Macintosh Performa 6310CD
The Macintosh Performa 6310CD is a PowerPC-based desktop personal computer manufactured by Apple Computer, Inc. and released on February 14, 1996.[1] It is the European and Asian version of the Performa 6300CD, featuring identical specifications: a 100 MHz PowerPC 603e processor, 16 MB of RAM, a 1.2 GB IDE hard drive, and a 4X CD-ROM drive in a compact desktop case based on the Macintosh Quadra 630 form factor.
| Macintosh Performa 6310CD | |
| Type | Personal Computer |
| Released | February 14, 1996 |
| Discontinued | October 1, 1996 |
| Intro price | n/a |
| CPU | PowerPC 603e @ 100 MHz |
| Memory | 16 MB RAM (expandable to 64 MB) |
| Storage | 1.2 GB IDE hard drive, 4X CD-ROM |
| Display | DB-15 video output (640×480 16-bit, 800×600 8-bit) |
| Sound | 16-bit mono input, 16-bit stereo output |
| Dimensions | 4.3" H × 16.5" W × 12.6" D (10.95 × 41.95 × 32 cm) |
| Weight | 19 lbs (8.6 kg) |
| OS / Firmware | System 7.5.1 – Mac OS 9.1 |
| Predecessor | Performa 6200CD |
| Successor | Performa 6360 |
| Model no. | M3076 |
The Performa 6310CD shares its logic board (Model M3076, Gestalt ID 42) with the Performa 6300CD and Performa 5300CD all-in-one system.
Hardware Overview
editThe Performa 6310CD is functionally identical to the Performa 6300CD:
- Processor: PowerPC 603e at 100 MHz with integrated FPU
- RAM: 16 MB standard via two 72-pin SIMM slots (80 ns), expandable to 64 MB
- Storage: 1.2 GB IDE hard drive, 4X CD-ROM, 1.44 MB floppy
- Video: 1 MB system RAM dedicated to video (640×480 16-bit, 800×600/832×624 8-bit)
- Expansion: LC PDS slot, communications slot, video I/O slot, TV tuner slot
Regional Differences
edit| Model | Region | Order Number | Notes |
| Performa 6300CD | North America | Various | Bundled with 15" monitor |
| Performa 6310CD | Europe, Asia, Japan | M4730J/A (Japan) | International version |
editFor detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh Performa 6300CD General Maintenance page.
editDetailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 6300CD Capacitor Replacement Guide page.
editA comprehensive troubleshooting guide addressing no power, startup issues, video problems, and other common failures is available on the Macintosh Performa 6300CD Troubleshooting page.
editSystem Architecture at a Glance
edit| Sub-system | Specification (Macintosh Performa 6310CD, 1996) |
| Bus width | 32-bit data (I/O) • 64-bit data (CPU) |
| ROM | 4 MB |
| RAM | 16 MB (expandable to 64 MB) |
| L1 Cache | 32 KB |
| L2 Cache | 256 KB |
| Video | 640×480 16-bit, 800×600 8-bit |
| Sound | Mono input, stereo output |
| Disks | 1.2 GB IDE HDD, 1.44 MB floppy, 4X CD-ROM |
| Ports | ADB, SCSI, 2× Serial, Audio I/O, Video out |
Power Specifications
edit- Input: 100V-240V AC, 50-60 Hz
- Maximum power consumption: 55 Watts
Apple service data
editApple's own figures for this family, from the Performa 6200/6300 Series Service Source volume hosted on this wiki.[2]
| Item | Apple's figure (6200/6300 series except 6360) |
| Case | Height 4.3 in. (10.95 cm), width 16.5 in. (41.95 cm), depth 12.6 in. (32 cm) |
| Weight | Without CD-ROM 17 lb. (7.7 kg); with CD-ROM 19 lb. (8.6 kg) |
| Line voltage | 100–240 VAC, 47–63 Hz (Performa 6360: 90–270 VAC, 43–67 Hz) |
| Power | 125 W; 2.5 A maximum and 220 W maximum for all line and load conditions (6360: 150 W) |
| Level 2 cache | 256K, standard across the series |
| ROM / video | 4 MB ROM; 1 MB of DRAM on board for video support |
| Sound | 16-bit monophonic sound input — the port accepts a stereo signal but combines it to mono for play-through or recording — and 16-bit stereophonic output, nominally 0.5 V RMS into 39 ohms, on two ports (front headphone jack, rear stereo mini phone jack). The internal speaker is muted when a plug is inserted in an output jack |
| Slots | Processor-direct slot 96/114-pin (not fitted on the 6360); communications slot 112-pin; video-in slot 60-pin; TV tuner port 10-pin |
| SCSI / ADB | One external DB-25 SCSI port, up to seven devices; one ADB port, mini DIN-4 |
| PRAM battery | Apple's symptom chart calls it a 4.5 V battery; verify it on the 10 V DC scale with the logic board removed and replace below 3.0 V |
The Performa 6360 is the exception on almost every line. Apple gives it 16-bit stereophonic input and output with SRS 3D Surround Sound, a sound-input connector at line level 2 Vpp maximum into 10 kilohms and an output at 2 Vpp maximum into 32 ohms, one built-in speaker rather than two, one 6.88-inch PCI slot in place of the processor-direct slot, GeoPort-compatible serial ports, and memory in two 168-pin, 70 ns DIMM sockets expandable to 136 MB where the rest of the family uses two 72-pin, 80 ns SIMM sockets to 64 MB.[2]
Two things in this volume are Apple's own errors and are not repeated here: a "Video Screen: 15-inch 0.28 mm dot-pitch CRT" entry, which belongs to the 5200-series all-in-one and not to a desktop machine, and the battery instruction printed as "Unplug 4.5 V battery" in this volume but as "Unplug 5.4 battery" in the 630-series volumes for the identical step.[2]
editReferences
edit- ↑ Macintosh Performa 6310CD Specs, EveryMac.com—link(accessed 2026-02-10)
- ↑ 2.0 2.1 2.2 Apple Computer, Performa 6200/6300 Series, Service Source. Hosted here as Performa 6200/6300 Series Service Source (File:Performa_6200.6300.pdf). Specifications and Additional Procedures — Battery Verification chapters.
