IBM Color Graphics Adapter
Revision as of 10:28, 21 May 2026 by Josh (talk | contribs) (โ†’Video Modes)
An IBM Color Graphics Adapter (CGA) card
Manufacturer IBM
Type 8-bit ISA video display adapter
Release date 1981 (with the original IBM PC)
Interface 8-bit ISA
Compatible IBM PC (5150), IBM PC XT (5160), IBM PC AT (5170), PC-compatible clones
Connectivity DB-9 TTL RGBI (drives the IBM 5153); composite NTSC RCA; light-pen header
The IBM Color Graphics Adapter (CGA) is the original 8-bit ISA colour graphics card IBM released alongside the IBM PC (5150) in 1981. It uses a Motorola MC6845 CRT controller, carries 16 KB of dedicated video RAM, and drives a TTL RGBI monitor (the IBM 5153) or a composite TV through an NTSC encoder.
Video Modes
CGA video modes
Mode Resolution Colours Notes
0 40 ร— 25 text 16 fg / 8 bg Colour burst on
1 40 ร— 25 text 16 fg / 8 bg Colour burst suppressed
2 80 ร— 25 text 16 fg / 8 bg
3 80 ร— 25 text 16 fg / 8 bg Colour burst suppressed
4 320 ร— 200 graphics 4 from fixed palettes Palette 0: cyan/magenta/white; Palette 1: green/red/yellow
5 320 ร— 200 graphics 4 (greyscale on composite) Composite "alternate" palette
6 640 ร— 200 graphics 2 (background + foreground) Highest standard resolution
Several undocumented modes can be coaxed out of the 6845 (160 ร— 100 16-colour text-block mode, composite NTSC artefact colour, and various demoscene techniques), but they are not part of the BIOS interface.
  • MC6845 CRTC โ€” clock and sync generation, addressing.
  • 16 KB video RAM.
  • TTL RGBI output on DB-9 (drives the IBM 5153).
  • Composite NTSC output on RCA jack.
  • Light-pen connector.
Common Faults
  • Snow โ€” the CGA "snow" effect is not a fault but a design quirk: the video RAM is single-ported and CPU writes during the active raster cause briefly-visible noise. Most CGA-aware games wait for the horizontal retrace to avoid it.
  • No video, beep code 1 long + 2 short โ€” reseat the CGA card first.
  • Missing one colour channel โ€” bad output buffer at the DB-9, or cracked solder joint on the connector.
  • Smoke from a discoloured tantalum โ€” replace the failed tantalum and any series resistor that may have died with it.
