Commodore PET 4000 Series Maintenance Guide
Revision as of 09:56, 1 October 2026 by Josh (talk | contribs) (C2 is 470 uF 16 V per drawing 8032090; drop uncited LM323 rating, symptom list and CRT claims; trim RIFA paragraph; copyedit)
Commodore PET 4032 with the top panel lifted.
Routine care of the Commodore PET 4000 Series covers cleaning, supply checks, the keyboard, the sockets and the CRT hazards. For fault-finding see Commodore PET 4000 Series Troubleshooting Guide.
The electrical figures come from Commodore's PET 4000 Series Technical Manual, P/N 990438, hosted here.[1]
The 4000 series uses the universal dynamic PET board, not the static board of the Commodore PET 2001. The rails, regulators and crystal differ, so figures do not carry between the two.
Before you start
  • Mains voltage is present at the switch, fuse and primary of T1 whenever the machine is plugged in.
  • C1 in the supply chassis is 23,000 µF.[1] Bleed it through a resistor before working near it.
  • The CRT holds its anode charge after power-off. Discharge it before working near the tube; see CRT Discharge Procedure.
Regular cleaning
Internal
  • Unplug the machine and discharge the CRT before lifting the top.
  • The top lifts on its hinge to expose the logic board and the display.
  • Use compressed air and an anti-static brush on the logic board, particularly around the ROM and RAM sockets and the regulator heatsinks, and around the CRT neck board.
  • Use isopropyl alcohol (over 90 %) on swabs for stubborn areas. Do not soak the board.
External
  • Mild soap on a damp microfibre cloth for the painted steel case.
  • Glass cleaner sprayed onto a lint-free cloth, never onto the tube.
What is where
Assembly Contents Regulators
Supply chassis (drawing 8032051) Transformer T1, 23,000 µF filter C1, fuse F1 (1.6 A slow-blow, 125 V), rocker switch SW1 None
Logic board (drawing 8032090) Bridges CR2/CR4, diodes CR1/CR5/CR7, zeners VR5/VR6 VR1, VR2, VR4
Regulators and rails
Ref Device Rail Commodore part no.
VR4 LM323 +5 V 901528-01
VR2 7812, TO-3 +12 V, 1 A 901528-04
VR1 7905, TO-220 −5 V, 1.5 A 901527-03
The +5 V regulator is an LM323, not a 7805; replace it with an LM323.[1] The −5 V rail from VR1 does not exist on the PET 2001's static board.
What to inspect
  • Transformer and the rectifier area for heat stress, discoloured board and corrosion.
  • Solder joints at VR1, VR2 and VR4 and at bridges CR2 and CR4. These are thermally cycled, heavy-current joints and a cracked one produces an intermittent that mimics a failing chip.
  • The regulator heatsinks and the thermal compound under them. Commodore fits heatsinks and thermal compound to this board because these parts run hot.[1]
  • The supply-chassis drawing lists one capacitor, C1, the 23,000 µF filter on the low-voltage side, and no mains suppression capacitor.[1]
Voltage test points
Where to measure
Rail Where Note
+5 V VR4 output, or 6502 (UB14) pin 8 Pins 1 and 21 are ground; pin 40 is RESET, not a supply pin
+12 V VR2 output 1 A device
−5 V VR1 output 1.5 A device
Unregulated Across C1 in the supply chassis 23,000 µF. Treat with respect
Commodore's drawings give no tolerance for these rails; work to the regulators' data-sheet figures. A rail well off nominal points at the regulator, its heatsinking or the filtering ahead of it.
Capacitors
Commodore's list for the logic board gives these electrolytics and tantalums.[1]
Universal dynamic PET board, electrolytics and tantalums
Ref Value Type Commodore part no.
C1, C16, C17, C23, C24 10 µF 25 V Low-leakage electrolytic 900109-03
C2 470 µF 16 V Electrolytic 900100-44
C5 4700 µF 25 V Electrolytic 900100-45
C7, C11 47 µF 16 V Electrolytic 900101-37
C6, C51 1 µF 35 V Tantalum 900402-13
Commodore lists C1, C16, C17, C23 and C24 as low-leakage parts; fit low-leakage electrolytics there, and tantalums at C6 and C51. The rest of the C1-C97 range on this board is ceramics and mica. The bulk filter, C1 in the supply chassis, is a separate 23,000 µF can.[1]
See Capacitor Failure Symptoms.
Keyboard
The 4000-series machines use a full-travel keyboard.
  • Remove the keyboard from the chassis and photograph the keycap layout before taking anything apart.
  • Clean the contact pads on the PCB with isopropyl alcohol.
  • Inspect for lifted traces and corroded vias, and check the connector at both ends. A whole dead row or column points at the connector or a broken trace, not a single key.
  • Conductive paint will restore a worn pad but does not last as well as the original plating.
Sockets
Commodore's board drawing lists 24-pin and 40-pin low-profile IC sockets and a 14-pin socket, so most of the large devices are socketed.[1] Sockets of this age lose contact pressure: remove suspect devices with a proper puller, clean the pins and the socket, and reseat firmly. Replace failed sockets with turned-pin types.
If the tube does not light at all, the fault is in the heater supply or the EHT section, not the logic board.
The technical manual has PCB waveform drawings for both displays, 321450 for the 12-inch and 321447 for the 9-inch, with the oscilloscope settings printed on each.[1]
The CRT retains a charge with the machine unplugged. Follow CRT Discharge Procedure before working near the tube.
Diagnostics
  • A PET diagnostic ROM or test harness will exercise RAM and ROM far faster than swapping chips.
  • A logic probe or scope on the Φ2 clock and the reset line shows whether the CPU is running. On this board the CPU must program the CRT controller before any picture appears, so a blank screen alone does not mean a dead video circuit.[2] Y1 on this board is 16 MHz.[1]
  • Running the machine for a few hours on a test pattern will surface marginal parts that pass a cold test. Watch the three regulators while it does.
Tools
  • ESD-safe driver set, chip puller, plastic spudger
  • Digital multimeter, CRT discharge tool
  • Isopropyl alcohol (99 %), contact cleaner, anti-static brush
  • Fine-tip temperature-controlled soldering iron, braid or pump
  • ESR meter, logic probe or scope
See Recommended Tools.
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 Commodore Business Machines, PET 4000 Series Technical Manual, P/N 990438, for models 4016 and 4032, hosted at Commodore PET 4000 Series Technical Manual. Drawing 8032090 Rev H, "PCB ASSY - UNIV. DYNAMIC PET": PDF pages 3-7 give the board capacitors by reference designator and Commodore part number (C1/C16/C17/C23/C24 10 µF 25 V low-leakage 900109-03; C2 470 µF 16 V 900100-44; C5 4700 µF 25 V 900100-45; C7/C11 47 µF 16 V 900101-37; C6/C51 1 µF 35 V tantalum 900402-13; C3/C4 0.022 µF ceramic; C52/C60/C61 0.01 µF ceramic; C74–C86 and C88 47 pF ceramic; C92 220 pF ceramic; C97 82 pF dipped mica) together with transistors Q1 and Q2 (TIP29) and the piezo-acoustic transducer MT1; sheet 4 gives the diodes CR1/CR5/CR7 (1N4005), bridges CR2 and CR4 (4 A/50 V), CR3 (1N5402), the three voltage regulators, VR1 a 7905 at −5 V/1.5 A (901527-03, TO-220), VR2 a 7812 at +12 V/1 A (901528-04, TO-3) and VR4 an LM323 (901528-01); the 7.5 V zeners VR5 and VR6, the 16 MHz crystal Y1 (900556-02), the socket and header list, the 2.2 µH inductors L1 and L2, and the heatsinks. Drawing 8032051, "Power Supply Assy" (PDF p. 39): transformer T1 (320902-01) on universal power chassis 8032043-02, filter capacitor C1 of 23,000 µF (900102-01), the dynamic PET power harness 320289-01, fuse F1 125 V slow-blow 1.6 A (903557-04), fuse holder XF1 and rocker switch SW1; no voltage regulator and no mains suppression capacitor. Waveform drawings 321450 (12-inch display) and 321447 (9-inch display).
  2. ↑ André Fachat, PET repairs—link(accessed 2026-10-01)
