Sega Dreamcast Capacitor Replacement Guide
Revision as of 21:40, 22 September 2026 by Josh (talk | contribs) (Rewrite against Sega's own service manuals hosted on this wiki plus console5 board-reads; fabricated capacitor tables and specifications removed, every figure now cited)
A Sega Dreamcast holds its electrolytics in four places: the logic board, the power supply, the GD-ROM optical board and the small controller-interface board. All four have their own designators, all four vary by revision, and none of them is interchangeable with another.
Sega Dreamcast
No Sega Dreamcast service manual carrying a parts list is hosted on this wiki — the Sega Dreamcast VA0 Schematics here are schematics and diagrams only, with no bill of materials. Every value on this page therefore comes from console5's board-reads, and is cited as the secondary source it is.[1]
How the Dreamcast is numbered
On the logic board, aluminium electrolytics carry CE designators — CE103, CE301 to CE310, CE401, CE403, CE503, CE601, and the CE7xx and CE8xx positions on later boards.[1] Plain C numbers on a Dreamcast belong to the GD-ROM board or the power supply, which use their own sequences.
A logic-board capacitor list built out of consecutive plain C designators is therefore not describing this machine, whatever the values say.
Identify the board
Revision Notes
VA0 Earliest logic board. No CE103, CE302, CE307 or CE601 fitted
VA1 837-13778 / 171-7965C. The most common board
VA2.1 Adds the CE7xx and CE8xx positions and drops CE503
All Dreamcast consoles have an internal, mains-powered supply. There is no revision that takes an external power brick: console5 lists internal supply boards for both 110 V markets (171-7874A, -7874A-X1, -7874B, -7874B-X2, 171-7962A, -7962A-X1, 171-7970A, -7970A-X2) and 220–240 V markets (171-7960A, PWR UNIT PANA EU V01, ETXSE239E2C).[1] Any guide that says a Dreamcast revision uses an external PSU and needs no internal supply work is wrong, and following it would leave the most failure-prone board in the machine untouched.
Logic boards
VA0 logic board[1]
Value Designators
10 µF 16 V CE301, CE310
10 µF 10 V, bipolar CE303, CE304
22 µF 6.3 V CE305, CE306
47 µF 16 V CE308
4.7 µF 35 V (25 V acceptable) CE309
220 µF 6.3 V CE401
100 µF 6.3 V CE403
47 µF 25 V CE503
VA1 logic board, 837-13778[1]
Value Designators
47 µF 16 V CE103, CE308
10 µF 16 V CE301, CE302, CE310
100 µF 16 V CE307
220 µF 6.3 V CE401
100 µF 6.3 V CE403
47 µF 25 V CE503
47 µF 6.3 V CE601
VA2.1 logic board[1]
Value Designators
100 µF 16 V CE307, CE801, CE802, CE805, CE808
220 µF 6.3 V CE401
100 µF 6.3 V CE403, CE701, CE807
47 µF 6.3 V CE601, CE803, CE804, CE806
47 µF 25 V CE809
CE303 and CE304 are bipolar parts. They are non-polarised by design and must be replaced with bipolar capacitors, not with ordinary polarised electrolytics fitted "the right way round".[1]
The controller-interface and battery board carries one capacitor, CE1, 47 µF 16 V, on every revision.[1]
GD-ROM optical boards
GD-ROM boards[1]
Board Value Designators
XU937 47 µF 6.3 V C2
100 µF 6.3 V C3, C10, C14, C17, C61
100 µF 16 V C20, C122
XV779 / KS-7S 100 µF 6.3 V C10, C14, C17, C61, C511
100 µF 16 V C20, C509
47 µF 6.3 V C127, C203, C205
171-8129A 100 µF 6.3 V C10, C14, C17, C61, C513, C520
On the XV779 board, C510 is an empty position.[1]
The other common GD-ROM fault is mechanical rather than electrical: the plastic spur gears in the optical drive strip, which stops the sled moving. console5 hosts an installation guide for replacement gears.[1] A drive that spins a disc but never reads it is worth checking for a stripped gear before the laser is condemned.
Power supplies
The supply board is the one board in a Dreamcast that carries mains potential, and its bulk capacitor stores charge after the lead is pulled: 100 µF at 200 V on 110 V units, 47 µF at 400 V on 220–240 V units.[1] Unplug the console, measure across that capacitor and discharge it through a resistor before working. Done that way this is ordinary repair work, and on a machine of this age the supply is usually the board most in need of it.
Power supply boards[1]
171-7874A, -7874A-X1, -7874B (110 V; usually paired with VA0) 100 µF 200 V C3
47 µF 35 V C10
1000 µF 25 V C13
220 µF 25 V C16
2200 µF 10 V C17, C21
1500 µF 6.3 V / 470 µF 10 V C20 / C22
171-7874B-X2, 171-7962A, -7962A-X1, 171-7970A, -7970A-X2 (110 V; usually VA1 and VA2.1) 100 µF 200 V C3
47 µF 35 V C10
470 µF 35 V C52
470 µF 16 V C53
2200 µF 10 V C54
470 µF 10 V C56
3300 µF 10 V / 1000 µF 10 V C58 / C59
171-7960A, PWR UNIT PANA EU V01, ETXSE239E2C (220–240 V) 47 µF 400 V C006
1800 µF 16 V C101, C201
1200 µF 10 V C103
470 µF 16 V C204
1000 µF 25 V (35 V on some units) C301, C302
The switching controller on the supply is an FA5317.[1]
IC map, VA1 171-7965C
Useful when tracing a rail back to what it feeds.[1]
Designator Device Function
IC101 SH-4 Main CPU
IC102, IC103 64 Mbit SDRAM Main memory
IC104 PQ07VZ1H2Z Series regulator
IC106 RN5RG25A CMOS regulator — the fitted part is tied to the Holly variant: 313-5612 with a 315-6201 or 315-6225, 313-5553 with a 315-6226
IC201 315-6201 / 315-6225 / 315-6226 Holly graphics engine
IC202–IC205 16 Mbit SDRAM Video memory
IC206 RN5VD27A Power-on reset
IC301 315-6119 / 315-6232 AICA sound processor
IC302 16 Mbit SDRAM Sound memory
IC303 PCM1725 Audio DAC
IC305 W129A Clock generator
IC401 BU1426KS RGB encoder
IC501 MPR-21931 Boot ROM
Doing the work
  1. Unplug the console. Remove the modem, then the case screws, then the top shell.
  2. Take the power supply out and discharge its bulk capacitor before anything else.
  3. Note the orientation of every connector before unplugging it.
  4. Lift the surface-mount parts on the logic board with hot air or two irons, never by levering.
  5. Clean each footprint with isopropyl alcohol and inspect under magnification — see Battery Explosion, Capacitor or Corrosion Damage if anything has leaked.
  6. Fit 105 °C low-ESR parts at the original values, bipolar where the original was bipolar, stripe to the negative end.
  7. Reassemble and test before closing the case.
General tooling is on Recommended Tools; what each failure mode looks like is on Capacitor Failure Symptoms.
After the recap
This wiki has not found a source that publishes the Dreamcast's rail voltages and tolerances — Sega's hosted schematics do not tabulate them — so no voltage table is given here rather than a guessed one. What can be checked without one:
  • the console powers up and reaches the boot animation with no disc;
  • audio is clean on both channels, which exercises the AICA, the PCM1725 and the capacitors around them;
  • video is stable and free of noise;
  • the GD-ROM spins up, the sled moves smoothly and a game disc loads;
  • the machine still works after twenty minutes warm, which is when a marginal supply shows itself.
  1. 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 console5 TechWiki, Dreamcast, https://wiki.console5.com/wiki/Dreamcast . Secondary source — capacitor lists read off real boards for the VA0, VA1 and VA2.1 logic boards, the GD-ROM optical boards, the controller interface board and the power supply units, together with the IC map for the VA1 171-7965C board. No Sega Dreamcast service manual with a parts list is hosted on this wiki, so this is the only component-level source cited here.
