IBM PC XT Capacitor Replacement Guide
Revision as of 11:02, 21 May 2026 by Josh (talk | contribs) (Comprehensive rewrite/creation of the IBM PC XT (5160) page set with verified facts and embedded content per RTC style guide)
The IBM PC XT (5160) motherboard carries through-hole tantalum capacitors that fail short-circuit and latch the PSU off. Recapping the motherboard and the PSU is the most useful preventative job on a 40-plus-year-old XT. This guide documents the verified per-rail capacitor positions, the failure modes, the soldering technique, and the replacement parts. The board photos on this page are imported with attribution from minuszerodegrees.net, whose long-running 51xx motherboard failure-history work is the primary source for IBM 5160 motherboard capacitor information.
A failed tantalum capacitor on an IBM 51xx motherboard. The small black hole on the body is the only visual indication of failure — in most cases there is no visual sign at all. (Image: minuszerodegrees.net)
A failed tantalum may show:
  • Cracked or discoloured body — small yellow or orange dipped bead.
  • Small black "eye" or hole on the body, as shown opposite. Often the only visual indication.
  • Burnt resistor next to the capacitor — a tantalum that shorted may have taken out the series resistor.
  • Brown halo around the pad — conductive residue from a long-failed capacitor.
In a substantial fraction of cases, a short-circuit tantalum shows no visual indication at all. Diagnostic methodology (resistance-to-ground measurement, capacitor removal one at a time) is required.
IBM 5160 Motherboard Tantalum Capacitors
The 5160 motherboard carries 16 tantalum capacitors total, irrespective of motherboard revision (64-256KB or 256-640KB). Their distribution by rail is:
IBM 5160 motherboard tantalum capacitor inventory
Rail Number of tantalums Notes
+5 V 13 All highlighted in the photo below; standard 10 µF / 16 V tantalum
+12 V 1 (C56) See dedicated section below; not critical to motherboard operation
Other rails / decoupling 2 Standard 10 µF / 16 V tantalum
In addition there is a single ceramic capacitor (C55) sitting on the +12 V line alongside the C56 tantalum.
+5 V tantalum capacitors
Thirteen tantalum capacitors sit on the +5 V line of the 5160 motherboard. They are highlighted in the photo below.
IBM 5160 (PC XT) motherboard. The thirteen tantalum capacitors on the +5 V line are highlighted. (Image: minuszerodegrees.net)
If a short-circuit is present on the +5 V rail of the motherboard (PSU latches off the moment the rail comes up), the cause is usually one of these thirteen tantalums. Remove them one at a time (desolder, or snip the leads at the body) until the short clears. Replace all of them with new 10 µF / 16 V tantalum or solid polymer parts.
+12 V tantalum capacitor C56
The +12 V line on the 5160 motherboard has only two components on it: C55 (a ceramic) and C56 (a tantalum). C55 can in theory short-circuit, but C56 is the textbook XT failure: minuszerodegrees.net's long-running failure history identifies it as a well-known short-circuit problem.
IBM 5160 motherboard: C56 is the +12 V tantalum capacitor, highlighted. It is the most documented short-circuit failure position on the XT motherboard. (Image: minuszerodegrees.net)
C56 filters only the +12 V going to the expansion slots. It is not critical to motherboard operation — the board will run without it. If C56 has gone short-circuit, you have two options:
  • Remove it entirely (desolder, or snip the leads at the body). The XT will run normally; expansion-slot +12 V will have less filtering.
  • Replace it with a new 10 µF / 16 V tantalum or solid polymer part. This is the recommended action.
If neither option clears the +12 V short, the fault is elsewhere (a +12 V short on an ISA card, or on the HDD/floppy power circuit).
Polarity
Tantalum capacitor polarity must be correct or the replacement part will fail explosively the moment power is applied. The positive lead is the longer of the two new-part leads and is marked + on the body. The PCB pad with the silkscreened + takes the positive lead.
Polarity reference for IBM 51xx motherboard tantalum capacitors. The reference applies to both the 5150 and 5160 motherboards. (Image: minuszerodegrees.net)
Soldering Technique
The 5160 motherboard has heavy copper ground and power pours that act as enormous heatsinks, the same as on the 5150. Conventional soldering iron work with an under-powered iron risks lifting the pad. minuszerodegrees.net documents a SNCTOL technique (Snip, Cut, Tin, Overlap, Solder) that avoids working the pad and is significantly safer for the PCB.
SNCTOL soldering technique. The diagram is for the 5150 motherboard but the technique applies equally to the 5160. (Diagram: minuszerodegrees.net)
If using a soldering iron directly, set it to at least 380 °C and use plenty of flux. A hot-air rework station, where available, makes the job substantially easier.
Replacement Parts
Use one of:
  • Modern wet-electrolyte tantalum: 10 µF / 16 V dipped tantalum bead (e.g. KEMET T350E106K016AT, AVX TAP106K016).
  • Solid polymer tantalum: 10 µF / 16 V or higher (e.g. KEMET T491A106K016AT). Solid polymer types do not fail short-circuit and are the recommended replacement.
  • Pre-packaged kit: Console5 IBM cap kits.
Voltage rating of 16 V is the minimum; 25 V or 35 V parts are also acceptable. Do not under-rate.
  1. Disassemble. Disconnect mains, remove the five rear cover screws, slide the cover off. Disconnect the floppy and HDD power cables, the HDD ribbons, and all ISA cards (labelling each). Unplug P8/P9 from the motherboard. Remove the four PSU mounting screws and lift the PSU out.
  2. Bleed the PSU bulk capacitors. The primary-side bulk capacitors retain a dangerous charge for hours after disconnection. Discharge each through a 10 kΩ resistor across the leads for at least 30 seconds.
  3. Document the original capacitor layout with photographs before desoldering.
  4. Desolder tantalums one at a time. Snip the leads close to the body and lift the body off, then desolder the remaining leads from the pad side.
  5. Install replacements with correct polarity (long lead = +, silkscreen + on the pad).
  6. Clean up flux residue with isopropyl alcohol; inspect for solder bridges.
  7. Reassemble, power on with no ISA cards beyond the video adapter, and confirm PSU rails before fitting the HDD ribbon and other cards.
Diagnostic Procedure for a Suspected Short-Circuit Tantalum
  1. Disconnect the keyboard.
  2. Remove all ISA cards (including the Fixed Disk Adapter and floppy adapter).
  3. Disconnect HDD and floppy power cables.
  4. Try the PSU again with just the motherboard connected. If the rails come up cleanly, the short was on one of the removed cards or drives. Re-add cards/drives one at a time, powering down between each.
  5. If the rails still latch off, the short is on the motherboard.
  6. With the motherboard isolated (PSU disconnected), measure resistance between +5 V and ground, and between +12 V and ground.
  7. +5 V dead short: the cause is almost certainly one of the 13 highlighted tantalums on the +5 V line.
  8. +12 V dead short: the cause is almost certainly C56. Remove C56; the short should clear.
  9. If the short does not clear, suspect other components on the affected rail (RAM chips on +5 V; or the C55 ceramic on +12 V).
ISA Card Capacitors
Several common 5160-era expansion cards also carry tantalum capacitors that fail in the same way as the motherboard tantalums:
The same SNCTOL replacement technique applies to ISA card capacitors.
PSU Capacitor Replacement
The XT PSU is a 130 W unit. Both US-only (120 V) and international (switchable 120/230 V) variants exist. Recap both types with attention to:
  • Primary-side bulk filtering — high-voltage electrolytics on the rectified-mains side.
  • Output filters for +5 V, +12 V, −5 V, −12 V on the secondary side.
  • X / Y safety capacitors on the mains input — must be replaced with safety-rated parts (X2 / Y1 / Y2 as appropriate). A failed X capacitor is a fire risk.
Specific values vary between PSU manufacturers (Astec, Zenith, IBM-branded variants). Consult the markings on the existing capacitors before ordering replacements; the Console5 PSU recap kit covers the standard 5160 PSU.
Post-Recap Voltage Checks
After recapping, with the machine running and no ISA cards fitted beyond the video adapter:
Rail Expected Max ripple
+5 V at P8/P9 4.95 – 5.15 V < 100 mV
+12 V at P8/P9 11.9 – 12.3 V < 200 mV
−5 V at P8/P9 −4.85 – −5.15 V < 50 mV
−12 V at P8/P9 −11.7 – −12.3 V < 100 mV
+12 V at HDD power connector 11.9 – 12.3 V under spin-up load A sagging rail here causes 1701 errors
