Atari SC1224 Documentation
Atari documentation for the Atari SC1224 colour monitor: the service manual for the Goldstar-built set on the CA-3 chassis, a separate scan of the CA-3 schematic and troubleshooting charts, the field service manual for the JVC-built Version 2, and Atari's May 1986 summary specification for its ST monitors. No service documentation for the Samsung-built SC1224 has been found.
SC1224 RGB Color Monitor Service Manual, chassis CA-3
Atari's service manual for the SC1224 on the CA-3 chassis. The cover reads "Atari, Chassis No.: CA-3, SC1224 RGB Color Monitor, Service Manual" and carries no document number or date. The scan has 22 PDF pages, mostly two-page spreads, with printed page numbers up to 32.[1] Its dimensions and weight match those atari-computermuseum.de gives for the Goldstar set.[2]
Contents
CA-3 service manual, PDF page map
PDF page Contents
1 Cover and contents list
2 to 5 Pages from a different manual: exploded view (printed 29), schematic P/N 484-476A (printed 30), geometry measurements (printed 4) and specifications and adjustments (printed 3) of a 12-inch paper-white monochrome monitor with 35.7 kHz and 71.2 Hz scan rates, the figures of the Atari SM124
6 Safety precautions (X-radiation, high-voltage measurement, fire and shock hazard, implosion protection), general information and specifications
7 Control operation (front and rear controls with designators) and theory of operation (power supply, start-up, sync, AFC, X-ray protection, vertical and horizontal circuits, pincushion correction)
8 Adjustment and maintenance: degaussing, high-voltage check, fail-safe (hold-down) check, oscillator, size, focus, width, position, linearity, centre, side PCC, white balance and convergence
9 Convergence figures and block diagram
10 CA-3 chassis schematic diagram
11 Exploded view and mechanical parts list
12 to 17 Timing chart and troubleshooting charts A to K (printed 10 to 20); chassis important parts photograph (printed 21)
18 and 19 Board layouts: main, CPT and power boards (printed 22 to 24)
20 to 22 Replacement parts list for the main, CPT and power boards (printed 29 to 32)
  • A procedure for opening the case or removing the chassis.
  • Any coverage of the JVC Version 2 or the Samsung set.
  • The SC1224's own pages that would carry the printed numbers 3, 4, 29 and 30; the scan has the monochrome monitor's pages in those places.
  • Correct values for every part. The parts list prints C703 as 100 µF where the schematic and the part number give 1000 µF, gives C961, C963 and C965 in pF where they are 1000 µF, 1000 µF and 100 µF electrolytics, and numbers the LA7830 vertical output IC as IC801 where the schematic and the theory section call it IC601.[1][3]
Pages that cite this document
Download: Atari SC1224 Service Manual (CA-3 chassis).pdf
CA-3 chassis schematic and troubleshooting charts
A 12-page scan titled "Atari SC1224 Schematic (1986)". PDF page 1 is the "CA-3 Chassis Schematic Diagram", P/N 484-257A, with the waveforms WF1 to WF17 along the bottom; it is a cleaner copy than the one in the service manual scan and is the source for the power board values. PDF pages 2 to 12 repeat the timing chart and the troubleshooting charts A, K, B, C, C-1, D, E, F, G with H, and I with J from the service manual.[3] The schematic labels the AC input "100-264V 47-63Hz" and the fuse F901 "3.15AT 250V"; the outputs are 115 V, 12 V and 14 V.[3]
It has no parts list and no adjustment procedures.
Download: Atari SC1224 CA-3 Chassis Schematic and Troubleshooting Charts.pdf
SC1224 Version 2 Field Service Manual
Atari Corporation's SC1224 Version 2 Field Service Manual, document C070433, dated February 1986, 34 pages, for the 120 V set on the MA-1018A board set.[4] atari-computermuseum.de identifies the Version 2 as the JVC-built SC1224, and its dimensions and weight match those in the manual; the manual's last page carries the imprint "Printed in Japan".[2][4] The hosted copy was recompressed to 200 dpi; the Internet Archive scan is 300 dpi and 121 MB.
Contents
Version 2 field service manual contents (PDF pages; the printed numbers match up to page 30)
Pages Contents
2 Specifications
3 Safety precautions, including the dielectric strength and leakage current checks
4 Functions: front and rear controls
5 How to remove for service: rear cabinet, main board, bottom cover
6 to 7 Alignment locations and service adjustments
8 to 10 Colour adjustments: CRT replacement, purity, static and dynamic convergence
11 to 14 Replacement parts list information, the parts list for the MA-1018A boards, chassis and cabinet parts
15 to 17 Exploded view
18 Block diagram
19 to 22 Troubleshooting charts for five problems
23 to 30 Annotated circuit pages: sync pulse former, RGB amplifier, horizontal deflection, vertical deflection, blanking and HB regulator, video output, power and audio, each part marked with its function and the symptom when it is open or short
31 Main board pattern
32 Schematic diagram of the four MA-1018A boards
33 Notes to the schematic: safety parts, symbols, capacitor and resistor markings, transistor and IC basings
34 Packing diagram (printed page 31)
  • Values for standard resistors and capacitors in the parts list. Page 11 says they are omitted and gives only the part-number scheme; their values are on the schematic and the circuit pages.
  • A 220 V or 240 V version. The specification is 120 V AC, 50/60 Hz.
  • Agreement everywhere between the parts list and the schematic: C1151, C1251 and C1351 (4.7 µF in the list, 3.3 µF on the schematic), C1311 (10 µF and 4.7 µF), C1402 (tantalum 2.2 µF 16 V and electrolytic 2.2 µF 50 V) and C1427 (16 V and 25 V) differ. The regulator IC1901 is printed STR30125-A on the schematic and STR3125-A on the power circuit page.[4]
Download: Atari SC1224 Version 2 Field Service Manual C070433.pdf
Atari Monitor Summary Specifications, May 1986
A six-page Atari Corp. memo of 14 May 1986 from Tom Brightman, copied to Shiraz Shivji, sending "summary specifications for Atari monitors for the ST product line" for review. Page 2 is a table for the SM124, SC1224 and SC1425; pages 3 and 4 are SM124 and SC1224 timing charts; page 5 is the pin assignment of the 13-pin DIN connector; page 6 is an SC1425 timing chart.[5] The memo asks for a connector specification for the "SC1425 EST" monitor. The SC1425 in this table is a 14-inch 640 × 480 monitor at 31.5 kHz, which is not the SC1425 Atari sold from 1988 (see Atari SC1425).[5][6]
Download: Atari Monitor Summary Specifications (1986-05-14).pdf
  1. ↑ 1.0 1.1 Atari, SC1224 RGB Color Monitor Service Manual, chassis CA-3. File:Atari SC1224 Service Manual (CA-3 chassis).pdf; source Internet Archive item SC1224_Service_Manual_CA-3.
  2. ↑ 2.0 2.1 "Atari SC1224 RGB Color Monitor", atari-computermuseum.de, https://www.atari-computermuseum.de/st_peri.htm#sc1224. Secondary source for the manufacturers and the dimensions and weights of each version.
  3. ↑ 3.0 3.1 3.2 Atari, CA-3 Chassis Schematic Diagram, P/N 484-257A, with timing and troubleshooting charts. File:Atari SC1224 CA-3 Chassis Schematic and Troubleshooting Charts.pdf; source Internet Archive item Atari_SC1224_Schematic_1986_Atari.
  4. ↑ 4.0 4.1 4.2 Atari Corporation, SC1224 Version 2 Field Service Manual, C070433, February 1986. File:Atari SC1224 Version 2 Field Service Manual C070433.pdf; source Internet Archive item sc-1224-version-2-service-manual.
  5. ↑ 5.0 5.1 Atari Corp., Atari Monitor Summary Specifications, memo of 14 May 1986. File:Atari Monitor Summary Specifications (1986-05-14).pdf; source Internet Archive item rearc_atari-st-e-tt-toolkit-b1-76-atari-monitor-summary-specifications-1986-05-14.
  6. ↑ "Atari SC1425 RGB Color Monitor", atari-computermuseum.de, https://www.atari-computermuseum.de/st_peri.htm#sc1425. Secondary source.
