Video Board Schematic
Revision as of 02:08, 25 September 2026 by Josh (talk | contribs) (P4 verification: real documentation page — title-block identification, the drawing's own service notes and values, and the C22/C27 and VR1 facts it settles)
Schematic, Service, Display Circuit — Commodore Business Machines, Inc.'s service schematic for the Commodore PET 2001 display assembly. One large sheet, scanned at 400 dpi.
"Video board" is this wiki's word, not Commodore's. Commodore calls it the display assembly, and it is the machine's power supply as well as its monitor.
What is on the sheet
The full component-level circuit of the display assembly: the mains transformer T1, the CR19–CR22 bridge, the 4700 µF reservoir C1, regulator VR1 producing +12 V, the −30 V rail, the +85 V boost rail, the horizontal output stage around Q14 and flyback T2, and the CRT anode supply of roughly +10 kV. Values are printed against components on the drawing.
Fourteen oscilloscope waveform photographs are printed on the sheet at their test points. The vertical and timebase setting for each is not on this drawing — it is on a separate supplement, held here as Schematic Notes for Video Board. The two documents are useless apart.
The five service notes printed on the drawing
1. Adjust for best focus; voltage is selectable. 2. R20 is mounted perpendicular to the board for screwdriver adjustment. 3. R9 is at the rear of the PCB, on a 1/4-inch shaft about 2 inches long. 4. Board connectors are Molex 09-64-1021 and 09-64-1061. 5. On the flyback terminals and C25, the numbers in parentheses are for the DOK version — the alternative flyback, Commodore 902475.
The sheet marks flyback T2 as GI 294-7746.
What it does not contain
No parts list — for reference designators, values and Commodore part numbers see Video Board Parts List (1 of 3). No physical placement — for that see Video Board Parts Layout. Nothing about the main logic board, which is a separate set of drawings.
Two other revisions of this drawing are held here
Page Drawing number in the title block Title as printed Dates on the sheet
This page not numbered in the title block Schematic, Service, Display Circuit —
Video Board Schematic (Rev 2, 320032) 320032, rev A Display Schematic drawn 3-9-76; revised 3-17-77, 4-11-77, 6-15-77
Video Board Schematic (Rev 3, 320033) 320033, size D, rev P Schematic, Display Circuit drawn 5/78, engineered 6-29-78; next assembly 320012
The "Rev 2" and "Rev 3" in those page titles are this wiki's numbering, not Commodore's. The drawings' own revision marks are A and P respectively, and they are two different drawing numbers, not two revisions of one. Check the number in the title block against your own board before working from either.
Commodore Schematic, Service, Display Circuit for the PET 2001, with its 14 waveform photographs.
Download: video-1.gif
