Sinclair ZX80
Revision as of 22:32, 24 September 2026 by Josh (talk | contribs) (Rebuild against Sinclair own circuit diagram (hosted here) and the sibling maintenance pages. Removed: a memory map giving the ROM as 8 KB when IC2 is a 4 KB 8332 and the infobox already said 4 KB; a ROM vector table including a floating-point calculator on a machine with integer BASIC only and a reset vector at 1C00 when a Z80 resets to 0000; a 44-way edge-connector pinout that gives ROMCS on pin 21 when /ROMCS does not exist on the ZX80 bus at all; a board-revision table for Issue 1 and Iss...)
Sinclair ZX80
Sinclair ZX80 logic board. Twenty-two ICs, all standard parts — there is no ULA on this machine
ManufacturerScience of Cambridge Ltd (later Sinclair Research Ltd)
TypeHome computer, sold as a kit or ready-built
ReleasedJanuary 1980
Discontinued1981 (superseded by the ZX81)
Intro price£79.95 kit, £99.95 ready-built
CPUZ80-class processor (Sinclair's diagram marks IC1 "780-1"), clocked at 3.25 MHz — the 6.5 MHz oscillator X1 divided by two
Memory1 KB static RAM — two 2114 chips at IC3 and IC4. Expandable through the rear edge connector
StorageExternal cassette recorder through 3.5 mm EAR and MIC jacks
DisplayMonochrome RF to a television. The display blanks while a program runs — this is normal, not a fault
SoundNone
PowerExternal unregulated DC adaptor through a 3.5 mm mono jack, centre pin positive. Nominal 9 V; Sinclair's diagram marks the input "9 V – 11 V"
OS / Firmware4 KB Sinclair integer BASIC in mask ROM (IC2, an 8332)
SuccessorSinclair ZX81
Model no.ZX80
The Sinclair ZX80 is an 8-bit home computer sold from January 1980 by Science of Cambridge, the company that became Sinclair Research. It was sold as a kit at £79.95 and ready-built at £99.95, and it was the first computer most people in Britain could imagine buying.
Sinclair published no service manual for it. What exists is the circuit diagram, which is hosted on this wiki, plus trade servicing articles from the period and the community archives. Every figure on the ZX80 pages here is traced to one of those; where nothing could be traced, the figure has been removed rather than guessed at.[1]
For servicing see Sinclair ZX80 General Maintenance, Sinclair ZX80 Troubleshooting Guide and Sinclair ZX80 Capacitor Replacement Guide.
What the ZX80 actually is
Three things distinguish it from the machines that followed, and all three matter when repairing one:[1][2]
  • There is no ULA. The ZX80's logic is ordinary 74LS parts. Sinclair combined them into a single ULA to make the ZX81 — so nothing on a ZX80 board can be diagnosed as "a failed ULA", and ZX81 repair advice does not transfer.
  • The RAM is static, two 2114 chips giving 1 KB. Because there is no DRAM there is no −5 V and no +12 V rail anywhere on the machine — the only rails are the incoming unregulated supply and the +5 V the regulator makes from it.
  • The video is generated by the processor. There is no display hardware in the modern sense; the Z80 emits sync and picture itself, which is why the screen blanks whenever BASIC is actually doing something.
The IC complement
From Sinclair's own circuit diagram:[1]
ZX80 integrated circuits
Ref Type Ref Type
IC1 780-1 (Z80 CPU) IC12 74LS00
IC2 8332 — 4 KB mask ROM IC13 74LS04
IC3 2114 RAM IC14 74LS05
IC4 2114-1 RAM IC15 74LS05
IC5 74LS373 IC16 74LS10
IC6 74LS157 IC17 74LS32
IC7 74LS157 IC18 74LS74
IC8 74LS157 IC19 74LS74
IC9 74LS166 IC20 74LS86
IC10 74LS365 IC21 74LS93
IC11 74LS00 IC22 7805 regulator
The regulator is IC22, not IC3. IC3 is a RAM chip. Getting this wrong is how people end up replacing memory on a machine with a power fault.[1]
Power
An external unregulated adaptor feeds a 3.5 mm mono jack, centre pin positive. It is the same size as the EAR and MIC sockets, so it is easy to plug into the wrong one. Nominal 9 V; about 14 V open-circuit; Sinclair's diagram marks the input "9 V – 11 V".[3][1]
Get the polarity right. A lead re-terminated the wrong way round is a known killer of the regulator on this family.[4]
Full detail, including what to check and in what order, is on the Sinclair ZX80 General Maintenance page.
Cassette, through 3.5 mm EAR and MIC jacks. There is no disc interface and Sinclair sold none for this machine.
Expansion
A rear edge connector carries the Z80 bus along with +5 V, +9 V and 0 V. The full pinout is printed on Sinclair's circuit diagram, and that is where to read it from — an earlier version of this page carried a pin-by-pin table that was not Sinclair's and is now removed.[1]
One difference from the ZX81 is worth knowing before you plug anything in: /ROMCS does not exist on the ZX80 bus. That input was added for the ZX81, so ZX81-era expansion hardware that relies on it will not behave the same way on a ZX80.[3]
Board revisions
No Sinclair-published list of ZX80 board issues has been found. Photographs of Issue 3 and Issue 3A boards are held in the Sinclair ZX Computers Archive, and that is the only board-issue evidence located.[5] Your board's issue number is silkscreened on it — work from what is in front of you.
An earlier version of this page carried a table of "Issue 1 (February 1980)" and "Issue 2 (late 1980)" boards with specific changes attributed to each: missing pull-ups on IC12, a resistor pack RP1 added, the board edge widened by 1 mm to fit Timex card guides. None of it could be traced to any source, and the IC12 claim contradicts Sinclair's own diagram, which shows IC12 as a 74LS00 rather than a video driver. The table has been removed.
Capacitors
There are exactly two electrolytics on the board: C8, 22 µF 16 V, across the unregulated input, and C10, 1 µF, in the power-on reset network. Everything else is ceramic and is not a service item.[1]
An earlier version of this page named "ageing electrolytic C5 (47 µF) on the video rail" as a cause of unstable picture. There is no C5 electrolytic, no 47 µF part and no video rail on this machine. See the Sinclair ZX80 Capacitor Replacement Guide.
Things that were on this page and should not have been
This page was rebuilt during a verification drive. The following were removed because they could not be traced to any source, and in several cases are contradicted by Sinclair's own circuit diagram:
  • A memory map giving the ROM as 8 KB at 0000–1FFF. The ZX80's ROM is 4 KB — IC2 is an 8332 — and the page's own infobox said so. The 8 KB figure belongs to the ZX81.[1]
  • A table of ROM entry points including a floating-point calculator at 03B5. The ZX80 runs integer BASIC and has no floating-point arithmetic at all. A "reset" vector at 1C00 is equally impossible: a Z80 resets to 0000.
  • A 44-way edge connector pinout allocating signals in a tidy sequential run. Read the pinout off Sinclair's diagram instead. The table also gave /ROMCS on pin 21, and /ROMCS does not exist on this machine's bus.[3]
  • "CPU clock 3.25 MHz, ÷13 from a 13 MHz crystal" and "half the UK colour burst". The oscillator is 6.5 MHz and it is divided by two; the PAL colour burst is 4.43 MHz and has nothing to do with it.[1]
  • A "turbo crystal" modification claiming a 10 per cent speed gain from fitting a 3.58 MHz part. On a machine whose video timing is generated by the processor itself, changing the clock does not make it faster — it stops the television synchronising.
  • "Drill discreet vents" in the case as a remedy for overheating. Do not drill holes in a forty-five-year-old computer. If the regulator runs hot, that is what its heatsink is for; if it is too hot, look for a fault.
  • A "Woolmark-approved polyester" keyboard supplier story, a Guinness World Record, and a "SLOW token present in the ZX80 ROM". None of these could be traced anywhere.
Sinclair's ZX80 circuit diagram — the only technical document Sinclair published for this machine, and the source for every figure on this page.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Sinclair Research Ltd, ZX80 Circuit Diagram. Hosted on this wiki as File:Sinclair ZX80 circuit diagram.png. Source for the IC type list, the 4 KB 8332 ROM, the 2114 static RAM, the 7805 at IC22, the 6.5 MHz oscillator X1 divided by two, the supply rails, the two electrolytics C8 and C10, and the edge-connector pinout. This is the only Sinclair-published technical document located for the machine; Sinclair issued no service manual for the ZX80.
  2. ↑ Differences between ZX80, ZX81 and Timex 1000, The Sinclair ZX Computers Archive, k1.spdns.de. Secondary source: the ZX80's standard TTL logic was combined into one ULA for the ZX81, and the ZX80's display blanks while a program runs.
  3. ↑ 3.0 3.1 3.2 Sinclair ZX80 Connectors, The Sinclair ZX Computers Archive, k1.spdns.de. Secondary source: connector types, supply polarity and open-circuit voltage, and the absence of /ROMCS from the ZX80 bus.
  4. ↑ "Servicing Sinclair Computers, Part 2", Television magazine, 1986. Trade servicing article covering the ZX80 and ZX81 family, mirrored in the Sinclair ZX Computers Archive at k1.spdns.de. Secondary source: reverse-polarity damage and handling practice.
  5. ↑ Sinclair ZX80 — PCB, The Sinclair ZX Computers Archive, k1.spdns.de: photographs of ZX80 Issue 3 and Issue 3A boards. Secondary source; the only board-issue evidence located.
