Sega Saturn (Model 1) Capacitor Replacement Guide
The component values and measurements on this page have not been verified against a service manual or schematic. This page is part of a set flagged during a wiki-wide audit. Spot checks found incorrect capacitance values and under-specified voltage ratings on some pages in this set. Do not order parts based on this page alone â check the values against your board's silkscreen and against a schematic or service manual before buying or fitting anything. |
Replacing the electrolytic capacitors in your Sega Saturn Model 1 is a vital preventative maintenance step to ensure stable operation, crisp video and audio output, and to prevent catastrophic board damage from capacitor leakage. As Saturn consoles age, original capacitors can dry out or leak, causing random resets, graphical artefacts, audio distortion, or even permanent PCB corrosion. A full recap restores reliability and preserves your Saturn for years to come.
[edit | edit source]Before beginning, carefully inspect the mainboard and power supply for these common capacitor issues:
- Leaking electrolyte â Brown, black, or green residue at the base of capacitors, especially near the audio and video sections.
- Bulging or domed tops â The aluminium can appears swollen or convex.
- Corroded pads or traces â Green or darkened areas around capacitor legs.
- Random resets, no video, or distorted sound â Often linked to failed power or audio rail capacitors.
- Fishy or acrid odour â A sign of electrolyte leakage.
If any capacitor shows failure, it is strongly advised to replace all electrolytic capacitors on the board.
Sega Saturn Model 1 Capacitor List
[edit | edit source]The Model 1 Saturn (VA0/VA1 mainboards, typically with round buttons and 20-pin power supply) uses both through-hole and SMD electrolytic capacitors. Always cross-check your board revision and silkscreen markings, as minor value changes exist between regions.
Mainboard Electrolytic Capacitors
[edit | edit source]| Ref. Designator | Capacitance | Voltage | Type | Location / Function |
| C1, C2, C3, C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20 | 10 ”F | 16 V | SMD | General decoupling (scattered throughout) |
| C21, C22, C23, C24, C25, C26, C27, C28, C29, C30 | 22 ”F | 16 V | SMD | Video, audio, and logic rails |
| C31, C32, C33, C34 | 47 ”F | 16 V | SMD | Audio output, video encoder |
| C35, C36, C37 | 100 ”F | 10 V | SMD | Audio amplifier, video DAC |
| C38, C39 | 220 ”F | 10 V | SMD | Main 5 V rail decoupling |
| C40 | 470 ”F | 6.3 V | SMD | Main 3.3 V rail decoupling |
| C41 | 1000 ”F | 6.3 V | Through-hole | Bulk 5 V filter (near power input) |
| C42 | 470 ”F | 16 V | Through-hole | Bulk 9 V filter (if fitted) |
| C43 | 2200 ”F | 10 V | Through-hole | Main 5 V filter (sometimes 1000 ”F in later VA1) |
Note: SMD capacitor counts and locations may vary slightly by region and board revision. Always verify with your actual board.
Power Supply Board (Internal PSU)
[edit | edit source]Saturn Model 1 units use an internal linear or switch-mode PSU. Recap the PSU for safety and stability.
| Ref. Designator | Capacitance | Voltage | Type | Notes |
| C101 | 2200 ”F | 16 V | Through-hole | Main 5 V output filter |
| C102 | 1000 ”F | 16 V | Through-hole | 9 V output filter |
| C103 | 470 ”F | 25 V | Through-hole | 12 V output filter |
| C104 | 47 ”F | 50 V | Through-hole | Input smoothing |
| C105 | 10 ”F | 50 V | Through-hole | Standby / logic supply |
If your Saturn has a different PSU (e.g., 220 V vs 110 V), values may differ slightly. Replace with equal or higher voltage ratings.
Recapping Procedure
[edit | edit source]- Unplug and discharge: Disconnect AC power and allow several minutes for capacitors to discharge. For safety, short large PSU capacitors with a 1 kΩ resistor.
- Disassemble: Remove the top cover, optical drive, shielding, and mainboard. Label all cables for reassembly.
- Desolder capacitors: Use solder wick or a pump. SMD capacitors can be removed by gently heating both ends with tweezers or a hot-air station.
- Clean pads: Remove all old electrolyte residue with isopropyl alcohol and a soft brush. Inspect for corroded traces and repair as needed.
- Install new capacitors: Observe correct polarityâlong lead is positive for through-hole; SMDs are marked with a stripe for negative.
- Solder carefully: Ensure solid joints and trim excess leads. Avoid overheating nearby components.
- Inspect work: Check for solder bridges, correct orientation, and clean any flux residue.
- Reassemble and test: Refit all components, double-check connections, and power up while monitoring for abnormal behaviour.
Recommended Tools & Parts
[edit | edit source]- Temperature-controlled soldering iron (fine tip for SMD, chisel for through-hole)
- Desoldering pump and braid
- Hot-air rework station or fine tweezers (for SMD removal)
- Isopropyl alcohol (99%) and antistatic brush
- ESR-capable multimeter (optional but recommended)
- Lead-free or leaded 0.5â0.8 mm solder
- High-quality, 105 °C, low-ESR capacitors (e.g., Nichicon, Panasonic, Rubycon)
- Kapton tape (to protect sensitive areas during SMD work)
- Protective eyewear and ESD precautions
Post-Recap Voltage & Ripple Check
[edit | edit source]After reassembly, verify the main voltage rails with a multimeter or oscilloscope:
| Rail | Nominal Voltage | Acceptable Range | Max Ripple (p-p) |
| +5 V | 5.00 V | 4.85 â 5.15 V | < 50 mV |
| +9 V | 9.00 V | 8.5 â 9.5 V | < 80 mV |
| +3.3 V | 3.30 V | 3.15 â 3.45 V | < 40 mV |
| +12 V (if present) | 12.00 V | 11.5 â 12.6 V | < 100 mV |
Excessive ripple or out-of-range voltages after recapping may indicate PSU faults or incorrect capacitor installation.
Additional Tips
[edit | edit source]- Match SMD footprint: Use SMD electrolytics or solid polymer types for SMD pads. Do not substitute with tantalum unless experienced.
- Polarity matters: Double-check orientation before solderingâincorrect polarity can cause immediate failure.
- Clean thoroughly: Leaked electrolyte is corrosive and conductiveâclean all affected areas.
- Check for trace damage: Saturn boards are prone to pad lift if overheated; use moderate heat and patience.
- Recap the PSU: Even if the mainboard looks fine, a failing PSU can damage new capacitors and other components.
- Test with a known-good game and controller after reassembly to confirm stability.
