IBM Color Graphics Adapter
Revision as of 10:03, 21 May 2026 by Josh (talk | contribs) (Create supporting page for the IBM PC (5150) article series)
The IBM Color Graphics Adapter (CGA) is the original 8-bit ISA colour graphics card IBM released alongside the IBM PC (5150) in 1981. It uses a Motorola 6845 CRT controller, carries 16 KB of dedicated video RAM, and drives a TTL RGBI monitor (the IBM 5153) or a composite TV through an NTSC encoder.
Video Modes
CGA video modes
Mode Resolution Colours Notes
0 40 ร— 25 text 16 fg / 8 bg Composite or RGBI
1 40 ร— 25 text 16 fg / 8 bg Colour burst suppressed
2 80 ร— 25 text 16 fg / 8 bg 8 ร— 8 character cell
3 80 ร— 25 text 16 fg / 8 bg Colour burst suppressed
4 320 ร— 200 graphics 4 from two fixed palettes Palette 0: cyan/magenta/white; Palette 1: green/red/yellow
5 320 ร— 200 graphics 4 (greyscale on composite) Composite "alternate" palette
6 640 ร— 200 graphics 2 (background + foreground) Highest resolution
Several undocumented modes can be coaxed out of the 6845 (160 ร— 100 16-colour text-block "mode 7", composite NTSC artefact colour, "8088 MPH"-style techniques), but they are not part of the BIOS interface.
  • 6845 CRTC โ€” clock and sync generation, addressing.
  • 16 KB video RAM (8 ร— 4116 DRAM on early boards, later consolidated).
  • TTL RGBI output on DB-9 (drives the IBM 5153).
  • Composite NTSC output on RCA jack (drives any NTSC TV).
  • Light-pen connector (rarely used).
Common Faults
  • Snow โ€” the famous CGA "snow" effect is not a fault but a design quirk: the video RAM is single-ported and CPU writes during the active raster cause briefly-visible noise. Disable by waiting for the horizontal retrace (most CGA-aware games already do this).
  • No video, beep code 1 long + 2 short โ€” the CGA card is dead or unseated. Reseat first.
  • Missing one colour channel โ€” bad output buffer at the DB-9, or cracked solder joint on the connector.
  • Smoke from a discoloured tantalum โ€” replace the failed tantalum (typically a 22 ยตF / 16 V) and any series resistor that may have died with it. See ISA card capacitor positions.
