Psion Organiser II Spare Parts List
Revision as of 11:34, 30 September 2026 by Josh (talk | contribs) (Add per-page contents table from the PDF; remove ParaLink (not in the document) and 'every capacitor's voltage and size' overstatement; note placement drawings and PARESA price list; add source link)
The Psion Organiser II Spare Parts List (version 3) is an 11-page spares document for the Psion Organiser II and several of its packs and peripherals. It gives Psion part numbers alongside the part numbers of PARESA, the distributor whose list it is, and pairs each board's parts list with a component placement drawing.[1]
Contents
Contents by page[1]
Page Contents
1 Exploded assembly diagram of the Organiser, with a numbered table of case mouldings, labels, keymat, LCD, connector strip, buzzer, screws and springs
2 "Revised Organiser Assembly": CE case mouldings, LCD window and display labels
3 Power supply board ("ORG PSU HAND ASSY", Psion 2000 0230): placement drawing and full parts list
4 Two-line CPU board spares kits (POS 200, XP multilingual, POS 296): placement drawing and parts list
5 LZ and LZ64 CPU board spares kits: placement drawing and parts list
6 Psion Printer II: mouldings, main printer board and mechanism
7 Comms Link (version 6 PCB): placement drawing and parts list
8 128K Datapak assembly
9 32K Rampak
10 Flashpak
11 PARESA price and stock list, in euros
Each board list gives the designator, value and tolerance of the resistors and chip capacitors, and the value, voltage rating, lead style (axial or radial) and size of the electrolytics.[1]
What it does not contain
It is a parts list. There is no schematic, no circuit description, no disassembly procedure and no fault-finding information.[1] The circuit is described in chapters 2 and 3 of the Psion Organiser II Technical Manual, transcribed on Jaap's Psion Organiser II Page; that manual uses different capacitor designators for the power supply board from this list.[2]
Pages that cite this document
Document
Download: Psion Organiser II Spare Parts List v3.pdf. The same file is on Jaap's Psion Organiser II Page.[1]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Psion, Organiser II Spare Parts List, version 3, 11 pages. Hosted on this wiki as File:Psion Organiser II Spare Parts List v3.pdf; also at Jaap's Psion Organiser II Page.
  2. ↑ Psion Organiser II Technical Manual, Psion Ltd, 1986, chapter 3 "Power Supply Board", transcribed at Jaap's Psion Organiser II Page.
