Amstrad NC150 Troubleshooting Guide
Revision as of 03:02, 2 October 2026 by Josh (talk | contribs) (New page: NC150 power and display checks from the NC100/NC150 power diagram)
The Amstrad NC150 shares the NC100's case and, in Hans-Jürgen Böhling's NC100/NC150 power supply diagram, its power circuit, so the power and display checks on the Amstrad NC100 Troubleshooting Guide apply to it.[1]
The flat case shared by the NC100 and NC150
Power
NC150 power faults
Symptom Probable cause Action
Dead on batteries and adaptor Software lock-up, F301, switch-on circuit Remove all power and drain as in the NC100 guide (this erases memory), then check F301 with the case open
Works on one source only Flat or reversed AA cells and contacts; adaptor, lead or socket Fit fresh cells; check the adaptor against the 6 V DC input on Böhling's diagram
Low-battery warnings Main cells or lithium cell low Böhling's diagram shows warnings for four AA cells below 4.2 V and 3.2 V and for the lithium cell below 2.3 V; replace the cell concerned
Memory lost after a battery change Lithium cell dead or all sources removed together Replace the lithium cell; restore files from a card
Sources: Böhling's power diagram[1] and Nixon's lock-up recovery for the NC100.[2] Nixon gives different thresholds from Böhling for the same signals; both are set out on the Amstrad NC100 Troubleshooting Guide.
The reset keys (Function, Stop and ←Del held while switching on) are documented for the NC100, where the reset erases the memory but not a memory card.[3] Back up to a card before trying them on an NC150.
Display
The display supply is the −15 V output of the DC/DC converter on Böhling's NC100/NC150 diagram, and the display joins the main board through a flat cable on the NC100.[1] A blank or faint screen on a working machine calls for the same checks as on the NC100: the brightness control on the right-hand edge, the flat cable, then the LCD supply.[4]
Software
The NC150's ROM is twice the size of the NC100's and adds a spreadsheet and a falling-blocks game.[2]
  1. ↑ 1.0 1.1 1.2 Hans-Jürgen Böhling, A Surgical Guide To The Amstrad Notepad Computer. Community document, hosted as File:Amstrad NC100 Surgical Guide.pdf, described at Amstrad NC100 Surgical Guide. The "NC100/NC150" power supply diagram (6 V DC input, F301, DC/DC converter, +5 V, lithium-backed 5VBK and −15 V LCD supplies, battery-level detector) and the NC150's ROM and RAM.
  2. ↑ 2.0 2.1 Robin Nixon and Chris Nixon, The Amstrad Notepad Advanced User Guide (Sigma Press, 1993), pp. 187–188 (lock-up recovery on the NC100) and p. 247 (the NC150). Scan at archive.org. Retrieved 2026-10-02.
  3. ↑ Amstrad plc, Amstrad Notepad Computer user manual (NC100), resetting, p. 60. Hosted as File:Amstrad Notepad Computer User Manual.pdf, described at Amstrad Notepad Computer User Manual.
  4. ↑ Amstrad plc, Amstrad Notepad Computer user manual (NC100), setting up p. 2 (brightness control). Hosted as File:Amstrad Notepad Computer User Manual.pdf.
