Apple Lisa Level 1 Technical Procedures Mar85
The Lisa Level I Technical Procedures, Apple part number 072-0085, 415 pages. This copy is the March 1985 state of the manual. Like all Apple loose-leaf service manuals of the period, each section carries its own revision date rather than the manual having a single one.
This is the primary Apple service document for the Lisa, and it is a full technical-procedures manual, not a module-exchange guide: it includes CRT discharge, video adjustments, diagnostics and troubleshooting.
Contents, in Apple's own section numbering
[edit | edit source]- Section 1: Take-Apart - Introduction (p. 1.3), Replacing the Disk Drives (p. 1.4), Removing a Diskette from a Malfunctioning Disk Drive (p. 1.5), The Glare Filter (p. 1.6), The Mouse (p. 1.7), The Keyboard (p. 1.7), Replacing a CPU Board: Transferring the Video State Machine ROM (p. 1.8), Packing Instructions (p. 1.9)
- Section 2: Set-up - Introduction and Material Requirements (p. 2.3), Unboxing (p. 2.5), Installing the Pull-out Reference Cards (p. 2.5), Checking the Battery Switch (p. 2.6), Installing the Lisa Accessories (p. 2.7), Installing the ProFile (p. 2.8), Installing the Office System Software (p. 2.9), Putting the Icons in Order (p. 2.13), Installing an Apple Daisy Wheel Printer (p. 2.17), Installing an Apple Dot Matrix Printer (p. 2.18), Setting Preferences (p. 2.19), Setting the Clock (p. 2.20), Testing the System (p. 2.20), Before You Leave (p. 2.21), Appendix 1 Replacing a Single Tool on the ProFile (p. 2.22), Appendix 2 Set-up Checklist (p. 2.23)
- Section 3: Video Take-apart - Safety Precautions (p. 3.3), Discharging the CRT (p. 3.5), Removing the CRT (p. 3.9), and installation
- Video Adjustments, Diagnostics, Troubleshooting and the upgrade sections follow.
Two items stand out:
- Transferring the Video State Machine ROM when replacing a CPU board. This is a self-inflicted fault waiting to happen: fit a replacement CPU board without moving that ROM across and the machine will not produce a correct display, and the board will be blamed.
- Checking the battery switch during set-up. The Lisa's batteries are switchable, and a machine that loses its clock may simply have the switch off.
[edit | edit source]No circuit schematic and no component values. It is a procedures manual: the parts it names are assemblies and boards. It does not cover the Lisa's software beyond installing and testing the Office System.
The other Lisa service document here
[edit | edit source]Apple Service Technical Procedures Lisa/Macintosh XL is the same manual, 072-0085, at a different state: its volume table of contents is dated June 1986 and it adds the Lisa 2/10 upgrade and the Macintosh XL Screen Kit sections. Between the two, check both before concluding a procedure is absent.
Pages that cite this document
[edit | edit source]- Apple Lisa, Apple Lisa 2, Apple Lisa 2/5, Apple Lisa 2/10, Macintosh XL
- Apple Lisa General Maintenance, Apple Lisa Troubleshooting - the CRT discharge procedure and the take-apart order.
- MacWorks Manual
