Macintosh Performa 577
Revision as of 12:12, 10 February 2026 by Josh (talk | contribs) (Add Service Documentation section with embedded Apple Service Source PDF)
The Macintosh Performa 577 is an all-in-one personal computer released on February 2, 1994, as part of Apple's consumer-oriented Performa line. The Performa 577 is a rebrand of the LC 575 with a larger hard drive, featuring a 33 MHz Motorola 68LC040 processor, built-in 14-inch Sony Trinitron color display, and bundled consumer software.[1]
ReleasedFebruary 2, 1994
DiscontinuedApril 3, 1995
Intro priceUS$1,799
CPUMotorola 68LC040 @ 33 MHz
Memory5 MB RAM (expandable to 36 MB)
Storage320 MB SCSI hard drive, 2X CD-ROM drive
Display14" Sony Trinitron color CRT (640×480 pixels)
SoundStereo 16-bit, 44.1 kHz
Dimensions16.5" H × 13.2" W × 16.25" D (419 × 335 × 413 mm)
Weight38.4 lbs (17.4 kg)
OS / FirmwareSystem 7.1.1 – Mac OS 8.1
PredecessorPerforma 550
SuccessorPerforma 580
CodenameOptimus
Model no.M1347
The Performa 577 uses the same logic board and chassis as the Macintosh LC 575, differing only in storage capacity and bundled software:
  • Processor: Motorola 68LC040 @ 33 MHz (no FPU)
  • RAM: 5 MB (4 MB soldered + 1 MB SIMM), expandable to 36 MB
  • Storage: 320 MB SCSI hard drive
  • Optical: 2X CD-ROM drive
  • Modem: Internal modem (Comm Slot)
  • Display: 14" Sony Trinitron CRT (640×480, 256 colors standard)
Bundled Software
The Performa 577 shipped with System 7.1.1 (with System Enabler 065) and included:
  • ClarisWorks 2.0
  • Quicken 4.0
  • Grolier's Encyclopedia
  • Educational titles
The Performa 577 shares identical hardware with:
The Performa 577 uses the same logic board and components as the LC 575. For maintenance procedures including cleaning, capacitor inspection, and preventive care, refer to Macintosh LC 575 General Maintenance.
Surface-mount electrolytic capacitors on the logic board require replacement due to age-related leakage. For specifications and procedures, see Macintosh LC 575 Capacitor Replacement Guide.
Common issues including power supply failures, CRT problems, and capacitor-related failures are covered in the Macintosh LC 575 Troubleshooting guide.
Retrobrite
The Performa 577's beige plastics yellow from UV exposure. Restoration techniques are detailed on the Retrobrite page.
For complete technical specifications including memory maps, I/O details, and custom chip information, see the LC 575 Technical Details section.
  1. Apple Macintosh Performa 577 Specs, EveryMac.com—link(accessed 2026-02-10)
