Atari 410 Documentation
Atari's documentation for the Atari 410 Program Recorder: the field service manual with two tech tips bound in, the 1981 owner's guide, the 1979 operator's manual and the schematic from the service manual.
410 Program Cassette Recorder Field Service Manual
The Atari 410 Program Cassette Recorder Field Service Manual is Atari, Inc.'s component-level service manual for the recorder, document FD100004, dated May 1982 on the cover. The hosted scan has 34 PDF pages.[1] It describes the Transtek-built version of the revised 410; the parts list is headed "Final Assy (Transtek)".[1]
Contents
FD100004 contents (page numbers are the manual's own; PDF pages in brackets)
Section Pages Contents
Introduction v (6) Purpose of the manual; clean the head and check the mechanics and belts before troubleshooting
I, Tools and maintenance 1-1, 1-2 (7, 8) Tool list; maintenance areas: drive roller, belts, head, solder joints, motor
II, Theory of operation 2-1, 2-2 (9, 10) Data-out circuit block diagram with test points; motor control through SIO pin 8, Q101, Q102, S101 and S102
III, Recorder test 3-1, 3-2 (11, 12) CLOAD and CSAVE test with the Atari test tape and a blank tape
IV, Head alignment and motor 4-1 to 4-3 (13 to 15) Head alignment at A101 pin 11; error codes 138, 140 and 143; motor control voltages; slow motor; switch maintenance
V, Test points 5-1, 5-2 (16, 17) Static and running voltages for data out, data in and audio out
VI, Parts list 6-1 (18) Every component on the Transtek board, with Atari part numbers and locators
VII, Schematic 7-1 (19) Figure 7-1, "410 Differences": the full schematic of the Transtek board
Tech tips (20 to 34) Tech Tip 9 (9 February 1983) on pp. 22 to 24; the other pages are copies of the servicer and user sections of Tech Tip 5 (17 November 1982)
  • Disassembly steps, belt sizes or belt part numbers. The mechanism appears only as part of the final assembly.
  • Parts lists or schematics for the Bigston or Chelco versions. Tech Tip 9 gives five component values to check on Chelco units.[1]
  • The mains transformer and the motor as separate parts.
  • The 410 P with its external adaptor.
Tech Tip 9 corrects the head-alignment level in section IV from 50 mV to at least 300 mV.[1]
Pages that cite this document
Download: Atari 410 Program Cassette Recorder Field Service Manual FD100004.pdf
Figure 7-1 of FD100004, rendered from the hosted scan
The Atari 410 Program Recorder Owner's Guide
The Atari 410 Program Recorder Owner's Guide, Atari part number C060088 Rev. 1, copyright 1981, 11 PDF pages, was packed with the revised recorder.[2] It covers connecting the recorder to the computer or to an 810, 820 or 822, the REC, PLAY, REWIND, ADVANCE, STOP/EJ and PAUSE keys and the counter, loading and saving programs, the cure for errors 138 and 143, the write-protect tabs, care of cassettes, and cleaning the heads, capstan and pinch roller. It contains no specifications or service information.
Pages that cite this guide
Download: Atari 410 Program Recorder Owner's Guide.pdf
ATARI 410 Program Recorder operator's manual (1979)
The earlier operator's manual, Atari part number C014810 Rev. 2, copyright 1979, has 7 PDF pages.[3] Its safety paragraph warns that the recorder contains dangerous voltage when plugged into a 115 V outlet, and notes that some machines have a PAUSE key and some have separate STOP and EJECT keys. It explains the 7-second limit on tape leader, with errors 143 (checksum) and 138 (device timeout) when the leader is too long, and covers saving, loading and the Educational System cassettes.
Pages that cite this manual
Download: Atari 410 Program Recorder Operator's Manual.pdf
Other 410 documents
Skematiks sold a traced schematic and component layout of the 410 (7S-AT410-3 and 6S-AT410-3) in 1983. The two sheets and their covering notes are on the Internet Archive (item atari-410-schematic-a-skematiks) and are not hosted here.[4]
  1. ↑ 1.0 1.1 1.2 1.3 Atari, Inc., 410 Program Cassette Recorder Field Service Manual, FD100004, May 1982: cover, contents (p. iii) and the bound-in tech tips. File:Atari 410 Program Cassette Recorder Field Service Manual FD100004.pdf; source Internet Archive item atari410programcassetterecorderfieldservicemanual1982atari.
  2. ↑ Atari, Inc., The Atari 410 Program Recorder Owner's Guide, C060088 Rev. 1, 1981. File:Atari 410 Program Recorder Owner's Guide.pdf; source Internet Archive item Atari_410_Program_Recorder_Owners_Guide_1983_Atari.
  3. ↑ Atari, Inc., ATARI 410 Program Recorder operator's manual, C014810 Rev. 2, 1979. File:Atari 410 Program Recorder Operator's Manual.pdf; source Internet Archive item Atari_410_Program_Recoder_Operators_Manual.
  4. ↑ Skematiks, Atari 410 schematics and notes, November 1983. archive.org/details/atari-410-schematic-a-skematiks.
