Macintosh Classic Capacitor Replacement Guide
Revision as of 22:32, 24 September 2026 by Josh (talk | contribs) (Rewrite. The single undifferentiated capacitor table gave CP1 and CP13 both as 220 uF 250 V with no mention of board variants - but Apple own parts list gives four power/sweep boards, 661-0597 and 661-0651 at 110 V and 661-0599 and 661-0652 at 220 V, and on a 220-240 V board CP1 is a single 220 uF 400 V part with CP13 fitted as a jumper. 240 V mains rectifies to about 340 V, so a 250 V part there fails. The shared power/sweep board now points at the Classic II guide which carries both variant...)
This guide covers capacitor replacement on the Macintosh Classic — the logic board, which is specific to this machine, and the power/sweep board, which is shared with the Macintosh Classic II and is documented in full on that machine's page.
Before you start
Take the battery out first. The 1/2 AA cell in this family leaks and the electrolyte destroys traces, in some cases beyond repair.[4] See Battery Explosion, Capacitor or Corrosion Damage.
Then follow the CRT Discharge Procedure. The power/sweep board carries mains on its primary side and the tube holds charge after the machine is unplugged.
Capacitor inspection
The surface-mount electrolytics on the logic board rarely bulge. Look instead for:
  • Dark haloes or dried crust at the base of the cans.
  • Dull or green solder joints on nearby IC pins.
  • Thinned or missing traces, best seen under a loupe with light raking across the board.
Through-hole electrolytics on the power/sweep board do show the classic symptoms — domed tops, brown or white crust at the leads, staining on the board beneath them.
See Capacitor Failure Symptoms.
Logic board
Macintosh Classic logic board
Reference Capacitance Voltage Quantity
C1 – C7 47 µF 16 V 7
C8 1 µF 50 V 1
Eight capacitors in total. From Recap-a-Mac's photographic guide, made from a physical board.[4]
Note that this is not the Classic II's list. The Macintosh Classic II logic board is a different design with either 13 or 17 surface-mount electrolytics depending on revision; do not order a Classic II kit for a Classic.
Macintosh Classic logic board recapping guide. (Image: Recap-a-Mac)
Replacement parts
Recap-a-Mac uses solid tantalum at the same values on this board:[4]
  • 1 µF 50 V — KEMET T491B105K050AT
  • 47 µF 16 V — KEMET T491D476K016AT
Solid tantalum has no liquid electrolyte and cannot leak, which is the failure mode that does the damage here. It fails short rather than open, so derate generously: a part rated well above the rail it sits on is far less likely to be pushed into failure by a switch-on surge. A 25 V part in the 47 µF positions is a common and sensible choice on a 5 V rail.
Power/sweep board
This board is shared with the Macintosh Classic II, and the full treatment — separate 120 V and 240 V capacitor lists, the board part numbers 630-0395, 630-0420, 630-0525 and 630-0560, the differences between Console5's and Recap-a-Mac's counts, the PP1 output adjustment, and the DIP ICs IF1, QP1 and JP1 that also fail on these boards — is on the Classic II capacitor guide. It is not duplicated here, because a second copy of a safety-critical table is a second copy to get out of step.
What you need to know before you go there:
  • Read the part number off your board. 661-0597 and 661-0651 are the 110 V boards; 661-0599 and 661-0652 are the 220 V boards.[1]
  • If CP13 is a jumper rather than a capacitor, you have a 220–240 V board, and CP1 must be a 400 V part.
  • Apple's Service Source Electrical specification lists only 100–120 V AC, 47–63 Hz, 100 W maximum — it documents the US machine. The parts list in the same document is what reveals that a 220 V board exists.[1]
Replacement procedure
  1. Remove the battery.
  2. Discharge the CRT — see CRT Discharge Procedure.
  3. Label every cable, then remove the logic board and, if you are working on it, the power/sweep board.
  4. Desolder the old capacitors. On the logic board use hot air or a low-temperature technique; the pads lift easily on a board that has already been attacked by electrolyte.
  5. Clean the board. Isopropyl alcohol and a soft brush, then inspect under magnification for thinned or broken traces near every capacitor position. Repair those before fitting anything new.
  6. Fit the replacements with the correct polarity. Check twice on tantalum — a reversed tantalum fails short and takes the rail down with it.
  7. Inspect the joints under magnification, trim the leads, and check for shorts across every rail with a meter before applying power.
After the recap
Apple publishes no rail voltages or tolerances for this machine, and no power-supply adjustment procedure. The Macintosh Classic / Classic II / Performa 200 Service Source hosted on this wiki gives only the mains side in its Electrical specification, and its Adjustments chapter covers video and yoke only — light meter setup, cutoff, brightness and contrast, centring, size and focus.[1]
What you can check is that the rails sit inside the range the logic on the board is specified for. Five-volt logic is specified for a 5 V supply at ±5 per cent, which gives 4.75 V to 5.25 V. Treat anything outside that as a fault, and anything that sags under load or carries visible ripple as a fault regardless of what the DC reading says. Compare against a known-good example of the same model where you can.
Measure at the floppy drive or logic board power connector.
Recap-a-Mac reports that the output voltage on this board can be adjusted with the variable resistor PP1, which is not something Apple documents.[3]
What not to do
  • Do not "power the machine up periodically to keep the capacitors healthy". That advice circulates widely and it is the wrong way round for this machine: powering up a Classic with leaking surface-mount electrolytics drives electrolyte further into the board and turns a recap into a trace-repair job. Recap it, then use it. Regular use after that is fine.
  • Do not fit a 250 V part at CP1 without confirming you have a 110 V board. See the warning at the top.
  • Do not increase capacitance because bigger sounds better. On the power/sweep board it changes the inrush the rectifier sees.
  • Temperature-controlled soldering iron with a fine tip; hot air is easier on the logic board.
  • Desoldering braid and a pump.
  • Leaded solder, 0.5 mm.
  • Isopropyl alcohol, a soft brush and a loupe.
  • Multimeter.
  • A CRT discharge tool — see Recommended Tools.
  1. ↑ 1.0 1.1 1.2 1.3 Apple Computer, Macintosh Classic / Classic II / Performa 200 Service Source, hosted on this wiki as File:Macintosh Classic - Classic II.pdf. Specifications (Electrical: 100–120 V AC, 47–63 Hz single phase, 100 W maximum); Adjustments (Video and Yoke only — there is no voltage adjustment procedure); and the Exploded View parts list, which gives the power/sweep board as 661-0597 (110 V Rev. A), 661-0599 (220 V Rev. A), 661-0651 (110 V Rev. B) and 661-0652 (220 V Rev. B). Apple's Service Source is module-level throughout: procedures, thresholds and field-replaceable-unit numbers, never component values.
  2. ↑ Console5 TechWiki, "Mac Analog Board: 630-0560" — wiki.console5.com. Publishes separate 120 V and 240 V lists for this board, including CP1 at 250 V versus 400 V and CP13 as a jumper on the 240 V board. Secondary source: a vendor capacitor-kit list compiled from physical boards, not Apple documentation.
  3. ↑ 3.0 3.1 Bruce / Recap-a-Mac, "Macintosh Classic I + II Analog Board (220V – 240V version)" — recapamac.com.au. Independently photographed from a 240 V board: one 220 µF 400 V part and no 250 V electrolytic anywhere on the board; the PP1 output adjustment; and the IF1, QP1 and JP1 DIP IC failures. Secondary source.
  4. ↑ 4.0 4.1 4.2 Bruce / Recap-a-Mac, "Macintosh Classic" — recapamac.com.au. The logic board capacitor list photographed from a physical board, the 1/2 AA battery failure mode, and the KEMET tantalum part numbers. Secondary source.
