The Amstrad NC100 Notepad is an A4-sized, Z80-based portable computer that Amstrad released in 1992. It has a full-size keyboard, an eight-line by 80-column LCD, and its software in ROM: a word processor, address book, diary, calculator, a terminal program and BBC BASIC. It runs from four AA cells or a mains adaptor, with a lithium coin cell keeping the memory alive while the cells are changed.[1][2] The Centre for Computing History gives its price as £199 and dates its own unit to August 1992.[3]
NC100 with a UK keyboard
ManufacturerAmstrad plc
TypeNotebook computer
ReleasedJuly 1992
Intro price£199
CPUZilog Z84C00 (Z80-compatible CMOS), 4.606 MHz
Memory64 KB SRAM (two µPD43257A)
StoragePCMCIA/JEIDA Type I SRAM card, up to 1 MB
Display480 × 64 pixel LCD, 80 × 8 characters, not backlit
Sound—
ROM256 KB firmware EPROM (µPD27C2001)
Ports / interfaceCentronics parallel (DB-25), RS-232 serial (DE-9)
PowerFour AA cells or mains adaptor; CR2032 lithium backup cell
Dimensions295 × 210 × 22 mm
Weight930 g
OS / FirmwareBuilt-in Protext-based word processor, diary, address book, calculator, terminal and BBC BASIC
SuccessorAmstrad NC150
History
Wikipedia gives the release as July 1992, when Newsbytes reported the unveiling; Tim Surtell's NC users' site gives September 1992 for the launch.[4] Two related models followed: the Amstrad NC150, sold only in Italy and France in the same case from April 1993, and the NC200, a clamshell model with a backlit 80 × 16 screen and a 3.5-inch disc drive.[1] Both the NC100 and NC200 were also sold in North America as the Dreamwriter 325 and Dreamwriter 200.[1]
Hans-Jürgen Böhling's teardown, A Surgical Guide To The Amstrad Notepad Computer, describes the board. His German NC100 board is marked Amstrad plc 4500-001P-1. Every IC is surface-mounted except the firmware EPROM, IC303, which sits under its own cover on the underside.[5]
NC100 main ICs (Böhling's surgical guide)
IC Part Function
IC301 Zilog Z84C0006FEC Z80-compatible CPU, 6 MHz part
IC302 NEC µPD65034 Custom ASIC: clocks, keyboard, printer and LCD interface, memory management, PCMCIA, sound
IC303 NEC µPD27C2001 256K × 8 firmware EPROM
IC304, IC305 NEC µPD43257A 32K × 8 SRAM, on the lithium-backed supply
IC307 Toshiba TC8521 Real-time clock, on the lithium-backed supply
IC308 NEC µPD71051 UART
IC309 NEC µPD4711 RS-232 line driver
IC312 LM339 Comparators for battery level detection
Böhling also tabulates zero-ohm links beside IC303 that select larger ROM types (27C4001, 23C2001, 23C4001 or 23C8001) and links that allow 43256 RAMs with the unfitted IC310.[5] The memory card slot takes 5 V PCMCIA/JEIDA Type I SRAM cards of up to 1 MB; flash cards do not work.[5] Amstrad's manual says cards must be formatted from the stored-documents menu before use.[2]
Böhling gives the clock as 4.606 MHz; Wikipedia gives 4 MHz.[5][1]
Power
NC100 power sources
Source Details
Four AA cells Alkaline LR6, about 35 to 40 hours; NiCd rechargeables about 5 hours (Amstrad)
Mains adaptor The supplied adaptor only; Böhling's power diagram marks the input as 6 V DC, with fuse F301
CR2032 lithium cell Keeps the memory and clock when no other power is present; Amstrad estimated its life at five years
Amstrad's figures are from the user manual; Wikipedia gives up to 20 hours on four AA cells.[2][1] Böhling's power supply diagram shows a DC/DC converter producing +6 V, +5 V, a lithium-backed 5 V line for the RAM and clock, and −15 V for the LCD, with a battery-level detector that signals the custom chip.[5] The supplied adaptor gives 300 mA at 6 V DC and is not regulated.[6] The Amstrad NC100 Troubleshooting Guide gives the warning thresholds. If every power source is removed at once, the documents, addresses and diary entries in memory are lost.[2]
Repair guides
  1. ↑ 1.0 1.1 1.2 1.3 1.4 Wikipedia, "Amstrad NC100", lead and section "Upgrades". Retrieved 2026-10-02. Release in July 1992, the built-in software, the 80 × 8 unlit screen, the serial, parallel and PC card ports, and the NC150 and NC200.
  2. ↑ 2.0 2.1 2.2 2.3 Amstrad plc, Amstrad Notepad Computer user manual. Hosted as File:Amstrad Notepad Computer User Manual.pdf, described at Amstrad Notepad Computer User Manual. Setting up pp. 1–2; mains adaptor p. 4; powering the Notepad p. 43; automatic power off p. 44; memory cards p. 47; resetting p. 60.
  3. ↑ Centre for Computing History, "Amstrad NC100", exhibit CH49463. Retrieved 2026-10-02. The £199 price and an August 1992 unit.
  4. ↑ Tim Surtell, Tim's Amstrad NC Users' Site, "Introduction" and "Specifications of the NC Computers". Retrieved 2026-10-02. Launch dates of the NC100 (September 1992), NC150 (April 1993) and NC200 (October 1993); the NC150's 128 KB RAM, French and Italian versions and optional external floppy drive; 4 × AA cells and a 6 V mains adaptor for the NC100 and NC150.
  5. ↑ 5.0 5.1 5.2 5.3 5.4 Hans-Jürgen Böhling, A Surgical Guide To The Amstrad Notepad Computer. Community document, hosted as File:Amstrad NC100 Surgical Guide.pdf, described at Amstrad NC100 Surgical Guide. Specification, opening the case, board and IC table, block and power supply diagrams, EPROM and RAM link tables, PCMCIA slot.
  6. ↑ Tim Surtell, Tim's Amstrad NC Users' Site, "Questions & Answers: Hardware". Retrieved 2026-10-02. Community answers: the blank-screen checklist from the NC200 manual, the internal surface-mount fuse (6 V 0.8 A on the NC100), adaptor rating and polarity, mains lead repair, case cracking, the NC100 display ribbon cable, serial port reliability, memory cards up to 1 MB, and Cliff Lawson on the NC150's Ranger disk hook.
