Macintosh SE/30
Revision as of 16:08, 4 April 2025 by Josh (talk | contribs)
Macintosh SE/30
Macintosh SE/30
TypePersonal Computer
ReleasedJanuary 16, 1986
DiscontinuedOctober 21, 1991
Intro priceUS$4,369
CPUMotorola 68030 @ 16 MHz
Memory1 MB RAM (expandable to 128 MB)
Storage1.44 MB 3.5" floppy drive, Internal SCSI HDD
Display9" monochrome CRT (512×342 pixels)
SoundMonaural 8-bit, 22 kHz (4-voice)
Dimensions13.6" H × 9.6" W × 10.9" D
Weight19.5 lbs (8.8 kg)
OS / FirmwareSystem 6.0.3 – System 7.5.5
PredecessorMacintosh SE
SuccessorMacintosh Classic II
CodenameGreen Jade, Fafnir
Model no.M5119
Historical Background
The Macintosh SE/30 was introduced on January 19, 1989, as a powerful upgrade to the original Macintosh SE. It featured a significantly enhanced CPU, the Motorola 68030 running at 16 MHz, making it one of Apple's most powerful compact Macs. The SE/30 introduced support for up to 128 MB RAM, onboard expansion via the PDS slot, and included an internal 1.44 MB "SuperDrive" floppy disk drive and optional internal SCSI hard drive. The SE/30 was popular among power users and is still highly valued by vintage computer enthusiasts.
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh SE/30 General Maintenance page.
The Macintosh SE/30 consists of two main printed circuit boards: the Logic Board and Analog Board. Below are detailed schematics and the official Apple service manual for the Macintosh SE/30.
Apple Service Manual
All of the Apple Service Manuals can be found on the Apple Service Manuals page. However, you can find the SE/30 Service Manual here: File:Macintosh SE30.pdf
Macintosh SE/30 PCB Schematics
Logic Board Analog Board
Macintosh SE/30 Logic Board
File:MacintoshSE30 LogicBoard Schematic.pdf
Macintosh SE/30 Analog Board
Macintosh SE/30 Analog Board Schematic
Detailed capacitor replacement guidelines for both the analog and logic boards can be found on the Macintosh SE/30 Capacitor Replacement Guide page.
Retrobrite
Instructions on addressing case yellowing through Retrobrite treatment can be found on the Retrobrite page.
A comprehensive troubleshooting guide addressing common issues such as no power, chime but no video, intermittent operation, Sad Mac errors, floppy drive problems, and SCSI hard drive maintenance is available on the Macintosh SE/30 Troubleshooting page.
