Acorn System 2 Capacitor Replacement Guide
This guide covers recapping the Acorn System 2 (1980). The System 2 is a set of Eurocards, so the capacitors are per-card: each card carries ceramic decouplers plus a single electrolytic on its +5 V regulator. The exact per-card values are in the card circuit diagrams and the Acorn System Catalogue; the CPU and cassette cards use the verified Acorn System 1 values.[1]
Approach
The System 2 has no mains and no CRT on its cards (only the optional Acorn PSU is mains-powered). Capacitor work is low-risk per-card bench work. On each Eurocard:
- The recap target is the regulator electrolytic (the CPU and cassette cards use 15 µF/16 V; the VDU and memory cards each have their own regulator electrolytic).
- The ceramic decouplers are stable and are left in place.
These are the Acorn System 1 cards. Their full capacitor lists are in the Acorn System 1 Capacitor Replacement Guide; the only electrolytic on each is a 15 µF/16 V part (C10 on the CPU card, C5 on the cassette card).
The 40×25 VDU card and the memory (RAM + BASIC ROM) card each regulate their own +5 V and carry a regulator electrolytic plus ceramic decouplers. Read each value from the card itself and the card circuit diagram before replacing. Replace any electrolytic with a 105 °C low-ESR part of equal capacitance and equal-or-higher voltage, observing polarity.
Procedure
- Power off; remove the card from the backplane.
- Record the value, voltage and polarity of each electrolytic.
- Desolder, clean the holes, fit the new part with correct polarity, solder and trim.
- Verify +5 V on the card and refit.
Optional mains PSU
If an Acorn mains power supply is fitted, it has its own bulk smoothing electrolytics (and mains-side parts). Recap it only if competent with mains supplies; discharge the bulk capacitor first.
- Acorn System 2
- Acorn System 2 Maintenance Guide
- Acorn System 2 Troubleshooting Guide
- Acorn System 1 Capacitor Replacement Guide · Capacitor Failure Symptoms
- ↑ Acorn System Catalogue and Acorn System 1 Technical Manual, Acorn Computers — hosted on this wiki. Source for the Eurocard set and the System 1 CPU/cassette-card capacitor values (a 15 µF/16 V electrolytic plus ceramic decouplers per card).
