Macintosh Performa 6360
| Macintosh Performa 6360 | |
| Type | Personal Computer |
| Released | October 17, 1996 |
| Discontinued | October 1, 1997 |
| Intro price | US$1,500 |
| CPU | PowerPC 603e @ 160 MHz |
| Memory | 16 MB RAM (8 MB on-board, expandable to 136 MB) |
| Storage | 1.2 GB IDE hard drive, 8X CD-ROM |
| Display | DB-15 video output (800×600 16-bit, 1024×768 8-bit) |
| Sound | Monophonic input, stereo output |
| Dimensions | 4.3" H × 12.6" W × 16.5" D (10.9 × 32 × 41.9 cm) |
| Weight | 19 lbs (8.6 kg) |
| OS / Firmware | System 7.5.1 – Mac OS 9.1 |
| Predecessor | Performa 6320CD |
| Successor | Performa 6400 |
| Codename | Alchemy (logic board) |
| Model no. | N/A (Gestalt ID 58) |
The Macintosh Performa 6360 is a PowerPC-based desktop personal computer manufactured by Apple Computer, Inc. and released on October 17, 1996.[1] Despite its similar name to the earlier Performa 6300 series, the 6360 uses a significantly different internal architecture based on the "Alchemy" logic board with faster DIMM-based memory, PCI expansion, and a faster 160 MHz processor.
The Performa 6360 shares its Alchemy logic board with the Performa 6400 mini-tower and Power Macintosh 5400 all-in-one.
Hardware Overview
The Performa 6360 represents a significant upgrade from the 6300 series:
- Processor: PowerPC 603e at 160 MHz with integrated FPU
- RAM: 8 MB soldered on-board plus two 168-pin DIMM slots (70 ns), 16 MB standard, expandable to 136 MB
- Storage: 1.2 GB IDE hard drive, 8X CD-ROM, 1.44 MB floppy
- Video: 1 MB system RAM dedicated to video
- Expansion: 1× PCI slot, communications slot, video I/O slot, TV tuner slot
Key Differences from Performa 6300 Series
| Feature | Performa 6300CD | Performa 6360 |
| Processor | 100 MHz 603e | 160 MHz 603e |
| RAM Type | 72-pin SIMM | 168-pin DIMM |
| Onboard RAM | None | 8 MB |
| Maximum RAM | 64 MB | 136 MB |
| Expansion | LC PDS | PCI |
| L2 Cache | 256 KB included | 256 KB optional |
| CD-ROM | 4X | 8X |
| Logic Board | M3076 | Alchemy (Gestalt ID 58) |
The Performa 6360 uses the Alchemy logic board, which provides a 64-bit data path to main memory—a significant improvement over the earlier 5200/6200/6300 series. The 40 MHz system bus communicates with the 160 MHz PowerPC 603e processor.
Third-party processor upgrades are available that can override the soldered CPU via the L2 cache slot.
Memory and Storage
RAM Configuration
| Specification | Details |
| RAM Type | 168-pin DIMM |
| RAM Speed | 70 ns |
| Standard RAM | 16 MB |
| Maximum RAM | 136 MB |
| Motherboard RAM | 8 MB (soldered) |
| RAM Slots | 2 |
Storage Systems
- Hard Drive: 1.2 GB IDE internal drive
- Floppy Drive: 1.44 MB 3.5" SuperDrive (manual insert)
- CD-ROM: 8X internal CD-ROM drive
Display and Graphics
Video memory is integrated, with 1 MB of system RAM dedicated to video functions:
| Resolution | Color Depth |
| 640×480 | 16-bit (Thousands) |
| 800×600 | 16-bit (Thousands) |
| 832×624 | 8-bit (256 colors) |
| 1024×768 | 8-bit (256 colors) |
A second display can be supported with the addition of a PCI video card.
For detailed maintenance practices including cleaning, PRAM battery management, and general upkeep, refer to the dedicated Macintosh Performa 6400 General Maintenance page. The Performa 6360 shares the Alchemy logic board with the 6400 series.
Detailed capacitor replacement guidelines for the Alchemy logic board can be found on the Macintosh Performa 6400 Capacitor Replacement Guide page.
A comprehensive troubleshooting guide addressing power issues, startup problems, and other common failures is available on the Macintosh Performa 6400 Troubleshooting page.
| Sub-system | Specification (Macintosh Performa 6360, 1996) |
| Bus width | 64-bit data path |
| System Bus | 40 MHz |
| ROM | 4 MB |
| RAM | 16 MB (expandable to 136 MB) |
| L1 Cache | 32 KB |
| L2 Cache | 256 KB (optional) |
| Video | 800×600 16-bit, 1024×768 8-bit |
| Sound | Mono input, stereo output |
| Disks | 1.2 GB IDE HDD, 1.44 MB floppy, 8X CD-ROM |
| Ports | ADB, SCSI, 2× GeoPort Serial, Audio I/O, Video out |
Power Specifications
- Input: 100V-125V or 200-240V AC, 47-63 Hz
- Maximum power consumption: 220 Watts
