IBM PS2 Model 50 Technical Reference (May 1988)
The IBM Personal System/2 Model 50 Technical Reference is IBM's 62-page model-specific interface reference for the PS/2 Model 50 (8550), First Edition, May 1988. The preface says it is to be used with the PS/2 Hardware Interface Technical Reference and the PS/2 and PC BIOS Interface Technical Reference. The October 1990 edition is also hosted.
Contents
[edit | edit source]From the contents page (p. v):
- Section 1, System Overview (p. 1-1): description and model and submodel bytes, system board features, block diagram, I/O address map, performance specifications for the Type 1 and Type 2 system boards, and physical specifications (Figure 1-7, p. 1-9).
- Section 2, Programmable Option Select (p. 2-1): POS address map, card selected feedback (hex 0091), system board enable/setup (hex 0094), POS registers 2 and 3 (hex 0102, 0103) including the parallel port select bits, and adapter enable/setup (hex 0096).
- Section 3, System Board (p. 3-1): Micro Channel adapter identification and central arbiter, ROM and RAM subsystems, system memory map, Type 1 and Type 2 memory connectors and presence detect, the real-time clock and CMOS RAM (p. 3-12) with its status registers, diagnostic, diskette type and equipment bytes, NMI, system control ports B and A, power-on password (p. 3-28), the Type 2 serial port controller and hardware compatibility (p. 3-29).
- Index.
[edit | edit source]It is a programming and interface reference: no FRU numbers, removal procedures, symptom index, schematics or component values. Unlike the October 1990 edition it has no power supply section; the only electrical data is the input range and current draw in the physical specifications. Anything common to the PS/2 family is in the Hardware Interface Technical Reference.
What it settles
[edit | edit source]Figure 1-7 (p. 1-9) gives the physical and electrical specifications: 360 × 420 × 140 mm, 9.55 kg, heat output 144.8 W, input 90-137 V or 180-265 V at a maximum of 2.7 A or 1.4 A, and maximum allowable currents of 275 mA from the keyboard port and 300 mA from the auxiliary device port. The October 1990 edition gives 150 W heat output for the same machine.
Pages that cite this document
[edit | edit source]- IBM PS/2 Model 50 cites it for the system board and the port current limits.
- IBM PS2 Model 50 Technical Reference (October 1990), IBM PS2 Model 60 Technical Reference (May 1988), IBM PS2 Model 50 Hardware Maintenance Reference, IBM PS2 Model 50 Schematics and IBM PS2 FDD Technical Reference (S42G-2194) list it as related.
