Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
List of abbreviations:
- N
- This edit created a new page (also see list of new pages)
- m
- This is a minor edit
- b
- This edit was performed by a bot
- (±123)
- The page size changed by this number of bytes
1 October 2026
| 01:26 | Acorn Archimedes A420 diffhist +59 Josh talk contribs (Add battery check (IC29 pin 8), RAM upgrade links from TSB 2/89, hard disc test warning; cite prices to 4corn; remove uncited discontinued/successor and failure-frequency claims; copyedit) | ||||
| 01:25 | Acorn Archimedes A410 diffhist +1,361 Josh talk contribs (Battery connector is PL10 and the NVM check is IC29 pin 8 (400/1 SM); add 400/1 power tags, IC positions, RAM upgrade links (TSB 2/89), capacitor list and fault checks; cite 1989 prices to 4corn; remove uncited claims; copyedit) | ||||
| 01:22 | Acorn Archimedes A310 diffhist −652 Josh talk contribs (Cite C37 short-circuit fault to stardot and the circuit diagram; fix MEMC1/MEMC1a attribution of Chris's A310s; remove uncited launch-MIPS, '10%' and MEMC1a-required claims; copyedit) | ||||
| 01:21 | Acorn Archimedes A305 diffhist +1,167 Josh talk contribs (Add empty RAM socket positions, C50 value reading, C37-C39 rails from the circuit diagram and component-level fault checks (CLS section 4); remove uncited 'first RISC', MEMC1a and discontinued claims; copyedit) | ||||
| 01:10 | Acorn Atom diffhist +2,799 Josh talk contribs (Replace memory map with Acorn's own (Technical Manual p. 20); fix adaptor rating, composite output, VIA position and board-issue claims; remove uncited edge-connector and RAM fault claims; add machine photo; copyedit) | ||||
30 September 2026
23:23 | Category:Acorn Computers 2 changes history +760 [Josh (2×)] | |||
23:23 (cur | prev) −46 Josh talk contribs (Remove emoji) | ||||
12:01 (cur | prev) +806 Josh talk contribs (Plain lead; add A3010 and A3020 rows and a list of hosted Acorn manuals; drop all-red mod columns (several named upgrades that do not exist for these machines); remove red links; add parent category; sentence-case headings) | ||||
| 16:04 | Acorn Archimedes A5000 diffhist 0 Josh talk contribs (→Models) | ||||
27 September 2026
10:51 | BBC Micro Model B+ 2 changes history −104 [Josh (2×)] | |||
10:51 (cur | prev) −100 Josh talk contribs (Remove red links to pages that do not exist on this wiki) | ||||
10:51 (cur | prev) −4 Josh talk contribs (Fix dead infobox image: BBC_Micro_Front_Restored.jpg has never existed on this wiki; use the hosted B+ photograph) | ||||
| 10:50 | Acorn System 4 Troubleshooting Guide diffhist −7 Josh talk contribs (Remove emoji from section headings; de-duplicate ref definitions that produced visible cite errors; merge the duplicated References section; targeted corrections noted in the drive report) | ||||
| 10:50 | Acorn System 4 Maintenance Guide diffhist −7 Josh talk contribs (Remove emoji from section headings; de-duplicate ref definitions that produced visible cite errors; merge the duplicated References section; targeted corrections noted in the drive report) | ||||
| 10:50 | Acorn Atom diffhist +12 Josh talk contribs (Remove emoji from section headings; de-duplicate ref definitions that produced visible cite errors; merge the duplicated References section; targeted corrections noted in the drive report) | ||||
| 10:50 | Acorn Electron diffhist +12 Josh talk contribs (Remove emoji from section headings; de-duplicate ref definitions that produced visible cite errors; merge the duplicated References section; targeted corrections noted in the drive report) | ||||
| 08:59 | Capacitor Failure Symptoms diffhist +80 Josh talk contribs (Link the documentation page for each cited manual, keeping the File: link as the direct download) | ||||
25 September 2026
| 08:54 | Capacitor Failure Symptoms diffhist +1,692 Josh talk contribs (P4 verification: add worked examples of ESR-rise and RIFA failure from the two hosted Pina books, with the U.S./International designator warning) | ||||
| 02:31 | BBC Micro Model A/B diffhist +288 Josh talk contribs (Link the R. B. Coats BBC BASIC textbook and label it plainly as third-party with no hardware content) | ||||
| 02:31 | BBC Micro Model B+ diffhist +546 Josh talk contribs (Link Acorn's B+ user guide and name its hardware appendices - it was reachable from no article) | ||||
24 September 2026
| 22:59 | Acorn System Catalogue diffhist +2,800 Josh talk contribs (Corrected a wrong description and recorded a scan gap: the scan runs printed pages 8-27 only, so it does NOT describe the System 1-4 machines as the page previously claimed. Listed what each surviving page covers and the details it does settle) | ||||
| 22:59 | Acorn System 1 Technical Manual diffhist +1,927 Josh talk contribs (Real documentation page: contents with page numbers, board numbers 200,000 and 200,001, the three separate parts lists and why configuration matters, and the honest gap that the circuit diagrams are loose sheets held separately) | ||||
| N 21:31 | Template talk:Navbox-AcornComputers diffhist +984 Josh talk contribs (Explain the navbox-unwritten convention and how to restore an entry when its page is written) | ||||
| 21:30 | Template:Navbox-AcornComputers diffhist +766 Josh talk contribs (Render entries with no page as plain text rather than red links (48 greyed, 0 restored) - every page transcluding this navbox inherited its red links) | ||||
