Apple Lisa 2/5
Revision as of 11:23, 27 September 2026 by Josh (talk | contribs) (Verify against Apple's Lisa Level 1 Technical Procedures (hosted): replaced the unsourced 1.2 A / 0.7 A / 1.8 A 'DataPower' supply ratings with Apple's own part numbers (661-93108 / 661-93149 / 661-73172, plus motherboard and I/O board); Apple publishes no rail tolerance or PSU adjustment for the Lisa, only video adjustments; deleted the 'discrete Woz Machine on the 2/5, IWM only on the 2/10' claim as unsupported; sound is CVSD not PWM square wave; serial speed 38.4 kbps removed; added Apple'...)
Apple Lisa 2/5
Apple Lisa 2/5 with external ProFile drive
TypePersonal Computer
ReleasedJanuary 1984
DiscontinuedJanuary 1985
Intro priceUS$3,495 (with ProFile)
CPUMotorola 68000 @ 5 MHz
Memory512 KB RAM (expandable to 2 MB)
Storage400 KB 3.5" floppy drive, external 5 MB ProFile hard drive
Display12" monochrome CRT (720×364 pixels)
SoundMono, via a continuously variable slope demodulator (CVSD)
Dimensions15.2" H × 18.7" W × 13.8" D
Weight48 lbs (22 kg)
OS / FirmwareLisa OS, Lisa Office System, MacWorks
PredecessorLisa 1
SuccessorApple Lisa 2/10
Model no.Apple part numbers: power supply 661-93108, motherboard 661-93106, I/O board 661-93198
The Apple Lisa 2/5 was a configuration of the Lisa 2 bundled with an external 5 MB ProFile hard drive, released in January 1984.[1] It replaced the original Lisa (Lisa 1) with its troublesome Twiggy floppy drives, offering a more reliable 3.5-inch Sony floppy drive and lower price point.
Overview
The Lisa 2/5 represented Apple's effort to make the Lisa more affordable and reliable. The "2/5" designation indicated the Lisa 2 hardware configuration paired with a 5 MB external ProFile drive. This configuration was the more affordable option compared to the Lisa 2/10, which included an internal 10 MB Widget drive.
Hardware Specifications
Processor and Memory
Component Specification
CPU Motorola MC68000 @ 5 MHz
Data Bus 16-bit external
Address Bus 24-bit
Base RAM 512 KB
Maximum RAM 2 MB (via memory board upgrades)
ROM 16 KB of bootstrap and self-test code
Device Specification
Floppy Drive Single 400 KB 3.5" Sony SS/DD drive
Hard Drive External 5 MB ProFile (parallel connection)
Floppy Format GCR multi-speed encoding
Floppy Eject Software-controlled
The Lisa 2/5 used a single 400 KB Sony 3.5-inch floppy drive, replacing the dual Twiggy 5.25-inch drives of the Lisa 1. The Sony mechanism was more reliable and used the same format as early Macintosh computers.
The external ProFile drive connects to the parallel port on the rear of the unit. Apple's error code 51 is "Parallel port VIA", which confirms the port is driven by a VIA and points the first replacement at the I/O board.[2]
Display
Specification Value
Screen Size 12" diagonal
Resolution 720 × 364 pixels
Display Type Monochrome CRT (black and white)
Refresh Rate 60 Hz vertical
Contrast Software-controlled, plus a hardware contrast adjustment on the video board that Apple's own fault table tells the technician to set to mid-range before condemning anything[2]
External Video RCA jack (non-standard composite output)
Input/Output
Port Description
Serial Ports 2 × RS-232C (25-pin). Apple names them RS232 port A and RS232 port B in its error codes 55 and 56[2]
Parallel Port External ProFile/printer connection
Keyboard Coiled cord to the I/O board; Apple part 661-93109[2]
Mouse DE-9 connector, single-button mechanical-optical
Expansion Slots 3× proprietary Lisa slots
Power Supply
The Lisa 2/5 uses the same supply as the Lisa 1: Apple part 661-93108 for the US machine and 661-93149 for the European one. The Lisa 2/10 uses a different part, 661-73172.[2]
Apple publishes no rail tolerance and no power-supply adjustment procedure for the Lisa. The only adjustments in the Level 1 procedures are video ones — horizontal phase, brightness and contrast, yoke and trim magnets.[2] Note also that Apple's video fault table lists "a sizzling noise coming from Lisa" and "power supply trips (turns off and on)" with brightness and contrast adjustment as the first two remedies, ahead of replacing the supply — so a Lisa that trips is not automatically a supply fault.
Differences from Other Lisa Models
Feature Lisa 1 Lisa 2/5 Lisa 2/10
Floppy Drive Dual Twiggy 5.25" Single Sony 3.5" 400K Single Sony 3.5" 400K
Hard Drive External ProFile External ProFile 5 MB Internal Widget 10 MB
Parallel Port External External Internal (for the Widget)
Power supply (Apple P/N) 661-93108 US, 661-93149 European 661-93108 661-73172
Motherboard (Apple P/N) 661-93106 661-93106 661-93170
I/O board (Apple P/N) 661-93104 661-93198 661-93171
Apple's parts lists confirm that the Lisa 2/10 has a different power supply, motherboard and I/O board from the Lisa 1 and Lisa 2.[2] Supply current ratings and a "DataPower" designation were previously given here and could not be sourced; the part numbers above are checkable and the amperages were not.
A row claiming the Lisa 2/5 uses "a discrete Woz Machine" disk controller and only the 2/10 an IWM has also been removed: nothing held here supports a split between the two Lisa 2 configurations on that point, and both read the same Sony 3.5-inch mechanism.
Software Compatibility
The Lisa 2/5 could run:
  • Lisa OS — Original Lisa operating system
  • Lisa Office System — Integrated office suite (LisaWrite, LisaCalc, LisaDraw, etc.)
  • MacWorks — Macintosh compatibility environment allowing Mac software to run on Lisa hardware
  • Xenix — Microsoft's UNIX variant (with appropriate configuration)
For detailed maintenance practices including cleaning, PRAM battery management, power supply care, and CRT handling, refer to the Apple Lisa General Maintenance page.
The I/O-board battery switch
Before treating a Lisa that has lost its clock as faulty, check the switch. Apple's set-up procedure: remove the back panel, find the set of four batteries on the lower right side of the I/O board, and make sure the switch next to them is set to ON (toward the left).[2] A Lisa shipped or serviced with that switch off will not keep time and is not broken.
The pack itself should come out of any machine being restored — see Apple Lisa Troubleshooting and Battery Explosion, Capacitor or Corrosion Damage.
A comprehensive troubleshooting guide addressing power issues, self-test error codes, display problems, and storage failures is available on the Apple Lisa Troubleshooting page.
Capacitor Replacement
The Lisa 2/5 contains electrolytic capacitors and a class-X mains safety capacitor that require replacement for long-term reliability. See the Apple Lisa Capacitor Replacement Guide for detailed specifications and procedures.
ProFile Hard Drive
The external ProFile drive included with the Lisa 2/5 was a 5 MB hard drive with its own Z8 microprocessor and error-sparing capabilities. ProFile drives were also prone to capacitor failures in their power supplies and should be recapped when servicing a Lisa system.
Modern alternatives to the ProFile include:
  • X/ProFile — Uses CompactFlash storage
  • IDEfile — Uses IDE drives or flash memory
  1. ↑ Apple Lisa, Apple History—link(accessed 2026-02-09)
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 Apple Computer, Apple Lisa Level 1 Technical Procedures (hosted here: Apple Lisa Level 1 Technical Procedures Mar85): Lisa Set-up 2.6 "Checking the Battery Switch"; Lisa 2 Diagnostics 5 "Interpreting the Boot ROM"; Lisa Troubleshooting Guide 6 and Appendix D "Start-up Error Codes"; Video Repair Procedures; and the Lisa 1, Lisa 2, Lisa 2/5, Lisa 2/10 and Macintosh XL Illustrated Parts Lists.
