Macintosh SE/30 Memory Upgrade Guide
The Macintosh SE/30, introduced in 1989, was the most powerful compact Mac of its era. It features an expandable RAM up to 128 MB with the correct SIMMs. Originally, the SE/30 shipped with 1 MB of RAM, but it can be upgraded significantly for better multitasking and performance.
Memory Specifications
The Macintosh SE/30 features 8 30-pin SIMM sockets, organized into two banks of four. Memory must be installed correctly for proper functionality:
  • Bank A (Front 4 slots) – Must always be populated first.
  • Bank B (Rear 4 slots) – Can be left empty unless installing more than 4 MB of RAM.
The SE/30 supports memory interleaving, meaning matched SIMMs provide better performance.
Macintosh SE/30 RAM Configurations
Total RAM Bank A Configuration Bank B Configuration Individual SIMM Capacity
1 MB (stock) 4 × 256 KB Empty 256 KB
2 MB 4 × 256 KB 4 × 256 KB 256 KB
4 MB 4 × 1 MB Empty 1 MB
5 MB 4 × 1 MB 4 × 256 KB Mixed (1 MB & 256 KB)
8 MB 4 × 1 MB 4 × 1 MB 1 MB
16 MB (May not work) 4 × 4 MB Empty 4 MB
17 MB 4 × 256 KB 4 × 4 MB Mixed (256 KB & 4 MB)
20 MB 4 × 4 MB 4 × 1 MB Mixed (4 MB & 1 MB)
32 MB 4 × 4 MB 4 × 4 MB 4 MB
64 MB 4 × 16 MB Empty 16 MB
128 MB (Maximum) 4 × 16 MB 4 × 16 MB 16 MB
Important Notes:
  • The SE/30 reserves 1 MB of RAM for video memory, meaning the 17 MB configuration (256 KB in Bank A, 4 MB in Bank B) is recommended for best performance.
  • If using 16 MB SIMMs, they must be non-parity and low-profile to fit properly.
  • Apple never officially documented configurations beyond 32 MB, but 64 MB and 128 MB work when using non-parity 16 MB SIMMs.
Required Tools
To upgrade the Macintosh SE/30 memory, you will need:
  • Torx T15 screwdriver (for case removal)
  • Plastic spudger or pry tool (to carefully separate the case)
  • Anti-static wrist strap (to prevent electrostatic discharge)
  • Compatible 30-pin SIMMs (matching capacity and speed)
Memory Upgrade Procedure
Step 1: Prepare the Macintosh SE/30 Ensure the Macintosh SE/30 is completely powered off and unplugged. Work on a grounded surface and wear an anti-static wrist strap to protect components from static discharge.
Step 2: Remove the Case Use a Torx T15 screwdriver to remove the four screws securing the rear case. Carefully separate the two halves using a plastic spudger. Be cautious of the CRT, as it retains high voltage even when unplugged.
Step 3: Locate the SIMM Slots The 8 memory slots are on the logic board, organized into two banks:
  • Bank A – The four front slots (closest to the edge of the board).
  • Bank B – The four rear slots (closest to the rear ports).
Step 4: Remove Existing SIMMs If replacing existing memory, gently (they easily snap) push apart the retention clips on each side of the SIMM slot and remove the modules.
Step 5: Install New SIMMs Align the new SIMMs with the slots, ensuring the notch matches the keying of the slot. Firmly push down until the SIMM snaps into place.
Installation Rules:
  • If upgrading to 4 MB, remove all 256 KB SIMMs from Bank A and install 4 × 1 MB SIMMs.
  • If upgrading to 5 MB, install 4 × 1 MB SIMMs in Bank A and move the 256 KB SIMMs to Bank B.
  • If upgrading to 17 MB, install 4 × 256 KB SIMMs in Bank A and 4 × 4 MB SIMMs in Bank B to optimize video memory allocation.
  • If upgrading to 128 MB, install 8 × 16 MB SIMMs (non-parity, low-profile).
Step 6: Reassemble the Macintosh SE/30 Once the memory is installed, reassemble the case and secure it with the Torx screws.
Step 7: Enable 32-bit Addressing (For RAM Above 8 MB) If you install more than 8 MB of RAM, it will be marked as allocated to the system unless Mode32 is installed.
To enable full memory access:
  1. Install Mode32.
  2. Open the Memory Control Panel.
  3. Enable 32-bit addressing.
Common Issues and Troubleshooting
Issue Possible Cause Solution
Macintosh SE/30 beeps on startup Incompatible or faulty SIMMs Ensure SIMMs are 30-pin, 120 ns or faster, properly seated, and non-parity.
Memory not recognized correctly Mismatched SIMM capacities Install matched pairs and avoid mixing different memory sizes.
System crashes or instability Faulty or damaged SIMMs Replace with known-good, compatible memory modules.
SE/30 does not boot with 16 MB SIMMs SIMMs have parity Use non-parity SIMMs for 16 MB configurations.
RAM over 8 MB is "allocated to system" 32-bit addressing not enabled Install Mode32 and enable 32-bit addressing in the control panel.
Additional Resources
