Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
Recent changes optionsShow last 50 | 100 | 250 | 500 changes in last 1 | 3 | 7 | 14 | 30 days
Hide registered users | Hide anonymous users | Hide my edits | Show bots | Hide minor edits
Show new changes starting from 17:26, 28 September 2026
Page name:
List of abbreviations:
N
This edit created a new page (also see list of new pages)
m
This is a minor edit
b
This edit was performed by a bot
(±123)
The page size changed by this number of bytes
27 September 2026
     10:43  IBM PC XT Troubleshooting Guide diffhist −643 Josh talk contribs (Structural and content repair: remove emoji from section headings; merge the duplicated References section (the trailing bare bullet list is now named inline refs); de-duplicate the tripled/quadrupled ref definitions that produced visible cite errors; rewrite the bolted-on power-supply and CMOS blocks so they describe this machine (the Dallas DS1287/DS12887 claim and, where applicable, the PC/XT minimum-load sentence did not apply here))
25 September 2026
     00:19  IBM PC XT (5160) diffhist +265 Josh talk contribs (P4 verification: link the IBM manuals hosted on this wiki that document this machine (they were unlinked from every article))
     00:18  File:IBM PC XT 5155 5160 Technical Reference Mar86.pdf diffhist +1,188 Josh talk contribs (P4 verification: real File: description - document identity from its own title page, page count, honest source note and honest licence block)
     00:16  IBM PC XT Technical Reference (First Edition) diffhist +2,938 Josh talk contribs (P4 verification: real documentation page - title as printed, part/form number, edition, contents, honest gaps, what it settles, cross-links)
     00:16  IBM PC 5150 Technical Reference diffhist +3,252 Josh talk contribs (P4 verification: real documentation page - title as printed, part/form number, edition, contents, honest gaps, what it settles, cross-links)
24 September 2026
     22:08  IBM PC XT/370 diffhist +3,544 Josh talk contribs (Fix refs so they render; IBM fits TWO cards not three - PC/370-P in slot 4 and PC/370-M in slot 3, with PC/3277-EM only on older machines and the 3278/79 or Remote Display Terminal adapter as alternatives; add IBMs model numbers (5160 Models 568/588/589), the 10 MB vs 20 MB fixed-disk configurations and IBMs unit specifications; host link is coax not twinax)
22 September 2026
     00:36  IBM PC XT Maintenance Guide 2 changes history +16,656 [Josh (2×)]
00:36 (cur | prev) +1,315 Josh talk contribs (Add sourced floppy drive head carriage rail cleaning and silicone relubrication (minuszerodegrees), replacing the unsourced white-lithium-grease advice removed in the previous edit)
00:28 (cur | prev) +15,341 Josh talk contribs (Verify against IBM 5155/5160 TechRef, IBM HMS 6280087 parts catalogue, Tandon TM100 service manual and minuszerodegrees; add inline <ref> citations. Corrections: all four rail ranges were wrong; PSU is two separate supplies not switchable; 1701 is generated by the controller BIOS ROM; removed fabricated claim that 1986 BIOSes turn a C800 ROM fault into 1-long-2-short beeps; Xebec 1210 corrected to IBM Fixed Disk Adapter (built by Xebec); slot 8 1801 error applies to accelerator cards; head cl...)
     00:36  IBM PC XT (5160) diffhist +7,088 Josh talk contribs (Verify against IBM 5155/5160 TechRef and minuszerodegrees; add inline <ref> citations. Corrections: dimensions/weight replaced with IBM figures (498x411x147 mm, 14.2 kg) instead of Wikipedia approximations; "Xebec 1210 MFM controller" corrected to IBM Fixed Disk Adapter (built for IBM by Xebec); slot 8 1801 error applies to accelerator cards; 1986 BIOS caveats named; removed unsourced "eXtended Technology" and "5160-788 only XT with CGA" claims; 3270 PC and XT/286 moved out of the 5160 submod...)
     00:28  IBM PC XT Capacitor Replacement Guide diffhist +8,827 Josh talk contribs (Verify against minuszerodegrees and IBM 5155/5160 TechRef; convert bare bullet sources to inline <ref> citations. Corrections: SNCTOL means "solder new capacitor to old legs"; post-recap voltage table was fabricated - replaced with IBM regulation tolerances and sense levels; removed invented ripple limits; PSU is two separate 120V and 220/240V units, not one switchable unit; 1701 comes from the HDD controller ROM not the motherboard POST; added 2-legged vs 3-legged footprint rule; dropped inc...)
21 September 2026
     21:51  IBM PC XT Maintenance Guide diffhist +20 Josh talk contribs (Verification drive: flag unverified component data pending check against a primary source)
     21:51  IBM PC XT Capacitor Replacement Guide diffhist +20 Josh talk contribs (Verification drive: flag unverified component data pending check against a primary source)
     21:51  IBM PC XT (5160) diffhist +20 Josh talk contribs (Verification drive: flag unverified component data pending check against a primary source)
