Amstrad PC2386
Revision as of 05:26, 2 October 2026 by Josh (talk | contribs) (New page from Amstrad's PC2386-65 service manual and owners' repair reports)
The Amstrad PC2386 is the 80386 model of Amstrad's PC2000 series, alongside the Amstrad PC2086 and Amstrad PC2286. It has a 20 MHz 80386 with a 64 KB cache, 4 MB of 32-bit parity memory, five 16-bit expansion slots, a Paradise VGA adaptor on the main board and, as the PC2386-65, a 65 MB hard disc. Amstrad's specification lists built-in LIM 4.0 expanded memory and MS-DOS 4.0 with Windows/386.[1] The system unit is larger than the PC2086's, at 415 × 160 × 485 mm.[1][2]
Amstrad PC2386
PC2386 with colour monitor, from the cover of Amstrad's service manual
ManufacturerAmstrad plc
TypeIBM PC/AT-compatible personal computer
Released1989
CPU80386 at 20 MHz, 80387 socket
Memory4 MB with parity, 32-bit; 64 KB 35 ns cache
Storage1.44 MB 3.5-inch floppy drive; 65 MB hard disc (Seagate ST277R)
DisplayBuilt-in VGA (Paradise PVGA1), Hercules, CGA and EGA compatible
Sound—
Ports / interfaceSerial, parallel, mouse, VGA, external floppy drive
ExpansionFive 16-bit ISA slots
PowerInternal switch-mode supply with fan
Dimensions415 × 160 × 485 mm (system unit)
OS / FirmwareMS-DOS 4.0, Windows/386
Model no.PC2386-65
History
Wikipedia gives 1989 for the launch of the PC2000 series, while the Centre for Computing History dates the PC2086, launched at the same time, to 1988;[3] the Centre for Computing History lists a PC User review of the PC2386, "Power for the People", dated February 1989.[4][5] Wikipedia records that the Seagate ST277R hard discs shipped in the PC2386 had to be recalled and fitted with Western Digital controllers, that Amstrad later sued Seagate and won in 1997, and that the bad press cost Amstrad its lead in the European PC market.[4][6] Amstrad's parts list gives the hard disc as the ST277R (part 176725).[1]
PC2386 main ICs (service manual p. 44)
IC Part as listed
IC146 AMS386 (part 176600)
IC001–009 KM41C1000-10
IC151–153 µPD421000LA-10, nine pieces
IC160–170 HM6789P-30
IC156 AMS40192, TMS72C256-20 ROS
IC157–159 AMS40191, AMS40190, AMS40189 ROS
IC115 MC146818P
IC120 Z765APS
IC307 PVGA1 video gate array
IC305 IMSG171P-35
IC311–324 (eight) KM41464-12
IC316 AMS40193
IC601–607 STK7458, MB3761M, LA6324, BA707, BA6993, AN7905F, AN7912T
The ROS (BIOS) is in four ROMs, and the Paradise PVGA1 is the video controller. IC316 is the device whose pin 6 carries the VCO control voltage in Amstrad's alignment; the IC6xx parts are on the power supply board.[1]
The crystals are X101 1.8432 MHz, X102 32.768 kHz, X103 48.0 MHz, X104 14.318 MHz, X105 40.0 MHz, X301 25.175 MHz, X302 28.322 MHz, X303 36.00 MHz, X304 15.00 MHz and X801 11.0 MHz. The floppy drive is listed as an OSDA-45A.[1] An owner's PC2386 has a Citizen OSDA-46 drive connected by a straight cable, with the drive set to ID 0.[7]
Power
The supply has its own fan (M601), a 330 µF 400 V reservoir capacitor (C601), an STK7458 hybrid regulator and two optocouplers, a TLP732 (Q602) and a TLP741G (Q603).[1] It is adjusted with VR604 for +5 V and VR603 for +12 V, and VR601 sets the primary protection.[1] Amstrad allowed component-level repair of the supply and monitors, but not of the main CPU board or the drives.[1] The schematic for the supply is on page 48 of the manual, which is missing from the hosted scan.[1]
Repair guides
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Amstrad plc, PC2386-65 Personal Computer Service Manual. Hosted as File:Amstrad PC 2386 Service Manual.pdf, described at Amstrad PC 2386 Service Manual. Technical specification, notes to engineers and safety tests p. 2; alignment instructions p. 3; main PCB views pp. 4–5; electrical parts list pp. 44–45. Pages 47 (cabinet parts) and 48 (power supply schematic) are missing from the scan.
  2. ↑ Amstrad plc, PC2086 S/D/30 Personal Computer Service Manual. Hosted as File:Amstrad PC 2086 Service Manual.pdf, described at Amstrad PC 2086 Service Manual. Technical specification p. 2.
  3. ↑ Centre for Computing History, "Amstrad PC2086 S", exhibit CH16138. Retrieved 2026-10-02. The PC2086 of 1988, released at the same time as the PC2286 and PC2386.
  4. ↑ 4.0 4.1 Wikipedia, "Amstrad PC2286" (revision 1353136875). Retrieved 2026-10-02. The PC2000 series launched 1989; the Seagate ST277R recall and replacement with Western Digital controllers; Amstrad's successful action against Seagate, judged in 1997.
  5. ↑ Centre for Computing History, "Amstrad PC2286/40", exhibit CH1264. Retrieved 2026-10-02. The PC2000 series description, and the related article "Power for the People – Amstrad PC 2386 Review", PC User, February 1989.
  6. ↑ Wikipedia, "Amstrad" (revision 1373433025). Retrieved 2026-10-02. The PC2000 series, the ST277R problem and the Seagate lawsuit.
  7. ↑ Tomek TRV, "Amstrad PC2386 floppy drive problem", VOGONS, 3 December 2025, and the same report at the Vintage Computer Federation Forums. Retrieved 2026-10-02. Community report: the Citizen OSDA-46 drive on a straight cable set to ID 0; other drives set to ID 0 that would not work in the PC2386.
