Macintosh IIvi Troubleshooting
Revision as of 00:08, 16 July 2026 by Josh (talk | contribs) (Expand troubleshooting: PRAM battery bomb, SMD logic-board recap, desktop PSU recap; cited (68kMLA/MacDat/BMOW))
This guide covers common faults with the Macintosh IIvi, including startup failures, video problems, and storage errors.
Preliminary Checks
  • Verify the power cable is secure
  • Test with a known-good outlet
  • Disconnect all external SCSI devices
  • Remove any NuBus or PDS cards
  • Check for visible capacitor leakage or battery corrosion
No Power
Power Issues
Symptom Possible Cause Action
Completely dead Blown fuse, failed PSU, bad cord Check outlet; test power cord; check PSU fuse
Clicking or ticking Failed PSU capacitors Recap power supply
Powers on briefly then dies Overload protection, shorted component Disconnect cards and drives; test with minimal config
Fan spins but no startup Dead PRAM battery, failed logic board Replace PRAM battery; check for capacitor damage
Startup Failures
Startup Problems
No chime, no video Dead logic board, failed capacitors Recap logic board; check PRAM battery
Chime but no video VRAM issue, video connector Reseat VRAM SIMMs; check video cable
Sad Mac error Hardware failure Decode error code; test RAM
Flashing question mark No boot device Check SCSI drive; verify termination
Chimes of death RAM failure Reseat or replace RAM SIMMs
Sad Mac Error Codes
Common Sad Mac Codes
Code Range Meaning Action
01XXXX ROM test failure Check for corrosion; may need logic board repair
02XXXX – 05XXXX RAM test failure Try different SIMMs; clean SIMM slots
0DXXXX NuBus card failure Remove all NuBus cards
0EXXXX SCSI controller failure Check for capacitor damage
0FXXXX Data bus failure Logic board damage
See Sad Mac Error Codes for complete reference.
Video Problems
Display Issues
No video after chime VRAM failure, cable issue Reseat VRAM; check video cable and monitor
Distorted or garbled VRAM configuration, bad VRAM Ensure matching VRAM SIMMs; try removing VRAM upgrade
Wrong colors VRAM issue, video DAC Reseat VRAM; check for capacitor damage
Flickering Loose cable, monitor issue Check video cable; test with different monitor
Audio Problems
Sound Issues
No startup chime Audio circuit failure, capacitor damage Recap logic board
Distorted audio Failed capacitors Recap logic board
No audio through jack Jack issue, cable Test with different cable/speakers
SCSI and Storage
Drive Problems
Flashing question mark No bootable System Check SCSI drive; verify cable; test with boot floppy
Drive not recognized Wrong SCSI ID, termination Verify unique SCSI IDs; check termination
System freezes during boot SCSI bus conflict Disconnect all SCSI; add one at a time
Floppy not reading Dirty heads, failed drive Clean heads; test with different disks
SCSI Termination
  • Internal drive should be terminated
  • If using external devices, terminate only the last device
  • Verify each device has a unique SCSI ID (0–6)
Capacitor Failure Symptoms
Symptom Likely Cause Solution
Random crashes Failed logic board caps Full logic board recap
Audio distortion Caps near audio circuit Recap logic board
No startup Power or reset circuit caps Recap; check traces
Intermittent operation Multiple failing caps Full recap
See Macintosh IIvi Capacitor Replacement Guide for procedures.
The Macintosh IIvi carries a 3.6 V 1/2AA lithium PRAM battery. These leak and can burst, spraying corrosive electrolyte across the logic board and destroying nearby components — often while the machine simply sits in storage. Remove the PRAM battery from any un-serviced unit. If one has leaked, neutralise and clean the residue and repair corroded traces and vias before troubleshooting.[1]
⚠️ Surface-mount capacitor leakage
The Macintosh IIvi logic board uses surface-mount electrolytic capacitors that leak with age and corrode the board; recap and clean the logic board as a first step, then recap the power supply.[2]
The desktop power supply uses electrolytic capacitors that fail with age. The classic symptoms are a machine that will rarely turn on, cannot be switched off without unplugging it, and clicks from the PSU when merely plugged in. Recap the power supply and confirm the +5 V and +12 V rails. (This PSU form factor is shared across the IIci, IIcx, IIvi, IIvx, Performa 600, Quadra 650 and Quadra 700.)[3]
  1. "Warning! Exploding Maxell PRAM Batteries", 68kMLA; and MacDat — Macintosh II family. Source for the leaking/exploding lithium PRAM battery that destroys nearby components.
  2. MacDat — Macintosh IIcx/II family; and 68kMLA recap threads. Source for the Mac II-family surface-mount electrolytic logic boards that leak and corrode with age and must be recapped.
  3. "Compact/Desktop Power Supply Capacitor Lists (by make and model)", 68kMLA; and "Capacitor Replacement in a Vintage Power Supply", Big Mess o' Wires. Source for the shared desktop PSU form factor (IIci/IIcx/IIvi/IIvx/Performa 600/Quadra 650/Quadra 700), the electrolytic failure symptoms and the PSU capacitor lists.
