IBM System/23 Datamaster Maintenance Guide
This guide documents preventive maintenance for the IBM System/23 Datamaster (Model 5322 all-in-one desktop and Model 5324 tower variant), announced by IBM on 28 July 1981. The Datamaster's hardware is the direct architectural ancestor of the IBM PC (5150) and uses the same 9-bit parity DRAM, 62-pin expansion bus (with only 5 signals changed), 8253 PIT, 8259 PIC, capacitive Model F keyboard mechanism and Power Good signal. Restoration of a Datamaster is therefore closely related to PC-era practice — with two large exceptions: the 8-inch diskette drives belong to the older 5120 generation, and the power supply is ferroresonant, which is a different animal from either a linear supply or a PC switcher.
Safety
The 5322's supply is ferroresonant, and IBM prints its own DANGER notice about it:
- "Up to 800 Vac is generated in the power supply. Before removing the power supply or any power supply part, switch off the 5322 power and disconnect the power cable from the ac service outlet."[1]
That is eight hundred volts AC, generated inside a box that looks like an ordinary transformer supply. The layout names a resonant capacitor C6 and a tapped transformer with jumper-selected mains taps on terminal block TB1.[1] Descriptions of this supply as a bridge-and-series-pass-regulator linear design — including the one that used to be on this page — are wrong, and the difference is not academic.
- Power off and unplug at the wall.
- Discharge through a resistor and verify with a meter before touching anything.
- The supply has a service position: it slides out of the rear of the machine with two screws removed, and in that position the fuses, voltage test points and power switch are all accessible without disconnecting anything. If you intend to switch the machine on with the supply in the service position, IBM says to first confirm grounding continuity between the 5322 base plate and the power supply frame with a meter on the ohms range.[1]
- For the CRT, follow the CRT Discharge Procedure and discharge a second time a few minutes later.
- The diskette drives have their own hazard. Each drive has an AC drive motor with a mains-rated run capacitor, and IBM's warning is "High voltage may be present at the capacitor terminals." Its procedure is to remove the insulator caps and discharge the capacitor by shorting its terminals with an insulated screwdriver before disconnecting the motor leads.[1]
See also Recommended Tools and Battery Explosion, Capacitor or Corrosion Damage.
Documentation Set
The complete IBM service documentation set for the System/23 is preserved at Bitsavers:
- SY34-0171-0 — IBM 5322 Computer Service Manual, December 1980. The primary CE document; covers diagnostics, power supply, drives, board layouts, schematics. Indispensable for any Datamaster restoration.
- SY34-0241-1 — IBM 5324 Computer Service Manual, May 1982.
- 6841631 — System/23 Diagnostic User Guide, April 1982 (complete PID-1200 test ID list).
- SA34-0107-3 — System/23 Setup Instructions (5322), June 1982.
- ZA38-0016-0 — Commonly Used Systems Parts Handbook, July 1988 (p. 119 lists 5322 / 5324 motherboard parts).
Download all of these for any serious Datamaster work.
Opening the System Unit
Tools: Philips #2 screwdriver, T15 / T20 Torx, anti-static strap, high-voltage probe.
A distinctive feature of the 5322 chassis: both the power supply and the motherboard slide out from the rear without removing the main cover. This is unusual for the era and means most service operations can be performed without disturbing the integrated CRT cradle.
- Power off and unplug all cables (mains, keyboard, printer, communications, external diskette unit cable).
- Rear cover plate — held by Philips screws around the perimeter.
- Motherboard sled — slides out horizontally from the rear once retaining screws are removed.
- PSU sled — slides out similarly from a separate rear bay.
- The integrated 12-inch CRT and its deflection sub-chassis remain in the main chassis.
- Drive cage — accessed by removing the front bezel and lifting the drive sled.
The CRT is 12 inches, and that is now settled
IBM's own service manual states it: "The CRT display unit has a 305 mm (12 in.) video screen."[1] It displays 24 lines of 80 characters, 1,920 characters in total. This page previously hedged between 9 and 12 inches because no primary source had been checked; the manual is now hosted here and the question is closed.
One operating note from the same manual that is worth passing on to owners: do not run the machine with the brightness control fully clockwise for long periods — IBM says the display screen can be damaged.[1]
Detached Keyboard
The 5322's keyboard is a separate unit connecting to the system via a multi-pin cable:
- 83-key capacitive Model F (or rather, the pre-Model F mechanism — the Datamaster keyboard is often cited as the earliest production version of the design).
- Intel 8048 microcontroller inside the keyboard with Datamaster-specific firmware. Critical: the 8048's firmware is unique to the Datamaster — IBM PC keyboard 8048 firmware is not interchangeable. A failed 8048 means the keyboard cannot be made to work with another Datamaster unless you have a donor keyboard.
- Interface to the motherboard is parallel (driven by an 8255 PPI port). The IBM PC moved the same keyboard mechanism to a serial interface.
Inspecting the Chassis
Inspection items (in order):
- PSU bulk filter capacitors — visual check for bulging tops, leaked electrolyte, discolouration. Linear PSU caps at 40+ years old are the highest-likelihood failure point.
- Series-pass regulator transistors — heatsink-mounted; check thermal paste; replace if dried out.
- Memory daughter card decoupling caps — community references specifically flag these as failure points. A shorted decoupling cap on the RAM rails will brick the system; recommended triage is to remove the bypass caps as a first test before suspecting the RAM itself.
- Flyback / deflection board — inspect for cracked solder joints.
- Phosphor — check for burn-in.
- 8-inch floppy drive belts — perished urethane is the dominant failure on these drives.
- Spindle motor brushes — wear is common after 40+ years.
- Mostek MK36000 ROS modules — visually inspect for moisture damage / bulging package. These ROMs are a documented Datamaster failure mode.
- Keyboard 8048 — confirm operational before any other keyboard work.
Regular Cleaning
- Soft brush and low-pressure compressed air for the motherboard, ROS sockets, RAM daughter cards, drive bays, and PSU vents.
- Do not use compressed air over a leaking electrolytic — it spreads electrolyte across the board.
- Detach the keyboard for separate cleaning; wipe with slightly damp microfibre.
- Remove keycaps using the IBM tool (the Datamaster uses the same capacitive-Model-F mechanism that became the IBM PC AT / Model F keyboard).
- Clean 8-inch floppy heads with isopropyl alcohol on a foam swab (not cotton — cotton fibres in the head gap cause CRC errors).
- Inspect every diskette before reading. Old IBM 8-inch media may have lost binder integrity; if oxide is shedding, do not load.
Expected Measurements
Measure at the power supply A1 card. IBM says explicitly that its tolerances apply there and not elsewhere.[1]
| Voltage | Tolerance | Peak-to-peak ripple limit | Fuse |
| +5 Vdc | +4.6 to +5.5 V | 0.12 V | F5, 10 A |
| −5 Vdc | −4.6 to −5.5 V | 0.05 V | F1, 0.5 A |
| +12 Vdc | +11.0 to +13.2 V | 0.175 V | F2, 1.5 A |
| −12 Vdc | −11.0 to −13.2 V | 0.12 V | F3, 0.5 A |
| +24 Vdc | +22.0 to +26.4 V | 0.325 V | F4, 1.5 A |
| Power good | +2.4 to +5.5 V | 0 | — |
The symmetrical ±5 % table previously on this page was not IBM's and was wrong in both directions — it called a perfectly healthy −12.8 V rail a fault and would have passed a +24 V rail at +25.2 V that IBM allows up to +26.4 V.
There is a power-good LED on the supply itself, so the simplest possible first check needs no instrument at all.[1]
Measuring ripple without a scope
IBM publishes a method for exactly this, and it is the most useful thing in the chapter:[1]
- Connect a capacitor, 0.22 µF or larger, rated 50 Vdc or higher, in series with one meter lead. (IBM notes the capacitor is not supplied with the meter.)
- Set the meter range to 2.5 Vac.
- Connect one lead to the DC voltage in question and the other to frame ground, remembering the capacitor is in series.
- If the pointer leaves zero, excess ripple may be present.
Compare against the peak-to-peak limits in the table above. Ripple is the measurement that actually finds a tired supply; a rail can sit dead centre of its voltage band and still be unusable.
The fuses tell you where the fault is
Every DC output has its own fuse, which makes diagnosis unusually clean:[1]
- F5 blown (10 A, +5 V) — something is shorting the main logic rail.
- F4 blown (1.5 A, +24 V) — the diskette side: a spindle motor, a head load, or the drive cable.
- F2 or F3 (1.5 A / 0.5 A, ±12 V) — serial interface and drive logic.
- F1 (0.5 A, −5 V) — bias.
- F6 is the AC input fuse.
IBM's own check is continuity on the ohms RX1 range, using a fuse puller to remove them. Never replace a fuse with one of a higher rating — IBM's warning, and on a supply that generates 800 Vac internally it is worth taking literally.[1]
Three supplies, three mains-tap tables
PN 6838279 is the 60 Hz Canada and US supply. PN 6838280 is 60 Hz General Business Group/International and PN 6838281 is 50 Hz GBG/I; both of those select the mains voltage by jumpers on terminal block TB1, covering 100, 110, 120, 127, 200/208, 220, 230 and 240 V — and the two tables are not the same.[1] Check which supply you have and which taps are fitted before switching on an imported machine. IBM also notes that if the supply in a given 5322 carries a different part number, the labels on that supply govern, not the manual's diagrams.
ATX PSU Substitution (Bench-Test)
It is documented community practice to substitute a modern ATX PSU as a bench-test power source once the original Molex pinout is matched.[2] The +24 V rail must be supplied separately (an ATX supply does not include +24 V); restorers commonly use a small standalone +24 V brick for floppy spindle power.
This is suitable for board-level diagnostics but is not a permanent replacement — the integrated CRT deflection board requires the original PSU's +12 V and high-voltage primary feed.
8-Inch Floppy Drive Maintenance
The 5322 has 0, 1 or 2 × built-in 8-inch floppy drives (typically Shugart-class in IBM cosmetics). Maintenance:
- Drive belt — perished urethane. Modern replacements available from the 8-inch floppy restoration community.
- Head load solenoid — exercise; replace if fatigued.
- Spindle motor — brush wear is the main failure. Brushes can be re-sourced from industrial motor suppliers.
- Read / write head — clean with IPA on a foam swab.
- Head alignment — verify against a known-good diskette using the procedure in SY34-0171-0.
- Oxide shedding from old IBM media — inspect every diskette before loading. Do not load shedding diskettes.
Optional External Storage
- IBM 5246 Diskette Unit — external 1 or 2 × 8-inch floppy drive enclosure. Service procedures match the internal drives.
- IBM 5247 Winchester Disk Unit — 15.4 MB or 30.8 MB 8-inch hard drive. Has its own linear PSU and disk controller card. If the 5247 is shared between multiple Datamaster hosts, verify the host-selection cabling per the 5247 manual before any service work.
ROS Module Care
The motherboard carries 14 or 16 × 8 KB ROS modules. These are normally:
- Mostek MK36000 — most common; now a leading failure mode. Mostek mask ROMs of this era degrade with age. Symptoms: system halts mid-IPL or fails one or more PID-1200 ROS tests.
- Motorola 68366 — alternative; more reliable.
- Motorola 68766 EPROM — used on early-production boards because of supply shortages.
If a ROS test fails repeatedly, the canonical community workaround is a ROM-adapter card with re-burned firmware — restorer-published ROM images exist on the Vintage Computer Federation forums.
RAM Card Care
The 5322 RAM lives on one or two memory daughter cards via 36-pin card-edge connectors. Cards come in 32 KB and 64 KB sizes. Combinations:
- 32 KB total — 32 KB card in base slot
- 64 KB total — 64 KB card in base slot, or two 32 KB cards
- 96 KB total — 64 KB + 32 KB
- 128 KB total — 64 KB + 64 KB
The base slot must always be populated — the system will not boot without it.
The DRAMs are TMS4132 — TI's factory-piggybacked variant of the TMS4116, with two TMS4116-class dies stacked in a single package. This is often mistaken for IBM-soldered redundancy; it is a TI factory part. Failure of either die kills the byte — to bench-test a TMS4132 you must physically separate the upper die from the lower die. This is normally not worth doing in a hobbyist restoration; replace the whole card with a known-good donor or modern reproduction.
Connector Care
- Keyboard cable — multi-pin proprietary; clean both sides with deoxidising contact cleaner.
- Serial port (USART) — current-loop or RS-232 depending on submodel; verify before connecting external equipment.
- Printer ports (up to two) — IBM-proprietary connector pinout per SY34-0171-0.
- External 5246 / 5247 cable — IBM-proprietary card-edge cable; clean and reseat both ends.
- Diagnostics probe port (rear) — 8-bit data plus probe power; cleaned only when in use with a service-engineer probe.
Recommended Tools
- Philips #2 and T15 / T20 Torx screwdrivers.
- Anti-static strap.
- Digital multimeter, plus a 0.22 µF / 50 V capacitor for IBM's ripple check.
- A high-voltage probe for the CRT. IBM publishes no anode voltage for this tube; the "12–15 kV" figure that used to be on this page had no source and has been removed. Treat it as lethal regardless.
- High-voltage probe for CRT discharge.
- IPA + foam swabs.
- Soldering iron (fine tip) + solder wick.
- Modern 8-inch floppy drive belt replacement.
- IBM keycap removal tool (same as Model F PC AT keyboard).
- SY34-0171-0 PDF.
- Service probe with 8-bit LED display (build instructions in SY34-0171-0).
- Modern ROM adapter for replacing failed Mostek MK36000 ROS modules (community-built).
Related Pages
- IBM System/23 Datamaster
- IBM System/23 Datamaster Troubleshooting Guide
- IBM System/23 Datamaster Capacitor Replacement Guide
- IBM 5120 Maintenance Guide — predecessor with related linear PSU caveats
- IBM 5322 Computer Service Manual · IBM System 23 Diagnostic User Guide — both hosted here
- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 IBM, IBM 5322 Computer Service Manual, SY34-0171-0, December 1980 — hosted on this wiki as IBM 5322 Computer Service Manual. Chapter 2: items 1200 (locations), 1210 (AC voltage distribution for supplies PN 6838279, 6838280 and 6838281, with the mains-tap jumper tables), 1211 (DC voltage distribution, IBM's voltage tolerance and peak-to-peak ripple table, and the meter-and-capacitor ripple measurement method), 1212 (signal cable pin assignments), 1230 (CPU planar board and connector pin assignments), 1240/1250/1260 (power supply layout, showing resonant capacitor C6, terminal block TB1, the power-good LED and AC input fuse F6, with the "Up to 800 Vac is generated in the power supply" DANGER notice), 1241/1251/1261 (the F1 to F5 rail fuses and ratings) and 1270 (cooling fan). Theory of operation: the 5322 model numbering, the 305 mm (12 in.) CRT showing 24 lines of 80 characters, the 83-key keyboard, the brightness-control warning, and the standard and optional features. Chapter 5: items 1550 (AC drive motor) and 1551 (the drive motor run capacitor, with its own DANGER notice and discharge instruction).
- ↑ Bits Passats, "IBM System/23 Datamaster". A community restoration write-up built from a working machine; the source for the shorted decoupling capacitor triage on the memory daughter cards and for the bench-supply substitution practice. Community source, not an IBM document.
Further reading
- IBM 5322 Service Manual SY34-0171-0 (December 1980).
- System/23 Diagnostic User Guide 6841631 (April 1982).
- Bits Passats — IBM System/23 Datamaster. The most thorough community technical reference.
- oldcomputers.net — IBM 5322 System/23 Datamaster.
- Mark Blair (NF6X) — IBM 5322 System/23 Datamaster Internals. Restorer's hands-on photos and notes.
- Vintage Computer Federation — IBM System/23 Datamaster thread.
- VCFed — IBM 5322 ROM image thread.
