Macintosh Performa 5300CD
Revision as of 12:23, 10 February 2026 by Josh (talk | contribs) (Fix image: use Performa 5200 image (same case design))
ReleasedOctober 17, 1995
DiscontinuedMay 1996
CPUPowerPC 603e @ 100 MHz
Memory8–16 MB RAM (expandable to 64 MB)
Storage1.2 GB IDE hard drive, 4X CD-ROM, 1.44 MB floppy
Display15" shadow mask CRT (640×480 at 16-bit, 832×624 at 8-bit)
Sound8-bit stereo, PlainTalk microphone
Dimensions17.5" H × 15.1" W × 16.0" D
Weight47 lbs (21.3 kg)
OS / FirmwareSystem 7.5.1 – Mac OS 9.1
PredecessorPerforma 5200CD
SuccessorPerforma 5400CD
CodenameTrailblazer, Bongo, Rebound, Transformer, Cordyceps (logic board)
The Macintosh Performa 5300CD is an all-in-one personal computer released by Apple Computer on October 17, 1995.[1] It was sold as part of Apple's Performa consumer line and featured a built-in 15" shadow mask color display. The system was based on the Power Macintosh 5300/100 LC, its educational counterpart sold in North America.[2]
The Performa 5300 series shares the same logic board design (codenamed "Cordyceps") as the Performa 5200CD, based on the older LC architecture with a 40 MHz system bus and 32-bit memory path despite the 603e being a 64-bit processor.[3]
Model Variants
The Performa 5300 series includes two variants sharing the same logic board:
Model CPU Speed Markets Introduced Discontinued
Performa 5300CD 100 MHz Worldwide October 1995 May 1996
Performa 5320CD 120 MHz Europe, Asia November 1995 August 1996
The Performa 5320CD additionally included TV/video input and output cards pre-installed.[4]
A Director's Edition variant of the 5300CD was sold in Europe and Australia with additional bundled software.
The Performa 5300CD uses a PowerPC 603e processor running at 100 MHz with an integrated FPU. The processor communicates over a 40 MHz system bus with a 64-bit data path, though the memory subsystem operates at 32-bit width due to the LC-derived architecture.
Component Specification
CPU PowerPC 603e @ 100 MHz
FPU Integrated
L1 Cache 32 KB
L2 Cache 256 KB
System Bus 40 MHz
Data Path 64-bit (32-bit memory path)
Memory and Storage
RAM Configuration
The system shipped with 8 MB or 16 MB of RAM depending on configuration. Two 72-pin SIMM slots accept 80 ns or faster memory modules, allowing expansion to a maximum of 64 MB using 4, 8, 16, or 32 MB SIMMs.[5]
ROM and System Software
The system contains 4 MB of ROM. It shipped with System 7.5.1 and System Enabler 406, supporting up to Mac OS 9.1.
Storage Systems
Device Specification
Hard Drive 1.2 GB IDE
CD-ROM 4X internal
Floppy 1.44 MB 3.5" (manual inject)
External SCSI DB-25 connector
The internal hard drive connects via an 8-bit IDE controller. External SCSI devices connect through the DB-25 port on the rear of the system. The system does not provide SCSI termination power; external devices must supply their own.
Display and Graphics
The built-in 15" shadow mask RGB display supports:
Resolution Color Depth
640 × 480 16-bit (thousands of colors)
800 × 600 8-bit (256 colors)
832 × 624 8-bit (256 colors)
Video uses 1 MB of system RAM dedicated to display functions. This allocation remains fixed regardless of total system RAM. An optional LC PDS video card can provide a secondary display output via DB-15 connector.
Audio Capabilities
The Performa 5300CD supports 8-bit stereo sound playback. Audio input uses a PlainTalk-compatible microphone jack with 16-bit mono recording at line level (100 mV RMS average, 1.8 V RMS maximum, 100 kΩ impedance).
The Performa 5260CD, despite its lower model number, shipped later with a newer logic board design supporting 16-bit stereo playback.
Input/Output and Expansion
Port Configuration
Port Connector Notes
ADB Mini-DIN 4 Keyboard and mouse
Serial (Printer) DIN-8 Disabled when comm slot Ethernet installed
Serial (Modem) DIN-8 Disabled when comm slot modem installed
SCSI DB-25 External devices
Audio In 3.5mm PlainTalk compatible
Audio Out 3.5mm Headphone/speaker
The serial ports do not support hardware handshaking on most units, which limits modem speeds. Only the final logic board revision added hardware handshaking support. Global Village Teleport Platinum modems implement handshaking internally, bypassing this limitation.
Expansion Slots
Slot Purpose
LC PDS 32-bit expansion cards, video output
Comm Slot Internal modem or Ethernet
TV Tuner Apple TV Tuner Card
Video I/O Video input and output cards
10Base-T Ethernet was available as an option through the comm slot.
Known Issues
The Performa 5300 series, along with the related 5200 and 6200/6300 series, has documented reliability and performance issues:
  • Limited IDE controller (8-bit) reduces hard drive throughput
  • LC-derived architecture bottlenecks the 603e processor
  • Serial port limitations affect high-speed modem compatibility
  • Network stability issues resolved by Open Transport 1.2 (Mac OS 8)
  • Installing a SCSI terminator on an unused SCSI port improves network stability
Third-party hard drive utilities such as FWB HD Toolkit provide better IDE drive performance than Apple's HD SC Setup.
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh Performa 5300CD General Maintenance page.
The Macintosh Performa 5300CD features two main PCBs: the Logic Board (Cordyceps) and Analog Board.
Apple Service Manual
The official Apple Service Source manual covers both the Performa 5200 and 5300 series:
Detailed capacitor replacement guidelines for both analog and logic boards can be found on the Macintosh Performa 5300CD Capacitor Replacement Guide page.
Retrobrite
A comprehensive troubleshooting guide addressing no power, chime but no video, intermittent operation, Sad Mac errors, and floppy drive problems is available on the Macintosh Performa 5300CD Troubleshooting page.
Sub-system Specification (Macintosh Performa 5300CD, 1995)
Bus width 64-bit data path • 32-bit memory
ROM 4 MB
RAM 8–16 MB (expandable to 64 MB)
Video 640 × 480 @ 16-bit, 832 × 624 @ 8-bit
VRAM 1 MB (system RAM)
Sound 8-bit stereo output, 16-bit mono input
Disks 1.2 GB IDE, 4X CD-ROM, 1.44 MB floppy
Ports ADB, Serial × 2, SCSI, Audio I/O
  1. Macintosh Performa 5300CD Specs, EveryMac.com—link(accessed 2026-02-10)
  2. Performa 5300CD, Low End Mac—link(accessed 2026-02-10)
  3. Macintosh Performa 5300, Apple Wiki—link(accessed 2026-02-10)
  4. Macintosh Performa 5320CD Specs, EveryMac.com—link(accessed 2026-02-10)
  5. Macintosh Performa 5300CD: Technical Specifications, Apple Support—link(accessed 2026-02-10)
