Atari 65XE
Atari 65XE
Atari 65XE Home Computer
ManufacturerAtari Corporation
TypeHome Computer
Released1985
Discontinued1992
Intro priceUS$120 (1985)
CPUMOS Technology 6502C @ 1.79 MHz (NTSC) / 1.77 MHz (PAL)
Memory64 KB RAM, 16 KB ROM (BASIC, OS)
StorageExternal cassette tape (410/1010), optional 5.25" floppy disk drive (1050/XF551)
Display320ร—192 pixels, 40ร—24 text, 16 colours (ANTIC/GTIA)
SoundPOKEY: 4 voices, 8-bit, noise, envelope, keyboard scan
Dimensions34 cm ร— 24 cm ร— 7 cm
Weight1.7 kg
OS / FirmwareAtari BASIC (in ROM), Atari OS
PredecessorAtari 800XL
SuccessorAtari 130XE
CodenameSweet-16
Model no.65XE
The Atari 65XE is an 8-bit home computer introduced by Atari Corporation in 1985 as part of the XE ("XL Enhanced") series. It maintained compatibility with the Atari 8-bit family while featuring a redesigned case and revised electronics, targeting the home computing and gaming market during the mid-1980s.
๐Ÿง  Architecture and Processor
At its core, the 65XE uses the MOS Technology 6502C microprocessor, a variant of the classic 6502, running at:
  • 1.79 MHz (NTSC systems)
  • 1.77 MHz (PAL systems)
The 6502C coordinates system operations and interfaces with Atariโ€™s custom chips, including ANTIC (video), GTIA (graphics), POKEY (sound and I/O), and PIA (peripherals).
๐Ÿ’พ Memory and Storage
The Atari 65XE is equipped with:
  • 64 KB RAM
  • 16 KB ROM, comprising:
    • 10 KB for the operating system (OS)
    • 6 KB for Atari BASIC (Revision C)
Storage options include:
  • Cassette tape drive (Atari 410/1010)
  • 5.25" floppy disk drive (Atari 1050, XF551)
  • Cartridge slot for instant program loading
๐Ÿ–ฅ๏ธ Display and Graphics
Video output is managed by the ANTIC and GTIA chips, providing:
  • Resolution up to 320ร—192 pixels
  • Text display: 40 columns ร— 24 rows
  • 16 colours (palette from 256 possible hues/luminances)
  • Multiple graphics modes (ANTIC modes 2โ€“15), hardware vertical/horizontal scrolling
  • Hardware sprites ("player/missile graphics") for smooth animation
The XE series supports composite and RF video output for connection to TVs and monitors.
๐Ÿ”Š Sound Capabilities
Audio is generated by the POKEY chip, offering:
  • 4 independent audio channels (voices), each 8-bit
  • Programmable frequency, noise, and envelope control
  • Keyboard scanning and serial I/O support
  • Capable of complex sound effects and simple music synthesis
๐ŸŽฎ Input/Output and Expansion
The 65XE provides a range of I/O ports:
  • Cartridge slot โ€“ for software and hardware expansions
  • SIO (Serial Input/Output) port โ€“ connects to disk drives, printers, modems, and other peripherals
  • Two joystick ports โ€“ compatible with Atari-standard controllers
  • Composite and RF video outputs โ€“ for TV/monitor connection
  • Parallel bus (internal, not user-accessible) for memory upgrades and peripherals
The XE series dropped the XLโ€™s parallel bus connector, limiting some expansion options compared to earlier models.
๐Ÿ” PCB Schematics & Service Manual
The Atari 65XE features a compact mainboard integrating the 6502C CPU, ANTIC, GTIA, POKEY, and RAM/ROM ICs. Service documentation and schematics are essential for repair and restoration.
Logic Board Schematic Diagrams
Atari 65XE Logic Board
File:Atari65XE Schematic.png
Atari 65XE Mainboard Schematic
For full service documentation, see the Atari 65XE Service Manual and Atari 8-bit Family Schematics.
