Psion Revo Plus General Maintenance
Preventive maintenance for the Psion Revo Plus (and the Diamond Mako).
The Revo Plus is a Revo, so the whole of Psion Revo General Maintenance applies โ the charging rules, the case microswitch, the backup routes, the screen and the case. This page records the differences.
What is different
[edit | edit source]| Change | Maintenance consequence |
| 16 MB RAM instead of 8 MB | More headroom, no maintenance implication |
| Larger battery | Longer charge time. If you replace the cells with the stock capacity for a Plus rather than a Revo, work the recalibration charge out accordingly |
| Loose-battery problem fixed | You do not need to glue the connector on a Plus. On an original Revo that is a standing recommendation; here it is not |
That third row is the practically useful one. On an original Revo, an intermittent death or a refusal to charge is very often the battery connector working loose โ a failure mode Psion corrected on the Plus.[1] So on a Plus, that symptom points at the cells or the charging circuit rather than at the connector, and you should not waste time chasing a mechanical fault the machine does not have.
The charging rules still apply
[edit | edit source]Unchanged from the Revo, and worth repeating because they are unusual:[1]
- Do not put the machine on charge when the battery is already above about 80 %. The charge termination senses a thermal change around that level; missing it can and does lead to overcharging. This caution applies to both Revo models.
- NiMH cells only.
- The red charging light turns off at around 84 %, not 100 %.
- After a cell replacement and hard reset, charge uninterrupted from 0 % to 100 % so the hardware recalibrates, preferably with the machine off, ignoring the meter during that charge.
Batteries
[edit | edit source]Still two internal NiMH AAA cells soldered to a connector and sealed under the nameplate โ larger capacity than the Revo's, but no more user-replaceable.[1]
The replacement procedure is identical and is on Psion Revo Battery Replacement, which covers the Revo, the Revo Plus and the Diamond Mako together.[2]
One thing does not change: the rear case microswitch that wakes and sleeps the machine is just as easily broken when refitting the battery bay.[2]
Diamond Mako
[edit | edit source]The Diamond Mako is a Revo Plus rebadged by SONICblue for the United States and Canada.[1] Everything on this page applies to it.
Capacitors
[edit | edit source]Not a recap candidate. Same reasoning as the Revo.
[edit | edit source]- Back up through the dock or IrDA.
- Let the battery run down before charging, and let the charge complete.
- Do not leave it on charge above 80 %.
- If the runtime has collapsed, plan a cell replacement โ remembering the Plus's larger stock capacity when calculating the recalibration charge.
- Check the rear case microswitch still wakes and sleeps the machine.
- Clean the IrDA window, the serial connector and the dock contacts.
[edit | edit source]- Psion Revo Plus ยท Psion Revo Plus Troubleshooting Guide ยท Psion Revo Battery Replacement
- Psion Revo General Maintenance โ the shared procedure
- Battery Refurbishment ยท Recommended Tools
[edit | edit source]- โ 1.0 1.1 1.2 1.3 1.4 "Psion Revo", Wikipedia. Source for the Revo Plus's RAM and battery differences, the fix for the loose-battery problem, the Diamond Mako rebadge, and the charging behaviour shared by both models.
- โ 2.0 2.1 David Savery, "Psion Revo/Diamond Mako Disassembly & Battery Replacement", R3UK, 2004. Source for the disassembly and battery replacement procedure covering all three machines, and the case microswitch caution.
