Macintosh LC II
The Macintosh LC II is a low-profile desktop Macintosh that Apple introduced on 23 March 1992 to replace the Macintosh LC. It replaces the LC's 68020 with a 68030 and doubles the memory soldered to the board to 4 MB, but keeps the LC's case, 16-bit data path, 96-pin expansion slot and 10 MB memory limit.[1][2] It was sold as the Performa 400, 405, 410 and 430 in the consumer market.[3]
| Macintosh LC II | |
| Released | 23 March 1992 |
| Discontinued | 15 March 1993 |
| Intro price | US$1,699 (4 MB RAM, 40 MB hard disk) |
| CPU | Motorola 68030 at 16 MHz (15.6672 MHz), 16-bit data path |
| Memory | 4 MB on the logic board, two 30-pin SIMM slots, 10 MB usable maximum (100 ns) |
| Storage | 40, 80 or 160 MB internal SCSI hard disk |
| Display | — |
| Sound | 8-bit mono input and output |
| Graphics | Built in (DB-15), 256 KB or 512 KB VRAM SIMM |
| ROM | 512 KB, socketed |
| FPU / coprocessor | None; decoding for an optional 68882 on a PDS card |
| Media | 1.4 MB Apple SuperDrive |
| Ports / interface | ADB, two RS-232/RS-422 serial (mini DIN-8), SCSI (DB-25), video (DB-15), sound in, sound out |
| Expansion | 96-pin processor-direct slot (4 W) |
| Power | 100–240 V AC auto-configured, 47–63 Hz, 50 W maximum |
| Dimensions | 3.0 × 12.2 × 15.0 in (7.7 × 31.0 × 38.2 cm) |
| Weight | 8.8 lb (4.0 kg) |
| OS / Firmware | System 6.0.8 or 7.0.1 to Mac OS 7.6.1 |
| Predecessor | Macintosh LC |
| Successor | Macintosh LC III |
| Model no. | M1700 (Gestalt ID 19 under System 7.0.1, 37 under 7.1) |
History
Apple's launch price was US$1,699 with 4 MB of RAM and a 40 MB hard disk.[3] Apple's developer note puts its performance slightly above the LC's and notes that the 68030 supports System 7's virtual memory.[1] The Performa 400 followed on 14 September 1992, the Performa 405 and 430 on 12 April 1993 and the Performa 410 on 18 October 1993.[3] Apple's service manual for the Performa 400 series lists the 405 and 410 with 80 MB drives and the 430 with 120 MB, and the 410 with a manual-insert floppy drive.[4] The LC III replaced the LC II in February 1993, and Apple sold an LC III logic board upgrade for it.[3][2]
| Item | Figure |
| Processor | Motorola 68030 at 16 MHz, 16-bit internal data bus, burst-mode RAM access |
| DRAM | 4 MB standard, expandable to 10 MB (100 ns or faster SIMMs) |
| ROM | 512K |
| VRAM | 256K VRAM SIMM, upgradable to 512K |
| Floppy drive | 1.4 MB Apple SuperDrive |
| Hard drive | 40, 80 or 160 MB |
| Serial | Two RS-232/RS-422 ports, mini DIN-8 |
| Video | DB-15 port for built-in video |
| Sound | Mono input and output ports (mini phono); 8-bit input at 11 or 22 kHz; monophonic 8-bit generator feeding the same signal to both channels |
| Expansion | 96-pin processor-direct slot for 020 or 030 direct-slot cards |
| Power | 100–240 V AC, automatically configured, 47–63 Hz; 50 W maximum, not including the monitor |
| Size and weight | 3.0 × 12.2 × 15.0 in (7.7 × 31.0 × 38.2 cm); 8.8 lb (4.0 kg) |
Differences from the LC
Apple's developer note lists the changes from the LC: a 68030 in place of the 68020; 4 MB soldered to the board where the LC has 2 MB (both reach 10 MB); no second internal floppy connector, and no support for extra internal or external floppy drives; a microphone kit without the phono adapter plug; and a slightly modified case.[1] The ROM adds support for the 68030's memory management unit and virtual memory, and supports 4 MB on the board plus up to 6 MB of expansion RAM.[1] Recap-a-Mac's photographed logic board is marked 820-0327, copyright 1991, "Macintosh LC II".[5]
Memory
The two 30-pin SIMM slots take 100 ns or faster SIMMs. EveryMac notes that the SIMMs must be installed as an equal pair.[6] With two 4 MB SIMMs the machine holds 12 MB but addresses only 10 MB; Apple documents this as a limit, not a fault.[2]
Video
The VRAM is on a SIMM. With 256 KB the LC II drives 512 × 384 in monochrome or 8-bit colour on the 12-inch RGB monitor and 640 × 480 in monochrome or 4-bit colour on the 13-inch RGB monitor. A 512 KB SIMM adds 16-bit colour on the 12-inch monitor and 8-bit colour on the 13-inch.[1]
Floating-point unit
The LC II has no FPU and no socket for one on the logic board. The V8 gate array decodes a 68882 on an expansion card, and the FPU select signal is on the processor-direct slot.[1] Recap-a-Mac notes that the board was laid out so that an FPU could be fitted and shows a board with a PLCC socket added.[5]
Expansion slot
The 96-pin processor-direct slot is physically and electrically the same as the LC's 68020 Direct Slot, and Apple limits a card to 4 W (800 mA at +5 V). On the LC II the FC3 signal is always high, so cards are always addressed in 32-bit mode.[1]
Battery, power supply and capacitors
The PRAM battery is Apple part 742-0011, a lithium cell; Apple's test is to replace it below 3.0 V.[2] The power supply is the part shared by the whole LC family, 661-1733.[2] The logic board has seventeen surface-mount electrolytic capacitors.[5] See Macintosh LC II General Maintenance and Macintosh LC II Capacitor Replacement Guide.
Known faults and service notes
- An eight-tone error chord at startup points to the SIMMs; a four-tone chord on the LC II points to the hard disk or floppy drive, found by disconnecting each and rebooting.[2]
- A machine that shuts down or restarts intermittently may be in thermal shutdown: check that the vents on the back and top of the case are clear; it should recover after 30 to 40 minutes.[2]
- If the fan is replaced, it must go in logo side down; Apple warns that otherwise it may damage the computer.[2]
- After fitting an upgrade board or top cover, check that the sound-out and sound-in plugs are in the right ports; Apple warns that the wrong port can damage the computer or the equipment.[2]
Symptom tables are on Macintosh LC II Troubleshooting.
Upgrades
Apple's service manual gives three board upgrades: the LC II upgrade kit (for an LC), the LC III upgrade, which on an LC II uses only the kit's LC III logic board, fan and top cover, and the LC 475 logic board upgrade.[2]
- Macintosh LC Series/Quadra 605 Service Source: Macintosh LC Series/ Quadra 605 Service Source
- Macintosh Performa 400 Series Service Source: Macintosh Performa 400 Series Service Source
- Macintosh LC II Computer Developer Note: Macintosh LC II Developer Note
- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Apple Computer, Macintosh LC II Computer Developer Note (1992), File:Macintosh LC II Developer Note.pdf (see Macintosh LC II Developer Note): chapter 1, pp. 2-7 (major features, design differences, compatibility issues, mathematics coprocessor); chapter 2, p. 10 (ROM changes, Gestalt ID).
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 Apple Computer, Macintosh LC Series/Quadra 605 Service Source, File:Quadra 605.lc series.pdf (see Macintosh LC Series/ Quadra 605 Service Source): Specifications, PDF pp. 6-17; symptom charts, PDF pp. 20-36; Take Apart, PDF pp. 38-63; Upgrades, PDF pp. 68-86; Battery Verification, PDF pp. 106-107; Exploded View, PDF p. 112.
- ↑ 3.0 3.1 3.2 3.3 Macintosh LC II, Wikipedia—link(accessed 2026-09-30) Introduced 23 March 1992 at US$1,699 (Apple press release, 23 March 1992), discontinued 15 March 1993; Performa 400 introduced 14 September 1992, Performa 405 and 430 on 12 April 1993, Performa 410 on 18 October 1993; Apple's US$599 LC III logic board upgrade (Apple press release, 9 February 1993).
- ↑ Apple Computer, Macintosh Performa 400 Series Service Source, File:Performa 400 series.pdf (see Macintosh Performa 400 Series Service Source), Specifications, PDF pp. 3-15; exploded view, PDF p. 78.
- ↑ 5.0 5.1 5.2 Macintosh LC II (Performa 400), Recap-a-Mac—link(accessed 2026-09-30) Annotated photograph of logic board 820-0327, hosted here as File:Mac LC II Recap Guide.jpg; 17 electrolytics; notes that the board was designed so an FPU could be fitted but Apple left the socket off to save cost.
- ↑ Apple Macintosh LC II Specs, EveryMac—link(accessed 2026-09-30) Model M1700; order numbers M1701LL/A, M1723LL/A, M1707LL/A, M1387LL/A and M1720LL/A (education, floppy only); SIMMs as an equal pair; Gestalt ID 19 under System 7.0.1, 37 under 7.1; battery 3.6 V lithium; System 6.0.8 or 7.0.1 to 7.6.1.
