IBM 5120 Capacitor Replacement Guide
Revision as of 16:42, 23 May 2026 by Josh (talk | contribs) (Deep technical pre-PC IBM page with verified sources (Bitsavers MIM/MAP, Wikipedia, IBM Archives) — honest gap disclosure where IBM did not publish per-board cap values)
This guide documents capacitor diagnosis and replacement for the IBM 5120 Computing System (also designated IBM 5110 Model 3). The 5120 uses a linear power supply that is larger than the 5100 / 5110 supplies because it must drive 2 × 8-inch floppy drives plus the 9-inch CRT. The 9-inch CRT also carries higher anode voltage and more substantial deflection-board capacitance than the 5-inch tube in the 5100 / 5110. After 45 years, all electrolytics should be considered out of specification.
Important Caveat
Per-board exact capacitor values for the IBM 5120 are NOT published in surviving IBM documentation that this guide author has been able to locate. The Maintenance Information Manual SY34-0192-0 documents the PSU and deflection board as block diagrams without per-component values; the Logic Manual SY34-0193-0 documents power distribution but not capacitor part values. This guide therefore documents the typical linear-PSU practice that applies to recapping the 5120, with categories of capacitor and representative value ranges. Each restorer should pull each board, identify caps in situ by their printed markings, and replace with same-or-higher voltage and same capacitance.
Safety Warning
The 5120 PSU contains mains-rectified bulk capacitors that hold a lethal charge after power-off. The 9-inch CRT anode carries 12–15 kV with substantial stored energy on the high-voltage capacitor. Before any work inside the chassis:
  1. Power off and unplug the mains lead.
  2. Wait at least 30 seconds.
  3. Discharge each PSU bulk filter capacitor through a 1 kΩ / 5 W resistor.
  4. Discharge the CRT anode to chassis ground via a high-voltage probe. The 9-inch tube stores more energy than the 5-inch tube on the 5100 / 5110.
  5. Verify both with a multimeter.
Linear PSU Topology
The 5120 PSU is a single-board linear supply, larger than the 5100 / 5110 supplies:
  • Mains input section — input fuse, X2 line-suppression capacitor (replace if RIFA-branded), mains transformer (larger than 5100 / 5110).
  • Rectifier section — bridge rectifier diodes.
  • Bulk filter section — large axial-can aluminium electrolytics smoothing rectified DC. Multiple bulk caps because of the larger rail count (the 5120 needs a spindle motor rail in addition to logic and deflection rails).
  • Series-pass regulator section — bipolar pass transistors on heatsinks.
  • Output filtering — smaller electrolytics at the rail output to the planar and to the drive logic boards.
5120 Main PSU Bulk Filter Capacitors — Primary Target
The bulk filter capacitors after the bridge rectifier are by far the most likely failure point. Representative values:
IBM 5120 PSU bulk filter capacitor (representative)
Value Voltage Type Position Quantity (approx)
4700–10000 µF 25–50 V Axial-can aluminium electrolytic, 105 °C +12 V or +24 V spindle motor rail bulk 1
4700–10000 µF 25–50 V Axial-can aluminium electrolytic, 105 °C +5 V logic rail bulk 1
2200–4700 µF 25 V Axial-can aluminium electrolytic, 105 °C +12 V auxiliary / deflection rail 1
1000–2200 µF 35 V Axial-can aluminium electrolytic, 105 °C −12 V bias rail 1
Verify printed values on the original caps before ordering replacements. Lead spacing is fixed by the PSU board.
5120 Series-Pass Regulator Capacitors
IBM 5120 series-pass regulator capacitors (representative)
47–470 µF 25–35 V Aluminium electrolytic, 105 °C Regulator input / output 6–10
0.1–1 µF 50 V Film / tantalum bypass (inspect only) Regulator bypass 6–10
Mains Suppression Capacitor
Inspect the X2 mains suppression capacitor. If it is RIFA-branded or shows cracking / bulging / fluid leakage, replace immediately with a modern X2-class 0.1 µF / 275 VAC. The fish odour is the RIFA polymer venting and is a fire hazard.
9-Inch CRT Deflection / Flyback Board
The 9-inch CRT deflection / flyback board carries more capacitance than the 5-inch tube on the 5100 / 5110. Representative cap list:
9-inch CRT deflection board capacitors (representative)
1–10 µF 25 V Aluminium electrolytic Vertical / horizontal oscillator bypass
22–47 µF 35 V Aluminium electrolytic Vertical deflection driver
100–470 µF 35 V Aluminium electrolytic +12 V deflection rail bulk
220–680 µF 16 V Aluminium electrolytic Boost rail
0.01–0.1 µF 1.6 kV–2 kV Ceramic disc (HV) Snubber on flyback collector
0.0027–0.01 µF 1.6 kV–2 kV Polypropylene HV Horizontal deflection tuning
The HV ceramic and polypropylene caps rarely fail. Aluminium electrolytics on the deflection board can leak and corrode the board over time — inspect under magnification.
8-Inch Floppy Drive Logic Boards
The 2 × built-in 8-inch floppy drives each carry their own logic board. Typical values for Shugart-class drives:
8-inch floppy drive logic board (representative)
47 µF 16 V Aluminium electrolytic Spindle motor driver
22 µF 16 V Aluminium electrolytic Sector buffer
10 µF 25 V Aluminium electrolytic Head amp
4.7 µF 16 V Tantalum IC bypass
If a drive becomes unreliable warm but stable cold, recap the drive logic board with 105 °C low-ESR equivalents. The same procedure applies to any external 5114 attached.
ROS / RWS / PALM Card Capacitors
The Executable ROS, Language ROS, RWS cards, and PALM board carry small tantalum decoupling caps. Diagnostic procedure for tantalum short:
  1. Multimeter on diode test.
  2. Probe each tantalum in-circuit: black to ground, red to rail.
  3. Good cap reads open / high resistance; shorted cap reads close to 0 Ω.
  4. Remove the cap to confirm.
  5. Replace with tantalum or low-ESR ceramic of equal value, equal or higher voltage rating.
Same as the IBM 5100 and IBM 5110:
  • Manufacturer: Panasonic FR/FM/FC, Nichicon HE/HZ (post-2007 date codes), Rubycon ZLH/ZLJ/YXJ, United Chemi-Con KZH/KZE.
  • Avoid generic Chinese-brand electrolytics for PSU rebuild.
  • 105 °C rated even where IBM original was 85 °C.
  • Voltage equal or higher than original.
  • Capacitance equal to original.
  • Verify lead spacing — many originals are axial; modern replacements are typically radial (use lead extenders if needed).
Recap Procedure
  1. Discharge the PSU bulk capacitors.
  2. Discharge the CRT anode to chassis ground via HV probe.
  3. Remove the PSU board from the chassis.
  4. Photograph from both sides at high resolution. Record every cap's location, value, polarity, lead pitch.
  5. Desolder each electrolytic with solder wick on each lead. Limit each cycle to 5–7 seconds at no more than 350 °C.
  6. Clean each pad with solder wick.
  7. Fit replacements matching the silkscreen polarity.
  8. Solder both leads from the underside. Inspect for clean fillets. Trim leads flush.
  9. Repeat for the deflection / flyback board.
  10. Reassemble.
  11. Verify rails on the bench under a 1–2 A resistive load before refitting.
Post-Recap Verification
  1. Power on with no diskette in either drive.
  2. Probe each rail at the planar power connector.
  3. Verify language banner appears clean on the 9-inch CRT.
  4. Run Diagnostic ROS.
  5. Insert customer test diskette; run Customer Acceptance Test.
  6. Verify each 8-inch drive reads and writes.
If any test fails, re-inspect the polarity of every replaced cap before suspecting another fault.
Polarity Reference
Polarity reference for IBM motherboard tantalum and aluminium electrolytic capacitors. Match the silkscreen "−" to the cap stripe. (Image: minuszerodegrees.net)
When Not to Recap
If the 5120 powers on cleanly, all rails are within tolerance, the language banner is clean, Diagnostic ROS runs, both drives read and write, and there is no visible cap failure, the caps are within tolerance. Given the machine's age (~45 years), planned recap before any extended use is strongly recommended to avoid bulk filter cap failure damaging downstream circuitry.
Always recap if:
  • Any visible cap failure on PSU, deflection board, or drive logic.
  • PSU smoke, fishy odour or audible whine.
  • Rails out of tolerance.
  • RIFA-branded X2 mains suppression cap present (preventive replacement).
  • 9-inch CRT loses focus after warm-up (suggests deflection-board cap ESR rise).
  • Either floppy drive becomes unreliable when warm.
