atom used the MOS Technology 6502 and was designed around an 8 KB ROM holding the operating system and Acorn's own Atom BASIC, written by Sophie Wilson.
The minimum machine had 2 KB of RAM and 8 KB of ROM; the maximum specification had 12 KB of each, plus an optional floating-point extension ROM. The case was designed by industrial designer Allen Boothroyd of Cambridge Product Design.[1]
Architecture
The Atom used a single double-sided PCB (part 202,000) with the 6502 running at 1 MHz and memory-mapped I/O. The system ROM held the Machine Operating System and Atom BASIC; the BASIC interpreter included an in-line 6502 assembler, which was unusual for the period.[1]
Memory map
Acorn Atom memory map
Address Contents
$0000 Block Zero RAM (1 KB: zero page, 6502 stack, OS and BASIC variables)
$0400 Text / VDG screen RAM (low)
$0800 VDG / CRT-controller area
$0A00 Optional floppy-disc controller (FDC)
$1000 Peripheral / extension space
$2000 Catalogue buffer
$2200 Sequential file buffers
$2800 Floating-point variables (internal RAM, up to 5 KB)
$2900 Extension text-space RAM
$3C00 Off-board extension RAM
$8000 Video and BASIC RAM (mode-dependent, up to 6 KB)
$A000 Optional utility ROM
$B000 INS8255 PPI I/O device
$B800 Optional 6522 VIA (printer interface)
$C000 Atom BASIC interpreter ROM (4 KB)
$D000 Optional extension ROM
$E000 Optional DOS / floating-point ROM
$F000 MOS and assembler ROM (4 KB)
Source: Acorn Atom memory map.[1]
Main board components
The IC designators below are from the Acorn Atom Technical Manual parts list.[2]
Component Device Designator Function
CPU MOS 6502 @ 1 MHz IC22 Central processor
Video Motorola MC6847 VDG IC31 256×192 graphics / 32×16 text
Peripheral interface INS8255 PPI IC25 Keyboard, cassette and loudspeaker I/O
Keyboard row driver 7445 BCD-to-decimal decoder IC26 Drives the keyboard matrix rows
VIA (optional) MOS 6522 (B800) Printer (Centronics) interface — fitted only on expanded machines
RAM 2114 static RAM (1K×4) IC42, IC43, IC51, IC52 (+ expansion) 2 KB base, expandable to 12 KB
ROM MM52164 mask ROM (base) IC20 8 KB system ROM (MOS + BASIC)
Clocks 4.00 MHz + 3.58 MHz crystals X2, X1 CPU clock (÷ to 1 MHz) and MC6847 video timing
Cassette amp LM358 op-amp IC46 CUTS read/write circuit
Regulators 2× LM340T-5 (7805) IC53, IC54 +5 V regulation, one per board half
Video system
The MC6847 Video Display Generator provided text (32×16) and graphics up to 256×192 monochrome, across nine modes from 64×64 in four colours to 256×192 monochrome. The MC6847 is a 60 Hz NTSC device, so on European 50 Hz sets the standard machine produced a monochrome picture; an Acorn 50 Hz PAL colour card (Acorn drawing 102,006-C) was available to add colour.[1] Output was via a UHF modulator (channel 36); a composite-video output was available by modification.
Keyboard, cassette and sound
The keyboard, cassette interface and loudspeaker are handled by the INS8255 PPI (IC25), with the 7445 (IC26) driving the keyboard-matrix rows; the optional 6522 VIA is used only for the printer interface on expanded machines.[2] The full-travel QWERTY keyboard includes CTRL, SHIFT, REPT (repeat) and BREAK keys, with software debouncing in the MOS ROM.
The cassette interface uses the CUTS variant of the Kansas City standard at 300 baud only, built around the LM358 op-amp (IC46) and transistors Q1/Q2 (BC107). There is no internal cassette deck or motor relay. Commercial BBC Micro tapes (1200 baud) cannot be loaded on the Atom.[1]
The Atom takes 8 V DC (unregulated) on a 2.1 mm jack (SK3) and regulates it on the board to +5 V using two LM340T-5 (7805-type) regulators, IC53 and IC54, each feeding one half of the logic, with a heatsink fitted between them. There is no −5 V rail and no AC inside the machine.[2] The Acorn adaptor is rated 8 V at about 1.5–1.8 A, which is marginal: a fully expanded Atom can draw up to 3 A, and the two regulators run hot.[1] The board can instead be powered from a 5 V regulated supply by fitting links LK6 and LK7, which join the two power sections and bypass the regulators.[2]
Input/output and expansion
Standard ports: a 7-pin DIN cassette socket (SK2), the UHF output (SK1), and the 8 V DC jack (SK3). The rear 64-way edge connector carries the full 6502 bus for Acorn Eurocard expansion. Expansion options fitted into the on-board sockets and via the bus included additional lower-text RAM (in 1 KB steps to 5 KB), video graphics RAM (to 6 KB), the 4 KB floating-point ROM, a 4 KB utility ROM, the 6522 VIA and Centronics printer port, the Acorn Disc Pack, an Econet interface, the PAL colour card and a speech board.[2]
Board revisions
The Atom main PCB carries the part number 202,000 on the silkscreen with an issue number. The Technical Manual documents Issue 2 (October 1980); production boards are commonly seen up to Issue 4.[3]
Known hardware issues
  • The two LM7805 regulators (IC53, IC54) run hot; on a fully expanded machine the supply is marginal and thermal shutdown causes intermittent resets.[1]
  • 2114 static RAM is a common failure part, producing corrupted text/graphics or crashes.
  • The rear edge-connector fingers are exposed and oxidise, causing expansion-bus faults.
  • Socketed ICs (ROM, RAM, MC6847, 8255) develop intermittent contacts and benefit from reseating.
For diagnosis and repair, see the maintenance, troubleshooting and capacitor pages below.
  1. 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 "Acorn Atom", Wikipedia. Source for the 1980–1983 production span, pricing, the nine MC6847 video modes (64×64 4-colour up to 256×192 monochrome), the 50 Hz PAL colour-card requirement, the 300 baud CUTS cassette interface, the dual on-board LM7805 regulators, and the memory map.
  2. 2.0 2.1 2.2 2.3 2.4 Acorn Atom Technical Manual (Issue 2, October 1980), Acorn Computers — hosted on this wiki. Source for the IC complement (IC22 6502, IC31 6847, IC25 INS8255, IC26 7445, IC20 MM52164 ROM, IC42/43/51/52 2114 RAM, IC53/IC54 LM340T-5 regulators), the crystals (X1 3.58 MHz, X2 4.00 MHz), the capacitor list, and the 8 V supply with the LK6/LK7 5 V conversion.
  3. Whytehead, Chris. "Acorn Atom", Chris's Acorns / The Centre for Computing History. Documents the 202,000 Issue 4 board, the base IC complement, and the recommendation to use a regulated 5 V supply for a fully expanded machine.
