Macintosh IIvi
Revision as of 12:43, 27 September 2026 by Josh (talk | contribs) (House rule: reword the remaining in-article correction narratives to describe the claim in circulation rather than the page's own edit history)
Macintosh IIvi
Macintosh IIvi (same case as IIvx)
TypeDesktop Personal Computer
ReleasedOctober 19, 1992
DiscontinuedFebruary 10, 1993
Intro priceNot sold in United States
CPUMotorola 68030 @ 16 MHz
Memory4 MB RAM onboard (expandable to 68 MB)
Storage40 MB, 80 MB, 160 MB, or 400 MB SCSI hard drive
DisplayDB-15 video, 640×480 @ 8-bit (512K VRAM)
Sound8-bit stereo output, mono input
Dimensions6.0" H × 13.0" W × 16.5" D (15.2 × 33 × 41.9 cm)
Weight25 lbs (11.3 kg)
OS / FirmwareSystem 7.1 – Mac OS 7.6.1
PredecessorMacintosh IIci
SuccessorMacintosh Centris 650
Model no.M1350
The Macintosh IIvi is a desktop personal computer manufactured by Apple Computer, Inc. from October 1992 to February 1993.[1] The IIvi was a cost-reduced version of the Macintosh IIvx, featuring the same 68030 processor but running at 16 MHz instead of 32 MHz, and lacking the L2 cache and FPU of its faster sibling.
The IIvi was sold in South America, Europe, and Japan, but not in the United States. The consumer version sold in the US was the Performa 600.[2]
The Macintosh IIvi uses a Motorola MC68030 microprocessor running at 16 MHz.[3]
  • Clock Speed: 16 MHz
  • Bus Speed: 16 MHz
  • Data Path: 32-bit
  • L1 Cache: 0.5 KB (on-chip)
  • L2 Cache: None
  • FPU: Optional Motorola 68882
The IIvi lacks the 32K L2 cache found in the IIvx, making it slower in cache-dependent operations.
Memory
RAM Configuration
  • Onboard RAM: 4 MB soldered
  • SIMM Slots: 4 × 30-pin
  • SIMM Speed: 80 ns minimum
  • Maximum RAM: 68 MB (4 MB onboard + 64 MB in SIMMs)
  • SIMM Installation: Four identical SIMMs must be installed as a group
ROM
  • ROM Size: 1 MB
  • ROM Type: Macintosh ROM
VRAM
  • Standard VRAM: 512 KB (two 256 KB VRAMs)
  • Maximum VRAM: 1 MB (two 512 KB VRAMs)
  • VRAM Slots: 2 × VRAM SIMM slots
  • VRAM Speed: 100 ns
Video
  • Video Output: DB-15 connector
  • Maximum Resolution: 640 × 480 pixels
  • Color Depth (512K VRAM): 8-bit (256 colors) at 640×480, 16-bit at 512×384
  • Color Depth (1 MB VRAM): 16-bit (thousands) at 640×480
Additional displays can be connected via NuBus video cards.
Hard Drive
  • Interface: SCSI (DB-25 external connector)
  • Standard Capacities: 40 MB, 80 MB, 160 MB, or 400 MB
Floppy Drive
  • Drive Type: Apple SuperDrive (1.44 MB)
  • Auto-inject: Yes
Optical Drive
  • CD-ROM: Optional 2X internal
Input/Output and Expansion
Ports
  • ADB Ports: 2 (Apple Desktop Bus)
  • Serial Ports: 2 × Mini DIN-8 RS-422 (Printer and Modem)
  • SCSI Port: DB-25 connector
  • Video Port: DB-15 connector
  • Audio Output: 3.5 mm stereo jack
  • Audio Input: 3.5 mm mono jack
Expansion Slots
  • NuBus slots: 3, plus what Apple calls an accelerator slot (not a general-purpose PDS)[4]
  • Processor Direct Slot (PDS): 1
  • Expansion Bay: 1 × 5.25" (for CD-ROM)
Power
Power — Apple's figures, and the trap in them
Apple's Electrical specification for the IIvi, IIvx and Performa 600 is in three parts, and they are easy to conflate:[4]
  • A/C line input: 100–120 VAC, 200 W
  • A/C line output receptacle: 100–240 VAC, 3 A maximum — this is the switched monitor
 outlet on the back, not the machine's own input
  • DC power: 112 W maximum
"Input voltage 100–240 V AC" circulates for this machine. That is the output receptacle's rating. Apple prints the machine's own line input as 100–120 VAC — a domestic figure — so a 220–240 V IIvx is a different supply, and its primary-side parts are not interchangeable with a 110 V one. Check which board is in front of you before ordering primary-side capacitors.
"230 W maximum" also circulates for this machine and is not Apple's figure for any part of this machine: 200 W is the AC input rating and 112 W the DC output. 230 W is the Macintosh IIfx figure.
Apple publishes no rail tolerance and no power-supply adjustment for this machine.
Battery
3.6 V ½AA lithium; Apple's instruction is to replace it below 2.8 V[4] — measured on the 10 V DC range. 2.8 V is the IIcx / IIci / IIvi / IIvx / Quadra 700 / SE / SE-30 figure; 3.0 V and 3.2 V belong to other machines and get transplanted between them. Lithium leakage is neutralised with bicarbonate of soda, not vinegar.
Case Design
The IIvi uses the same high-profile desktop case as the Macintosh IIvx, Performa 600, Macintosh Centris 650, Macintosh Quadra 650, and Power Macintosh 7100. The case includes a front-accessible 5.25" bay for an optional CD-ROM drive.
  • Dimensions: 6.0" H × 13.0" W × 16.5" D (15.2 × 33 × 41.9 cm)
  • Weight: 25 lbs (11.3 kg)
Common maintenance concerns include capacitor leakage, PRAM battery failure, and power supply issues.
For cleaning, battery maintenance, and inspection procedures, see the Macintosh IIvi General Maintenance page.
The Macintosh IIvi logic board contains surface-mount electrolytic capacitors that leak over time.
For capacitor specifications and procedures, see the Macintosh IIvi Capacitor Replacement Guide.
Common issues include startup failures, video problems, and SCSI errors.
For diagnostics, see the Macintosh IIvi Troubleshooting page.
Technical Specifications
Sub-system Specification (Macintosh IIvi, October 1992)
CPU Motorola 68030 @ 16 MHz
FPU Optional Motorola 68882
Bus Speed 16 MHz
ROM 1 MB
RAM 4 MB onboard + 4 × 30-pin SIMM slots (68 MB max)
L1 Cache 0.5 KB (on-chip)
L2 Cache None
Video 640 × 480 @ 8-bit (512K VRAM), 16-bit with 1 MB
Sound 8-bit stereo output, mono input
Storage 40/80/160/400 MB SCSI HDD, 1.44 MB SuperDrive
Expansion Apple: three NuBus slots and one accelerator slot[4]; plus a 5.25-inch bay
Ports 2 × ADB, 2 × Serial, SCSI, Video, Audio I/O
Identification
Identifier Value
Apple Model Number M1350
Gestalt ID 44
  1. ↑ Macintosh IIvi Specs, EveryMac.com—link(accessed 2026-02-09)
  2. ↑ Macintosh IIvi Specs, EveryMac.com—link(accessed 2026-02-09)
  3. ↑ Macintosh IIvi Specs, EveryMac.com—link(accessed 2026-02-09)
  4. ↑ 4.0 4.1 4.2 4.3 Apple Computer, Macintosh IIvx, Macintosh IIvi, Performa 600 Service Source (Macintosh IIvx/IIvi/Performa 600 Service Source, File:Macintosh_iivx.vi.perf_600.pdf), Specifications chapter and Additional Procedures → Battery Verification ("if the battery voltage is below 2.8 volts, replace the battery").
