Macintosh Performa 200
Revision as of 11:49, 10 February 2026 by Josh (talk | contribs) (Creating Performa 200 article (rebrand of Classic II))
The Macintosh Performa 200 is a consumer-oriented compact Macintosh computer introduced by Apple Computer on September 14, 1992.[1] It is a rebranded version of the Macintosh Classic II, sold through consumer retail channels as part of Apple's Performa line. The two models are identical in hardware specifications, differing only in external branding and bundled software.
TypeAll-in-One Personal Computer
ReleasedSeptember 14, 1992
DiscontinuedOctober 18, 1993
Intro priceUS$900
CPUMotorola 68030 @ 16 MHz
Memory2 MB RAM (expandable to 10 MB)
Storage40 MB or 80 MB SCSI hard drive, 1.44 MB floppy drive
Display9" monochrome CRT (512×342 pixels)
SoundMonaural 8-bit
Dimensions13.2" H × 9.7" W × 11.2" D (35.5 cm × 24.6 cm × 28.4 cm)
Weight16.0 lbs (7.3 kg)
OS / FirmwareSystem 7.0.1 – Mac OS 7.6.1
Model no.M4150
Relationship to Classic II
The Performa 200 shares the same logic board, case design, and specifications as the Macintosh Classic II. Both models use a 16 MHz Motorola 68030 processor with a 16-bit data path, which limits memory bandwidth compared to the SE/30's 32-bit bus despite using the same processor.[2]
The Performa branding indicated sale through consumer retail outlets with bundled software and simplified setup, while the Classic II was sold through Apple's traditional dealer network.
The Performa 200 uses the Motorola 68030 processor running at 16 MHz. The processor supports 32-bit operations internally but connects to RAM via a 16-bit data bus, reducing memory throughput. The system bus operates at 16 MHz.
A proprietary internal expansion slot was designed for an optional FPU co-processor, though Apple never released one.
Memory
  • Standard RAM: 2 MB soldered on logic board
  • Maximum RAM: 10 MB (2 MB onboard + 8 MB via two 4 MB 30-pin SIMMs)
  • RAM Type: 30-pin SIMM, 100 ns or faster
  • RAM Slots: 2 (must be installed in matched pairs)
  • ROM: 512 KB
  • Floppy Drive: 1.44 MB SuperDrive (auto-inject)
  • Hard Drive: 40 MB or 80 MB internal SCSI
  • SCSI Interface: Internal and external SCSI ports
Display
The Performa 200 includes a built-in 9" monochrome CRT display with a resolution of 512×342 pixels, identical to the original Macintosh form factor. The integrated video circuitry draws from main RAM.
Input/Output
  • Keyboard Port: ADB (Apple Desktop Bus)
  • Mouse Port: ADB
  • Serial Ports: 2× Mini DIN-8 (printer and modem)
  • SCSI Port: DB-25 external SCSI
  • Audio: Mono speaker, 3.5mm headphone jack
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh Classic II General Maintenance page.
Detailed capacitor replacement guidelines for both analog and logic boards can be found on the Macintosh Classic II Capacitor Replacement Guide page.
A comprehensive troubleshooting guide addressing no power, chime but no video, intermittent operation, Sad Mac errors, and floppy drive problems is available on the Macintosh Classic II Troubleshooting page.
Retrobrite
Sub-system Specification
CPU Motorola 68030 @ 16 MHz
Bus width 16-bit data • 24-bit address
ROM 512 KB
RAM 2 MB (expandable to 10 MB)
Video 512 × 342 monochrome
Sound 8-bit mono
Disks 1.44 MB 3.5" floppy, 40/80 MB SCSI HDD
Ports ADB × 2, Serial × 2, SCSI
  1. Macintosh Performa 200 Specs, EveryMac.com—link(accessed 2026-02-10)
  2. Mac Classic II, Low End Mac—link(accessed 2026-02-10)
