IBM PC 5150 Technical Reference (August 1981)
The Technical Reference for the IBM Personal Computer (5150), part of IBM's Personal Computer Hardware Reference Library, is the First Edition of August 1981, IBM part number 6025008. The hosted PDF has 396 pages. It describes the machine as launched: the 16KB-64KB system board, the 63.5 W power supply, the keyboard and the first options, with the BIOS listing and logic diagrams of the system board and of each option in Appendix D.
Contents
[edit | edit source]From the manual's contents list (pp. iii to viii):
- Section 1, Hardware Overview (1-1), with the system block diagram (1-4)
- Section 2, Hardware (2-1): system board (2-3), data flow (2-6), I/O channel (2-8 to 2-12), system board component diagram (2-13), keyboard (2-14), cassette interface (2-19), speaker (2-22), I/O address map (2-23), memory map (2-25), switch settings (2-28 to 2-31), power supply (2-33 to 2-36), Monochrome Display and Parallel Printer Adapter (2-37), IBM Monochrome Display (2-43), Color/Graphics Monitor Adapter (2-45), Parallel Printer Adapter (2-65), IBM 80 CPS Matrix Printer (2-70), 5 1/4" Diskette Drive Adapter (2-89), 5 1/4" Diskette Drive (2-110), 32 KB and 64 KB Memory Expansion Options (2-113), Game Control Adapter (2-117), Asynchronous Communications Adapter (2-123)
- Section 3, ROM and System Usage (3-1): BIOS usage, cassette logic, keyboard encoding, low memory maps
- Appendix A, ROM BIOS listing; Appendix B, assembly instruction set; Appendix C, characters, keystrokes and colour
- Appendix D, Logic Diagrams (D-1): system board (D-2 to D-11), keyboard (D-12), Monochrome Display and Parallel Printer Adapter (D-14), IBM Monochrome Display (D-24), Color/Graphics Monitor Adapter (D-25), 80 CPS Matrix Printer (D-31), Parallel Printer Adapter (D-34), Diskette Drive Adapter (D-35), Diskette Drive (D-39), 32 KB Memory Expansion (D-42), 64 KB Memory Expansion (D-45), Asynchronous Communications Adapter (D-48), Game Control Adapter (D-49)
- Appendix E, unit specifications; glossary, bibliography and index
[edit | edit source]- It is not a service manual. It has no FRU part numbers, removal procedures or problem isolation charts; those are in IBM PC 5150 Hardware Maintenance and Service (August 1981).
- The logic diagrams have no parts list and no placement drawing, so a designator has to be found on the board by hand. There is no circuit diagram of the power supply.
- It covers only the 16KB-64KB system board and lists only the 120 V supply (p. 2-34). The 64KB-256KB board and the 220/240 V supply are in the revised edition of April 1984, described at IBM PC 5150 Technical Reference.
What it settles
[edit | edit source]- The filter capacitors on the 16KB-64KB system board (p. D-11, "System Board (I/O Channel)"): five on +12 V and one on −12 V, designated C6; five on −5 V and six on +5 V, designated C7. A note on the sheet gives all its capacitors as 8.2 µF tantalum.
- The power supply: 63.5 W continuous, a switching regulator (pp. 1-1, 2-33); outputs +5 V at 2.3 to 7.0 A, −5 V at 0 to 0.3 A, +12 V at 0 to 2.0 A and −12 V at 0 to 0.25 A, with the regulation tolerances (p. 2-34); a 2 A input fuse, and Power Good with a turn-on delay of 100 ms, no greater than 500 ms, and its sense levels (p. 2-36).
Pages that cite this document
[edit | edit source]- IBM PC (5150) Capacitor Replacement Guide: the system board filter capacitors on the 16KB-64KB board
Download: IBM PC 5150 Technical Reference (August 1981).pdf
