Related changes
Enter a page name to see changes on pages linked to or from that page. (To see members of a category, enter Category:Name of category). Changes to pages on your Watchlist are in bold.
List of abbreviations:
- N
- This edit created a new page (also see list of new pages)
- m
- This is a minor edit
- b
- This edit was performed by a bot
- (±123)
- The page size changed by this number of bytes
27 September 2026
| 14:09 | Macintosh XL diffhist +5,267 Josh talk contribs (Cited and embedded Apple's own Lisa/Macintosh XL Service Technical Procedures, which was hosted on this wiki but linked from no page at all. Corrections from it: the Macintosh XL has NO built-in parallel port - Apple's configuration table gives that to the Lisa 2 only and says a Macintosh XL must have a parallel interface card fitted in the expansion chamber - so the infobox connectivity line and the Widget's 'direct parallel port connection' were both wrong; a Screen-Kit-modified Macintosh X...) | ||||
12:45 | Apple Lisa 2/10 5 changes history +2,289 [Josh (5×)] | |||
12:45 (cur | prev) +17 Josh talk contribs (House rule: reword in-article correction narrative to describe the claim in circulation rather than the page's own edit history) | ||||
12:35 (cur | prev) −6 Josh talk contribs (House rule: reword in-article correction narratives so they describe the claim in circulation and what the source says, rather than the page's own edit history. The corrections themselves are recorded in the edit summaries) | ||||
11:35 (cur | prev) −294 Josh talk contribs (Collapse duplicated <ref name=...> definitions to a single definition with the rest self-closing (duplicate definitions render as a visible red cite error)) | ||||
11:24 (cur | prev) +2,592 Josh talk contribs (Verify against Apple's Lisa Level 1 Technical Procedures (hosted): replaced unsourced 1.8 A / 1.0 A 'DataPower' supply ratings and the 'more reliable' claim with Apple's real part numbers (661-73172 supply, 661-93170 motherboard, 661-93171 I/O board, 661-93176 hard disk assembly); deleted the H/EA / H/88 / 3A boot-ROM version table as untraceable; deleted the 'IWM on the 2/10, discrete Woz Machine on the 2/5' claim; 80-85 are Apple's ProFile error group, not a 'generic Widget failure' at 82;...) | ||||
11:23 (cur | prev) −20 Josh talk contribs (De-link red link Apple ProFile - no such page exists) | ||||
12:36 | Apple Lisa Troubleshooting 3 changes history +4,690 [Josh (3×)] | |||
12:36 (cur | prev) +2 Josh talk contribs (House rule: reword in-article correction narratives so they describe the claim in circulation and what the source says, rather than the page's own edit history. The corrections themselves are recorded in the edit summaries) | ||||
11:27 (cur | prev) +4,695 Josh talk contribs (Verify against Apple's Lisa Level 1 Technical Procedures (hosted): DELETED the banded error-code table (there are no codes in the 10s; 22/23/25 are diskette faults, CPU-board codes are 40-49, and 82 is not a 'generic Widget failure' - Apple groups 80-85 as ProFile errors) and replaced it with Apple's full Appendix D table with its own replacement order; deleted the '24+ hours' discharge interval (verify with a meter instead), the unverified RIFA brand attribution, and the unsourced focus-on-f...) | ||||
11:05 (cur | prev) −7 Josh talk contribs (Remove emoji from section headings - the rebuilt pages across this wiki use plain headings, so these were batch drift rather than house style) | ||||
12:35 | Apple Lisa 2/5 4 changes history +2,672 [Josh (4×)] | |||
12:35 (cur | prev) −2 Josh talk contribs (House rule: reword in-article correction narratives so they describe the claim in circulation and what the source says, rather than the page's own edit history. The corrections themselves are recorded in the edit summaries) | ||||
11:35 (cur | prev) −405 Josh talk contribs (Collapse duplicated <ref name=...> definitions to a single definition with the rest self-closing (duplicate definitions render as a visible red cite error)) | ||||
11:23 (cur | prev) −38 Josh talk contribs (De-link red link Apple ProFile - no such page exists) | ||||
11:23 (cur | prev) +3,117 Josh talk contribs (Verify against Apple's Lisa Level 1 Technical Procedures (hosted): replaced the unsourced 1.2 A / 0.7 A / 1.8 A 'DataPower' supply ratings with Apple's own part numbers (661-93108 / 661-93149 / 661-73172, plus motherboard and I/O board); Apple publishes no rail tolerance or PSU adjustment for the Lisa, only video adjustments; deleted the 'discrete Woz Machine on the 2/5, IWM only on the 2/10' claim as unsupported; sound is CVSD not PWM square wave; serial speed 38.4 kbps removed; added Apple'...) | ||||
12:35 | Apple Lisa 2 4 changes history +7,661 [Josh (4×)] | |||
12:35 (cur | prev) 0 Josh talk contribs (House rule: reword in-article correction narratives so they describe the claim in circulation and what the source says, rather than the page's own edit history. The corrections themselves are recorded in the edit summaries) | ||||
11:35 (cur | prev) −5,577 Josh talk contribs (Collapse duplicated <ref name=...> definitions to a single definition with the rest self-closing (duplicate definitions render as a visible red cite error)) | ||||
11:22 (cur | prev) +104 Josh talk contribs (Remove the unsourced 65 ms Widget seek time and the invented 394-590 RPM range; cite Apple's hard disk assembly part number) | ||||
11:22 (cur | prev) +13,134 Josh talk contribs (Verify against Apple's own Lisa Level 1 Technical Procedures (hosted): DELETED 'Lisa 2/10 has two floppy drives' - Apple states twice that 'Lisa 2, 2/5, and 2/10 have only one disk drive'; deleted the R38/R39 voltage-adjustment potentiometers (Apple publishes no rail tolerance or PSU adjustment for the Lisa - only video adjustments), the invented serial-number prefix table, the port speed/AppleTalk table (ports are RS-232, no AppleTalk hardware), the unsourced upgrade prices and the 65 ms Wid...) | ||||
| 08:58 | Apple Lisa General Maintenance diffhist +176 Josh talk contribs (Link the documentation page for each cited manual, keeping the File: link as the direct download) | ||||
25 September 2026
08:54 | Apple Lisa 2 3 changes history +1,391 [Josh (3×)] | |||
08:54 (cur | prev) +469 Josh talk contribs (P4 verification: link Apple's own Macintosh XL Screen Kit manual, hosted here, from the Lisa 2 documentation section) | ||||
08:00 (cur | prev) +16 Josh talk contribs (repair red link: point MacWorks at the hosted MacWorks Manual page) | ||||
07:58 (cur | prev) +906 Josh talk contribs (cite Apple's Lisa 2 owner's guides and technical procedures (P4 orphan fix)) | ||||
| 08:54 | Macintosh XL diffhist +1,033 Josh talk contribs (P4 verification: cite Apple's own Macintosh XL Screen Kit manual (030-1240-A, hosted here) for the startup key combinations, and say what it does not contain) | ||||
| 08:53 | Apple Lisa Troubleshooting diffhist +1,315 Josh talk contribs (P4 verification: cite Apple's own Lisa start-up error tones, icons and codes (rev. 5/17/83) from the hosted Technical Procedures binder, and say plainly that the extract is partial) | ||||
08:05 | File:Apple Lisa Level 1 Technical Procedures Mar85.pdf 2 changes history +704 [Josh (2×)] | |||
08:05 (cur | prev) +62 Josh talk contribs (categorise this file page (P4 verification drive)) | ||||
08:04 (cur | prev) +642 Josh talk contribs (P4: real summary, source and licence for this file (verification drive)) | ||||
07:58 | Apple Lisa 2 changes history +1,037 [Josh (2×)] | |||
07:58 (cur | prev) +707 Josh talk contribs (cite Apple's Lisa owner's guide and Level I technical procedures (P4 orphan fix)) | ||||
02:31 (cur | prev) +330 Josh talk contribs (Link Apple's MacWorks manual, which was reachable from no article) | ||||
| 07:49 | Apple Service Technical Procedures Lisa/Macintosh XL diffhist +1,940 Josh talk contribs (P4: turn document holder into a real documentation page (verification drive)) | ||||
| 02:20 | MacWorks Manual diffhist +2,701 Josh talk contribs (P4 verification: real documentation page - contents, what each document settles, and honest classification (The Laser Writer Family 1992 is a third-party Business One Irwin book, not an Apple document)) | ||||
23 September 2026
23:35 | Apple Lisa 3 changes history +6,962 [Josh (3×)] | |||
23:35 (cur | prev) +471 Josh talk contribs (Verification drive: the Lisa 2/10 has one 3.5-inch drive plus the internal Widget, not two floppy drives, and a plain Lisa 2 cannot take an internal drive because its I/O board and motherboard do not support one; MacWorks is loaded from diskette, not a ROM emulator) | ||||
23:32 (cur | prev) +54 Josh talk contribs (House style: rephrase the corrections as statements about the figures themselves rather than about this page's own history) | ||||
23:13 (cur | prev) +6,437 Josh talk contribs (Verification drive: screen refresh is Apple's 60 Hz not 67 Hz and the dot rate is 20 MHz not a '25 MHz crystal'; removed the fabricated memory map, 'Lisa PDS' pinout table, 'Lisa ASIC', light-pen interface, ProDOS-derived filesystem and LisaTerminal-as-3270/Telnet claims; the ProFile connects to the built-in PARALLEL port, not AppleBus; memory is two 512 KB boards, Apple max 1 MB (2 MB third-party), not '4x 256Kx1 SIMMs, 1.5 MB'; removed the duplicated lead paragraph; fixed cabinet dimensions...) | ||||
23:32 | Apple Lisa General Maintenance 2 changes history +6,678 [Josh (2×)] | |||
23:32 (cur | prev) −1 Josh talk contribs (House style: rephrase the corrections as statements about the figures themselves rather than about this page's own history) | ||||
23:14 (cur | prev) +6,679 Josh talk contribs (Verification drive: added the four NiCd AA cells on the I/O board - the Lisa's most destructive failure, which this page never mentioned; RIFA values are C1 and C7 at 0.33 uF 250 V, not the 0.1/0.22/0.047 uF the page claimed; removed the +5/+12/-12 V rail table (Apple's Macintosh Plus procedure - the Lisa technical procedures contain no rail measurement at all); added Apple's boot/IO ROM code pairs, disk controller ROM numbers, video adjustment guidance, memory board rules and the 15 kV CRT w...) | ||||
