Atari 1010 Documentation
The Atari 1010 documentation below comprises Atari's field service manual for the Atari 1010 Program Recorder and the owner's guide packed with it.
Atari 1010 Cassette Recorder Field Service Manual
[edit | edit source]The 1010 Cassette Recorder Field Service Manual is Atari's service manual for the recorder, part number FD100223 Rev. 02, dated September 1983. The hosted scan has 63 pages, including the silkscreens and schematics of both versions.[1] It covers two different units, the 1010S (Sanyo) and the 1010C (Chelco), and tells the reader to identify them by the FCC ID on the base and the order of the PAUSE and STOP/EJ keys.
Contents
[edit | edit source]| Section | Title | Pages |
| Introduction | v | |
| 1 | Theory of operation: 1010S power supply, audio, data and record amplifiers, limiter, envelope detector, output stage; 1010C power supply, circuit data out and motor control | 1-1 to 1-3 |
| 2 | Silkscreens and schematics | 2-1 |
| 3 | Testing and troubleshooting: tools, maintenance and checkout, connecting for test, head alignment check, motor speed check, read/write verify test, 1010S disassembly, head and mechanism replacement, 1010C disassembly, belt, mechanism, head and LED replacement | 3-1 to 3-12 |
| 4 | Diagnostic flowcharts for each version, with head alignment and motor speed adjustment procedures | 4-1 to 4-26 |
| 5 | Symptom checklists, 1010S and 1010C | 5-1 to 5-2 |
| 6 | Parts lists, 1010S and 1010C | 6-1 to 6-2 |
| 7 | Service bulletins (an empty section explaining the bulletin types) | 7-1 |
[edit | edit source]- Belt dimensions. The parts lists give Atari part numbers for the belts; only the 1010C counter belt has a size (65 × 1 × 1).
- Capacitor and resistor values in the parts lists, which cover the mechanism, heads, switches, belts, semiconductors and test tapes.
- Any service bulletins; section 7 only describes the kinds of bulletin.
Pages that cite this manual
[edit | edit source]- Atari 1010: versions, power supply and data circuits
- Atari 1010 Maintenance Guide: cleaning, belts, disassembly, head alignment and speed
- Atari 1010 Troubleshooting: test sequence, symptom checklists and flowcharts
Download: Atari 1010 Cassette Recorder Field Service Manual FD100223 Rev 02.pdf
The Atari 1010 Program Recorder Owner's Guide
[edit | edit source]The Atari 1010 Program Recorder Owner's Guide (Atari, 1982) is the 16-page guide packed with the recorder. It covers connecting the recorder and adaptor, the keys and counter, loading with CLOAD, saving with CSAVE, protecting cassettes by breaking off the tabs, care of cassettes and cleaning the tape path. It contains no specifications or service information.
Pages that cite this guide
[edit | edit source]- Atari 1010: controls and connectors
- Atari 1010 Maintenance Guide: cleaning the heads, capstan and pinch roller
- Atari 1010 Troubleshooting: errors 138 and 143
Download: Atari 1010 Program Recorder Owner's Guide.pdf
[edit | edit source]- ↑ Internet Archive item manualzilla-id-6912711, "Atari 1010 Cassette Recorder Field Service Manual"; PDF title "Atari 1010 Cassette Recorder Field Service Manual with Schematics and Silkscreens".
