Atari SC1224 Capacitor Replacement Guide
The Atari SC1224 was built by JVC, Goldstar and Samsung, and each version has its own boards and capacitor list.[1] Service manuals survive for two of them: the Goldstar set on the CA-3 chassis and the JVC set that Atari calls Version 2. No parts list for the Samsung set has been found.
The monitor has a colour CRT with an anode supply of 22 to 23 kV and mains-connected primary circuits. Unplug it, discharge the CRT as described in CRT Discharge Procedure, and treat the power board as live until the reservoir capacitor has been measured at a safe voltage. Goldstar's manual requires an isolation transformer between the monitor and the mains when the chassis is serviced powered.[2]
Which version is it?
The Version 2 board set is marked MA-1018A and has the brightness control on the back panel with the hold, height and position controls.[3][4] The CA-3 chassis has brightness and contrast at the front or side with the on/volume knob, and V-LIN, V-SIZE, V-HOLD, H-POSITION and H-HOLD at the back.[5] The photographs on the Atari SC1224 page show the two cases.
Goldstar CA-3 chassis
Atari's CA-3 parts list gives every capacitor on the main, CPT (CRT) and power boards. The tables below list the electrolytic, non-polarised electrolytic (BP) and tantalum parts. Values and part numbers are from the parts list; three printing errors are corrected from the CA-3 schematic and the part numbering, and each correction is noted.[6][7][8] Shaded parts are, in Atari's words, components with "special characteristics important to safety"; replace them with the same type.[6]
| Ref | µF | Voltage | Type | Atari part no. | Notes |
| C302 | 22 | 16 V | Electrolytic | 08110315 | |
| C304 | 22 | 16 V | Electrolytic | 08110315 | |
| C305 | 22 | 16 V | Electrolytic | 08110315 | |
| C306 | 22 | 16 V | Electrolytic | 08110315 | |
| C307 | 100 | 16 V | Electrolytic | 08110319 | |
| C308 | 1 | 50 V | Non-polarised (BP) | 181-064R | |
| C312 | 22 | 16 V | Electrolytic | 08110315 | |
| C314 | 22 | 16 V | Electrolytic | 08110315 | |
| C315 | 22 | 16 V | Electrolytic | 08110315 | |
| C316 | 22 | 16 V | Electrolytic | 08110315 | |
| C317 | 100 | 16 V | Electrolytic | 08110319 | |
| C318 | 1 | 50 V | Non-polarised (BP) | 181-064R | |
| C322 | 22 | 16 V | Electrolytic | 08110315 | |
| C324 | 22 | 16 V | Electrolytic | 08110315 | |
| C325 | 22 | 16 V | Electrolytic | 08110315 | |
| C326 | 22 | 16 V | Electrolytic | 08110315 | |
| C327 | 100 | 16 V | Electrolytic | 08110319 | |
| C328 | 1 | 50 V | Non-polarised (BP) | 181-064R | |
| C331 | 100 | 160 V | Electrolytic | 02140719 | |
| C332 | 330 | 16 V | Electrolytic | 02140322 | The A chart checks the 12 V supply at C332 |
| C333 | 22 | 16 V | Electrolytic | 08110315 | |
| C401 | 1 | 50 V | Electrolytic | 08110507 | |
| C402 | 220 | 16 V | Electrolytic | 02140321 | |
| C403 | 10 | 16 V | Electrolytic | 08110313 | |
| C404 | 10 | 16 V | Electrolytic | 08110313 | |
| C406 | 1000 | 16 V | Electrolytic | 02140325 | |
| C409 | 220 | 16 V | Electrolytic | 02140321 | |
| C601 | 220 | 16 V | Electrolytic | 02140321 | |
| C602 | 10 | 16 V | Electrolytic | 08110313 | |
| C607 | 0.47 | 50 V | Electrolytic | 08110505 | |
| C608 | 1 | 25 V | Tantalum | 181-032J | |
| C609 | 1000 | 25 V | Electrolytic | 02140425 | |
| C613 | 100 | 50 V | Electrolytic | 02140519 | |
| C614 | 100 | 50 V | Electrolytic | 02140519 | |
| C616 | 220 | 25 V | Electrolytic | 02140421 | |
| C617 | 3.3 | 25 V | Non-polarised (BP) | 181-098A | |
| C618 | 47 | 25 V | Electrolytic | 08110417 | |
| C621 | 10 | 25 V | Electrolytic | 08110413 | |
| C703 | 1000 | 16 V | Electrolytic | 02140325 | The parts list prints 100 µF; the schematic shows 1000/16, and the part number is the same as C406 |
| C707 | 1 | 50 V | Electrolytic | 08110507 | |
| C709 | 1 | 50 V | Electrolytic | 08110507 | |
| C713 | 2.2 | 160 V | Electrolytic | 08110709 | The C-1 chart checks for 23 V at C713 |
| C719 | 33 | 50 V | Electrolytic | 08110516 | Shaded (safety) part in the parts list |
| C721 | 2200 | 35 V | Electrolytic | 181-081H | Shaded (safety) part in the parts list |
| C724 | 10 | 160 V | Electrolytic | 02140713 | Shaded (safety) part in the parts list |
| C726 | 3.3 | 25 V | Non-polarised (BP) | 181-098A | |
| C727 | 3.3 | 25 V | Non-polarised (BP) | 181-098A | |
| C728 | 220 | 16 V | Electrolytic | 02140321 | |
| C729 | 100 | 16 V | Electrolytic | 08110319 | |
| C734 | 33 | 16 V | Electrolytic | 08110316 | Shaded (safety) part in the parts list |
| C735 | 1 | 160 V | Electrolytic | 08110707 | Shaded (safety) part in the parts list |
| C736 | 220 | 160 V | Electrolytic | 181-134A | |
| C737 | 1000 | 25 V | Electrolytic | 02140425 | |
| C739 | 3.3 | 25 V | Non-polarised (BP) | 181-098A | |
| C740 | 33 | 160 V | Electrolytic | 181-102A | |
| C741 | 1000 | 25 V | Electrolytic | 02140425 | Shaded (safety) part in the parts list |
| C501 | 10 | 16 V | Electrolytic | 02110313 | |
| C504 | 10 | 16 V | Electrolytic | 02110313 | |
| C507 | 10 | 16 V | Electrolytic | 02110313 | |
| C511 | 10 | 160 V | Electrolytic | 02140713 | |
| C512 | 1 | 160 V | Electrolytic | 02110707 | |
| C513 | 1 | 160 V | Electrolytic | 02110707 | |
| C514 | 1 | 160 V | Electrolytic | 02110707 |
| C950 | 120 | 400 V | Electrolytic | 181-124G | Mains reservoir after the bridge BD901 |
| C951 | 10 | 100 V | Electrolytic | 02140613 | |
| C952 | 10 | 50 V | Electrolytic | 02140513 | |
| C961 | 1000 | 25 V | Electrolytic | 02140425 | 14 V output filter. The parts list prints "1000pF"; the schematic shows 1000/25V and the part number is the same as C609 |
| C963 | 1000 | 25 V | Electrolytic | 02140425 | 12 V output filter. The parts list prints "1000pF"; the schematic shows 1000/25V |
| C965 | 100 | 160 V | Electrolytic | 02140719 | 115 V output filter. The parts list prints "100pF"; the schematic shows 100/160V and the part number is the same as C331 |
That is 61 polarised electrolytics, seven non-polarised electrolytics (C308, C318, C328, C617, C726, C727 and C739) and one tantalum (C608) on the three boards.
The power board also carries film and ceramic capacitors that are not in these tables. C956 is a 0.047 µF 800 V polypropylene part; C901 and C902 are Panasonic ECQ-E2A104MW metallised polypropylene parts and C904, C905, C957 and C958 are safety ceramic parts, all shaded.[7] One owner of a dead SC1224 found C950, C961 and a capacitor numbered C966 leaking and heat damage on C956.[9] C966 does not appear in the CA-3 parts list, so that monitor may have had a different power board. On the main board the horizontal retrace capacitors C715 (printed 472, 4.7 nF, 1600 V), C716 (222, 2.2 nF, 1600 V) and C717 (102, 1 nF, 1250 V) are shaded polypropylene parts.[6]
JVC Version 2
Atari's Version 2 parts list omits standard resistors and capacitors; it gives only the part-number code for a standard electrolytic of each voltage.[10] The values below are read from the schematic and the annotated circuit pages, with the parts list used where it gives the part.[4][11][12] Where the two disagree, both are given. The notes give the symptom Atari's circuit pages list for that part.[11]
| Ref | µF | Voltage | Type | Notes |
| C1002 | 3.3 | 16 V | Electrolytic | Clamp charge, red; open or short gives no red raster |
| C1003 | 3.3 | 16 V | Electrolytic | |
| C1004 | 3.3 | 16 V | Electrolytic | |
| C1005 | 100 | 25 V | Electrolytic | 12 V supply to IC1001 pin 16 |
| C1101 | 100 | 25 V | Electrolytic | |
| C1201 | 100 | 25 V | Electrolytic | |
| C1301 | 100 | 25 V | Electrolytic | |
| C1105 | 0.47 | 50 V | Non-polarised (BP) | Parts list 0.47 µF; the schematic prints "47/50 BP" |
| C1205 | 0.47 | 50 V | Non-polarised (BP) | As C1105 |
| C1305 | 0.47 | 50 V | Non-polarised (BP) | As C1105 |
| C1106 | 10 | 16 V | Electrolytic | Pedestal clamp; short gives no red raster, open gives a red raster |
| C1206 | 10 | 16 V | Electrolytic | |
| C1306 | 10 | 16 V | Electrolytic | |
| C1151 | 4.7 | 50 V | Non-polarised (BP) | Parts list 4.7 µF; the schematic prints 3.3/50 BP |
| C1251 | 4.7 | 50 V | Non-polarised (BP) | As C1151 |
| C1351 | 4.7 | 50 V | Non-polarised (BP) | As C1151 |
| C1152 | 3.3 | 50 V | Non-polarised (BP) | Input coupling |
| C1252 | 3.3 | 50 V | Non-polarised (BP) | |
| C1352 | 3.3 | 50 V | Non-polarised (BP) | |
| C1402 | 2.2 | 16 or 50 V | Tantalum or electrolytic (sources differ) | V oscillator; open or short gives a single horizontal line. Parts list: tantalum 2.2 µF 16 V; schematic: 2.2/50 E cap ±20% |
| C1403 | 470 | 16 V | Electrolytic | Vcc smoothing; short gives a single horizontal line |
| C1407 | 33 | 25 V | Electrolytic | |
| C1423 | 100 | 35 V | Electrolytic | Boost (IC1421) |
| C1424 | 470 | 25 V | Electrolytic | |
| C1425 | 470 | 35 V | Electrolytic | |
| C1427 | 1000 | 25 or 16 V | Electrolytic | Side pin compensation; short gives side pin distortion. Schematic 1000/25; the parts list gives 1000 µF 16 V, so a 25 V part covers both |
| C1429 | 470 | 16 V | Electrolytic | Side pin compensation; short gives side pin distortion |
| C1452 | 4.7 | 50 V | Electrolytic | Vertical blanking (Q1451) |
| C1502 | 4.7 | 50 V | Electrolytic | Noise filter on IC1501 |
| C1503 | 220 | 25 V | Electrolytic | |
| C1505 | 1 | 50 V | Electrolytic | H AFC smoothing; short gives faulty horizontal sync |
| C1508 | 100 | 16 V | Electrolytic | |
| C1522 | 1 | 160 V | Electrolytic | |
| C1523 | 33 | 160 V | Electrolytic | |
| C1530 | 10 | 25 V | Electrolytic | |
| C1531 | 470 | 25 V | Electrolytic | Filter after D1522, the 15 V (B2) rectifier |
| C1532 | 10 | 160 V | Electrolytic | HB rectifier |
| C1541 | 1 | 160 V | Electrolytic | Clamp; short shifts the raster to the right |
| C1551 | 1000 | 16 V | Electrolytic | Smoothing for the 16 V line |
| C1563 | 4.7 | 160 V | Electrolytic | HB regulator |
| C1564 | 10 | 160 V | Electrolytic | HB regulator |
| C1701 | 10 | 16 V | Electrolytic | B1 overvoltage detection; open gives no raster |
| C1702 | 100 | 25 V | Electrolytic | |
| C1703 | 10 | 35 V | Electrolytic | |
| C1807 | 33 | 25 V | Electrolytic | +15 V supply to IC1801 |
| C1904 | 470 | 200 V | Electrolytic | Mains reservoir after D1901-D1904; shaded (safety) part |
| C1905 | 1000 | 25 V | Electrolytic | Starter supply after D1905 |
| C1907 | 10 | 160 V | Electrolytic | Ripple filter (with R1906) |
| C1601 | 1 | 50 V | Electrolytic | Input coupling; short gives no sound |
| C1602 | 220 | 16 V | Electrolytic | |
| C1603 | 10 | 50 V | Electrolytic | Short gives no sound |
| C1604 | 10 | 50 V | Electrolytic | Open gives no sound |
| C1607 | 220 | 16 V | Electrolytic | |
| C1610 | 1000 | 16 V | Electrolytic | 16 V supply smoothing |
| C1081 | 100 | 25 V | Electrolytic | |
| C1311 | 4.7 | 160 V | Electrolytic | Schematic 4.7/160; the parts list gives 10 µF 160 V |
The Version 2 has nine non-polarised electrolytics, all in the RGB input and drive stages (C1105, C1151, C1152 and their green and blue equivalents). Fit bipolar parts there. An owner who recapped an SC1435 warns against fitting a polarised part in a non-polarised position.[13] The shaded film capacitors C1526 (7200 pF 1600 V) and C1534 (5600 pF 1600 V) set the horizontal retrace; Atari lists them as metallised polypropylene parts with a ±3 % tolerance.[12] An open C1526, C1534 or C1535 makes the picture narrow, and an open C1529 (the 0.3 µF 200 V S-correction capacitor) leaves a single vertical line.[11]
Procedure
- Unplug the monitor and remove the rear cover. On the Version 2 it is held by five screws.[14]
- Discharge the CRT anode to the chassis earth and keep a lead on it while working. See CRT Discharge Procedure.
- Measure the mains reservoir (C950 on the CA-3, C1904 on the Version 2) and discharge it through a resistor if it holds a charge.
- On the Version 2, remove the main board: two screws (B), two screws (C) and two screws (D), the bracket if needed, the anode lead and the other wires. Keep the CRT earth wire connected between the CRT socket board and the main board whenever the set is powered for checks, and coat the CRT socket with silicone grease if it is disconnected.[14]
- Replace one capacitor at a time. Match polarity to the board marking, keep at least the voltage in the tables, and fit bipolar parts in the BP positions.
- Fit shaded (safety) parts with the type the parts list gives.[6][10]
- While the board is out, inspect the solder side and resolder dry joints. A monitor repairer on Atari-Forum advises going over every joint before replacing parts.[15]
- Refit the board, reconnect the anode cap and the CRT earth, and run the checks below.
Checks after recapping
| Version | Point | Expected |
| CA-3 | Power board outputs P962, P961, P960 | 115 V, 12 V, 14 V[8] |
| CA-3 | FBT pin 7 and point A10 | 115 V[16] |
| CA-3 | Sound IC pin 1 and pin 9 | 12 V and 14 V[16] |
| CA-3 | CRT heater, H1 to H2 | About 6.3 V rms[16] |
| Version 2 | B1 line, IC1901 pin 4 | 125 V[17] |
| Version 2 | HB line | 120 V, set with HB ADJ R1570 after a 30-minute warm-up[18] |
| Version 2 | IC1421 pin 3 | 25.3 V[19] |
| Version 2 | IC1601 pins 7 and 9 | 11.8 V and 14.1 V[19] |
Goldstar's manual says the CA-3 has no high-voltage adjustment and that the 115 V supply must be correct for the high voltage to be correct; it gives 23.0 kV as the nominal anode voltage, 24.0 kV as the limit at zero beam current and 24.5 kV under any setting of the brightness control.[2][20] Measure the anode voltage only with a high-voltage probe made for it.
- ↑ "Atari SC1224 RGB Color Monitor", atari-computermuseum.de, https://www.atari-computermuseum.de/st_peri.htm#sc1224. Secondary source for the three manufacturers.
- ↑ 2.0 2.1 Atari, SC1224 RGB Color Monitor Service Manual, chassis CA-3, Safety Precautions (PDF p. 6). File:Atari SC1224 Service Manual (CA-3 chassis).pdf.
- ↑ Atari Corporation, SC1224 Version 2 Field Service Manual, C070433, February 1986, Functions, p. 4. File:Atari SC1224 Version 2 Field Service Manual C070433.pdf.
- ↑ 4.0 4.1 SC1224 Version 2 Field Service Manual, Schematic Diagram (PDF p. 32).
- ↑ SC1224 Service Manual (CA-3), Control Operation, printed p. 5 (PDF p. 7).
- ↑ 6.0 6.1 6.2 6.3 SC1224 Service Manual (CA-3), Replacement Parts List, main board capacitors, printed pp. 30-31 (PDF p. 21).
- ↑ 7.0 7.1 SC1224 Service Manual (CA-3), Replacement Parts List, CPT and power boards, printed p. 32 (PDF p. 22).
- ↑ 8.0 8.1 Atari, CA-3 Chassis Schematic Diagram, P/N 484-257A. File:Atari SC1224 CA-3 Chassis Schematic and Troubleshooting Charts.pdf, PDF p. 1. Source for C703 (1000/16), C961 and C963 (1000/25V), C965 (100/160V) and the output voltages.
- ↑ "Dead SC1224", Atari-Forum, posts by MaLICiouS, 26 March 2010. https://www.atari-forum.com/viewtopic.php?t=18975. Community report.
- ↑ 10.0 10.1 SC1224 Version 2 Field Service Manual, Replacement Parts List Information, p. 11.
- ↑ 11.0 11.1 11.2 SC1224 Version 2 Field Service Manual, annotated circuit pages, pp. 23-30.
- ↑ 12.0 12.1 SC1224 Version 2 Field Service Manual, Replacement Parts List, p. 12.
- ↑ "Atari SC1224", exxos's Atari, Amiga & retro forum, post by derkom, 21 May 2020. https://www.exxosforum.co.uk/forum/viewtopic.php?t=2803. Community report.
- ↑ 14.0 14.1 SC1224 Version 2 Field Service Manual, How to Remove for Service, p. 5.
- ↑ "Faulty sc1224 and Sc1436?", Atari-Forum, post by simbo, 28 February 2007. https://www.atari-forum.com/viewtopic.php?t=10579. Community advice.
- ↑ 16.0 16.1 16.2 SC1224 Service Manual (CA-3), troubleshooting charts A, B, C, C-1 and K, printed pp. 11-14 and 20 (PDF pp. 12-14 and 17).
- ↑ SC1224 Version 2 Field Service Manual, Power Circuit, p. 29.
- ↑ SC1224 Version 2 Field Service Manual, Service Adjustments, pp. 6-7.
- ↑ 19.0 19.1 SC1224 Version 2 Field Service Manual, Trouble Shooting, problems 3 and 4, pp. 20-21.
- ↑ SC1224 Service Manual (CA-3), Adjustment and Maintenance, High Voltage Check, printed p. 6 (PDF p. 8).
