Amstrad PC3286
Revision as of 05:25, 2 October 2026 by Josh (talk | contribs) (New page: PC3286 specifications, processor board, configuration and owner reports, cited to Amstrad's manual and leaflet)
The Amstrad PC3286 is the 80286 model of Amstrad's "Generation 3" desktop PCs, launched in 1990 with the 8086-based Amstrad PC3086 and the 80386SX-based Amstrad PC3386SX. Amstrad's leaflet called it "the workhorse of the Generation 3 range". It runs a 16 MHz 80286 on a plug-in processor board, has 1 MB of memory on SIMMs, an AT-type IDE interface, built-in VGA and five ISA slots, and shares its main board and case with the PC3386SX.[1][2][3][4]
Amstrad PC3286
PC3286 system unit (photo: tarasque, CC BY 4.0)
ManufacturerAmstrad plc
TypeDesktop personal computer (IBM PC/AT compatible)
Released1990
CPUIntel 80286 at 16 MHz on a plug-in processor board; 80287 socket
Memory1 MB, expandable to 16 MB with SIMMs; optional 64 KB cache
Storage3.5-inch 1.44 MB or 5.25-inch 1.2 MB floppy drive; optional 40 MB AT-IDE hard disk
Display—
Sound—
GraphicsBuilt-in Paradise VGA, compatible with EGA, CGA, MDA and Hercules
Ports / interfaceParallel (25-way), RS232 serial (25-way), Amstrad mouse, VGA, monitor power outlet
ExpansionTwo full-length and one half-length 16-bit ISA slots, one full-length and one half-length 8-bit
Dimensions425 × 135 × 390 mm (W × H × D)
OS / FirmwareMS-DOS 3.30A
PC3286 (Amstrad leaflet and user manual)
Item Value
Processor 80286 at 16 MHz, slowed to 8, 5 or 4 MHz by software; 80287 socket
Memory 1 MB parity-checked, expandable to 2, 4, 8, 10 or 16 MB; built-in LIM expanded memory
Cache 64 KB of 35 ns cache RAM, optionally fitted
Floppy drive 3.5-inch 1.44 MB or 5.25-inch 1.2 MB
Hard disk Optional 40 MB IDE, 28 ms, on the built-in AT-type IDE adaptor
Drive bays Two 3.5-inch third-height and two 5.25-inch half-height
Expansion Two full-length and one half-length 16-bit ISA slots, one full-length and one half-length 8-bit; expansion bus at 8 MHz
Video Extended VGA, also supporting MDA, CGA, Hercules, EGA and MCGA
Ports Bi-directional parallel, RS232C serial (25-way D), mouse, VGA, monitor power socket
Keyboard 102-key, AT software compatible
Size 425 × 135 × 390 mm
Software MS-DOS 3.30A
Sources: Amstrad's leaflet and user manual; the speed steps are from Amstrad PC International.[1][2][5][4]
The 286 processor board, MS0188A (photo: tarasque, CC BY 4.0)
The processor sits on a daughterboard that plugs into the main board; on one machine it is silkscreened MS0188A, "286" and "Amstrad copyright 1990". The 80287 co-processor socket is on this daughterboard, and the PC3386SX uses the same main board with an 80386SX daughterboard.[3][6] The Centre for Computing History holds both a 286 and a 386 daughterboard catalogued against the PC3286.[7]
Memory is on parity SIMMs (nine bits to the byte) in four sockets, fitted in pairs; DRAM speed and memory size are set by links, and an optional 64 KB cache uses 35 ns chips.[8] The built-in devices (hard disk adaptor, VGA, mouse port, printer port, floppy controller and COM1) can each be disabled by a link, and four links select the mouse interrupt.[5] The video is a Paradise VGA, which the DEVICE command reports as "Internal PVGA". It is set by four DIP switches on the back panel, the fourth of which selects an 8-bit or 16-bit interface to the VGA.[9][10][11]
The clock and setup data are in a CMOS RAM with a built-in lithium battery, a Dallas DS1287-type module on a socket.[12][6] The keyboard uses Amstrad's own interface. The mouse plugs into a 9-pin D socket, which is not a serial port, and appears to software as a Microsoft bus mouse, so the standard MOUSE.COM works.[13] The BIOS is Amstrad's own, version 2.0 in the manual; Cliff Lawson of Amstrad gives the 3000 series a 2.xx BIOS, against 1.xx in the 1000 and 2000 series.[14][11][15]
Configuration
Amstrad's manual runs the SETUP utility (version 2.0) from the system disk, at the DOS prompt; it records memory sizes, the primary display, the co-processor, the processor speed, the floppy and hard disk types and the expanded memory I/O address in the CMOS RAM. Lawson gives Ctrl-Alt-S at the DOS prompt for the 3000 and 4000 series.[14][11] The DEVICE command changes the processor speed, cache settings and video emulation without a restart.[9]
Amstrad GmbH's interrupt table for the PC3286 and PC3386SX gives IRQ 3, 10, 11, 12 and 15 as free; the mouse port is on IRQ 5, the hard disk on IRQ 14 and the real-time clock on IRQ 8.[16]
Known faults
  • Owners report problems with SETUP: one found that a SETUP program meant for the earlier models, which identified the machine as a PC2286, offered only 12 MHz on his PC3286, and that Ctrl-Alt-S did nothing on his machine.[17]
  • A PC3286 described on Vogons in 2024 would not POST, even after the clock module was replaced with a modern equivalent; the thread did not record a fix.[6]
  • The clock module's battery runs down with age, giving "WARNING: CMOS battery failed".[18]
The procedures are in the Amstrad PC3286 Maintenance Guide and the fault tables in the Amstrad PC3286 Troubleshooting Guide. The case, clock chip and start-up messages are shared with the PC3086 and covered in its guides. No capacitor list has been published: Amstrad's service manual for the range (SM-PC3000) survives only in the Centre for Computing History's paper collection.[19][20]
  1. ↑ 1.0 1.1 Amstrad plc, PC3286 leaflet, © August 1990, p. 2 (specification). Hosted as File:Amstrad PC3286 leaflet (1990).pdf.
  2. ↑ 2.0 2.1 Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 1-2 to 1-4. Specifications of the three models and memory configuration.
  3. ↑ 3.0 3.1 Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 7-1 to 7-7. Processor speeds, fitting an 8087, 80287 or 80387SX co-processor, and opening the system unit.
  4. ↑ 4.0 4.1 "Neue PC-Reihe von Amstrad", Amstrad PC International, October/November 1990, pp. 50–51. Internet Archive. Retrieved 2026-10-02. Announcement at OrgaTech '90 of the PC3086, PC3286 and PC3386 as replacements for the 2000 series, with a specification table.
  5. ↑ 6.0 6.1 6.2 Vogons forum, "Amstrad 3286", tarasque and others, September 2024 to February 2025. Retrieved 2026-10-02. A PC3286 that would not POST after the Dallas clock module was replaced with a Necroware nwX287; the owner's list of option link positions; photographs (CC BY 4.0).
  6. ↑ Centre for Computing History, "Amstrad PC3286 286 Daughterboard" (CH42246) and "Amstrad PC3286 386 Daughterboard" (CH42247), 1990. Retrieved 2026-10-02.
  7. ↑ Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 8-6 to 8-10. Memory cache, SIMM upgrades, memory size and DRAM speed links, cache speed links.
  8. ↑ 9.0 9.1 Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 4-2 to 4-18. The DEVICE command: display, floppy drive, cache, memory map and processor speed settings.
  9. ↑ Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 6-5 to 6-15. PS/2 and AT video modes, disabling the built-in VGA, links 901 and 902, and the video DIP switches.
  10. ↑ 11.0 11.1 11.2 Cliff Lawson (Amstrad plc), "Older AT PCs" (atpcs.htm), from his Amstrad support pages at web.ukonline.co.uk/cliff.lawson, as preserved at freetimeweb.nl. Retrieved 2026-10-02. SETUP on the 3xxx and 4xxx series, the BIOS 2.xx of the 3xxx series, memory links for the 3286, 3386SX and 4386SX, video DIP switches and option links.
  11. ↑ Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 13-2 to 13-4. Transporting a hard disk PC, PARK.COM, and replacing the CMOS RAM.
  12. ↑ Cliff Lawson (Amstrad plc), "General notes on Amstrad PCs" (general.htm), as preserved at freetimeweb.nl. Retrieved 2026-10-02. Amstrad's proprietary keyboard and mouse interfaces up to the 4386, PS/2-compatible ones from the 5xxx series, and a summary specification of each PC.
  13. ↑ 14.0 14.1 Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 3-7 to 3-15. Voltage selector, power switch, the "Please wait." self-test dots, start-up messages and BIOS versions, and the SETUP program for the PC3286 and PC3386SX.
  14. ↑ Thomas Kallay, "Big Brother: AMSTRADs Flaggschiff der Generation 3: der PC3386 SX", Amstrad PC International, February/March 1991, pp. 41–42. Internet Archive. Retrieved 2026-10-02. Specification table and test of a PC3386SX with a 100 MB Conner disk.
  15. ↑ "AMS-Line: Der Informationsdienst der Firma AMSTRAD", Amstrad PC International (page header CPC), August/September 1991, p. 7. Internet Archive. Retrieved 2026-10-02. Amstrad GmbH's column: the meaning of the start-up dots, the PC4386SX BIOS indicator, and the interrupt and I/O address tables of the PC3086, PC3286 and PC3386SX.
  16. ↑ Vogons forum, "Amstrad 286 wrong CPU speed", AndalusianRG and others, October 2021. Retrieved 2026-10-02. A PC3286 whose borrowed SETUP program offered only 12 MHz.
  17. ↑ Amstrad plc, User Manual and MS-DOS Guide for the PC3086, PC3286 and PC3386SX, 2nd ed. (1990), pp. 14-1 to 14-3. Non-fatal and fatal hardware error messages.
  18. ↑ Centre for Computing History, "Amstrad PC3086 PC3286 PC3386SX Colour Personal Computers Service Manual" (CH27476): 53-page service manual with schematics and wiring diagrams, reference SM-PC3000. Retrieved 2026-10-02.
  19. ↑ acpc.me (ACME) archive, Amstrad PC section, directory DOCUMENTS_TECHNIQUES/SERVICE_MANUALS. Retrieved 2026-10-02. The PC3086/PC3286/PC3386SX, PC4386SX and PC5086/PC5286 service manuals are listed with placeholder images only, marked missing.
