Help:Writing a repair guide
| ๐ง Writing a Repair Guide |
| Templates and Best Practices for RTC Wiki Repair Articles |
Repair guides are the heart of the RetroTechCollection Wiki. This page explains how to write high-quality maintenance, troubleshooting, and capacitor replacement guides.
Article Types
[edit source]We use three standard guide types for each device:
| Type | Purpose | Naming Convention |
| General Maintenance | Preventive care, cleaning, inspection, common failure points | Device Name General Maintenance
| Troubleshooting | Systematic fault diagnosis with symptoms, causes, and actions | Device Name Troubleshooting Guide
| Capacitor Replacement | Complete cap lists, replacement procedures, post-recap checks | Device Name Capacitor Replacement Guide
General Maintenance Guide Template
[edit source]A maintenance guide should cover:
- Regular Cleaning โ external case, internal components, connectors
- Power Supply Checks โ voltage measurements, PSU health
- Connector & Socket Maintenance โ cleaning, DeoxIT, contact care
- Common Failure Points โ what breaks most often and why
- Cooling System โ fans, heatsinks, thermal material
- Recommended Tools โ what you need for maintenance
- Preventive Maintenance Checklist โ periodic tasks
Key Principles
[edit source]- Be specific โ include exact voltages, temperatures, and part numbers
- Include measurements โ expected voltage ranges with tolerances (e.g., "4.9โ5.1 V")
- Reference board revisions โ note when procedures differ between hardware versions
- Warn about dangers โ CRT discharge, mains voltage, ESD sensitivity
Troubleshooting Guide Template
[edit source]A troubleshooting guide should use diagnostic tables with three columns:
|+ '''Problem Category'''
! Symptom !! Probable Cause !! Recommended Action
| Description of what the user sees || What's likely wrong || What to do about it
Standard sections:
- Preliminary Checks โ basic power and visual inspection
- Voltage Reference Table โ all power rails with expected values
- No Power / Dead Unit โ power supply chain faults
- No Video / Display Issues โ video output problems
- No Audio โ sound faults
- Input Device Issues โ controller/keyboard faults
- Disc/Media Errors โ optical drive or floppy issues (if applicable)
- Component-Level Tests โ clock frequencies, oscilloscope readings, chip-level diagnostics
- Quick-Fix Flowcharts โ decision trees for common problems
Writing Good Diagnostic Tables
[edit source]- Start with the most common cause โ list probable causes in priority order
- Be actionable โ every "Recommended Action" should tell the reader exactly what to do
- Include test values โ "Measure 5V at pin 21" is better than "Check the power supply"
- Cross-reference โ link to the maintenance guide and capacitor guide
Capacitor Replacement Guide Template
[edit source]A capacitor replacement guide needs:
- Visual Inspection Signs โ what failing caps look like
- Complete Capacitor List โ table with designator, value, voltage, type, and location
- Board Revision Differences โ note where cap layouts change between revisions
- Replacement Procedure โ step-by-step desoldering and soldering instructions
- Post-Recap Voltage Checks โ expected values and acceptable ripple
- Recommended Tools & Parts โ specific equipment needed
Capacitor Table Format
[edit source]{| class="wikitable styled-table" style="width:80%; text-align:center;"
|+ '''Board Name Capacitor Specifications'''
! Designator !! Capacitance !! Voltage !! Type !! Notes
| C1 || 100 ยตF || 6.3 V || SMD || Power filtering
Writing Style
[edit source]Follow the RTC Wiki style guidelines:
- Factual and specific โ state what it IS, not what it MEANS
- Dry technical writing โ let the facts speak; skip commentary
- No AI writing patterns โ avoid "pivotal", "crucial", "testament to", "enduring legacy"
- Direct โ subject-verb-object, no fluff
- Source everything โ use
<ref>{{cite web ...}}</ref>
Using Styled Tables
[edit source]Add this at the top of your article for consistent table styling:
Then use class="wikitable styled-table" on your tables.
Cross-Linking
[edit source]Every repair guide should link to:
- The main article for the device
- The other two guide types (maintenance โ troubleshooting โ capacitor guide)
- Relevant common pages (e.g., CRT Discharge Procedure, Sad Mac Error Codes)
