Atari 65XE
| File:Atari XE logo.svg | |
| File:Atari65XE.jpg | |
| Atari 65XE Home Computer | |
| Manufacturer | Atari Corporation |
| Type | Home Computer |
| Released | 1985 |
| Discontinued | 1992 |
| Intro price | US$120 (1985) |
| CPU | MOS Technology 6502C @ 1.79 MHz (NTSC) / 1.77 MHz (PAL) |
| Memory | 64 KB RAM, 16 KB ROM (BASIC, OS) |
| Storage | External cassette tape (410/1010), optional 5.25" floppy disk drive (1050/XF551) |
| Display | 320ร192 pixels, 40ร24 text, 16 colours (ANTIC/GTIA) |
| Sound | POKEY: 4 voices, 8-bit, noise, envelope, keyboard scan |
| Dimensions | 34 cm ร 24 cm ร 7 cm |
| Weight | 1.7 kg |
| OS / Firmware | Atari BASIC (in ROM), Atari OS |
| Predecessor | Atari 800XL |
| Successor | Atari 130XE |
| Codename | Sweet-16 |
| Model no. | 65XE |
The Atari 65XE is an 8-bit home computer introduced by Atari Corporation in 1985 as part of the XE ("XL Enhanced") series. It maintained compatibility with the Atari 8-bit family while featuring a redesigned case and revised electronics, targeting the home computing and gaming market during the mid-1980s.
๐ง Architecture and Processor
At its core, the 65XE uses the MOS Technology 6502C microprocessor, a variant of the classic 6502, running at:
- 1.79 MHz (NTSC systems)
- 1.77 MHz (PAL systems)
The 6502C coordinates system operations and interfaces with Atariโs custom chips, including ANTIC (video), GTIA (graphics), POKEY (sound and I/O), and PIA (peripherals).
๐พ Memory and Storage
The Atari 65XE is equipped with:
- 64 KB RAM
- 16 KB ROM, comprising:
- 10 KB for the operating system (OS)
- 6 KB for Atari BASIC (Revision C)
Storage options include:
- Cassette tape drive (Atari 410/1010)
- 5.25" floppy disk drive (Atari 1050, XF551)
- Cartridge slot for instant program loading
๐ฅ๏ธ Display and Graphics
Video output is managed by the ANTIC and GTIA chips, providing:
- Resolution up to 320ร192 pixels
- Text display: 40 columns ร 24 rows
- 16 colours (palette from 256 possible hues/luminances)
- Multiple graphics modes (ANTIC modes 2โ15), hardware vertical/horizontal scrolling
- Hardware sprites ("player/missile graphics") for smooth animation
The XE series supports composite and RF video output for connection to TVs and monitors.
๐ Sound Capabilities
Audio is generated by the POKEY chip, offering:
- 4 independent audio channels (voices), each 8-bit
- Programmable frequency, noise, and envelope control
- Keyboard scanning and serial I/O support
- Capable of complex sound effects and simple music synthesis
๐ฎ Input/Output and Expansion
The 65XE provides a range of I/O ports:
- Cartridge slot โ for software and hardware expansions
- SIO (Serial Input/Output) port โ connects to disk drives, printers, modems, and other peripherals
- Two joystick ports โ compatible with Atari-standard controllers
- Composite and RF video outputs โ for TV/monitor connection
- Parallel bus (internal, not user-accessible) for memory upgrades and peripherals
The XE series dropped the XLโs parallel bus connector, limiting some expansion options compared to earlier models.
๐ PCB Schematics & Service Manual
The Atari 65XE features a compact mainboard integrating the 6502C CPU, ANTIC, GTIA, POKEY, and RAM/ROM ICs. Service documentation and schematics are essential for repair and restoration.
| Logic Board | Schematic Diagrams |
- For full service documentation, see the Atari 65XE Service Manual and Atari 8-bit Family Schematics.*
๐ท Gallery
Atari 65XE front view
Rear panel with I/O ports
65XE motherboard (top view)
Atari XE series (65XE, 130XE)
