Atari 1025 Documentation
Revision as of 22:19, 1 October 2026 by Josh (talk | contribs) (New page: describe the hosted service manual, Sams service data and owner's guide, with contents and gaps)
The Atari 1025 documentation below comprises Atari's field service manual for the Atari 1025 printer, Howard W. Sams & Co.'s Computerfacts service data for it, and Atari's owner's guide.
Atari 1025 Printer Field Service Manual
The 1025 Printer Field Service Manual is Atari's service manual for the printer, part number FD100290 Rev. 01, dated June 1983. The hosted scan has 82 pages, including the oversize silkscreen and schematic.
Contents
Section Title Pages
Introduction vii
1 Theory of operation: print head, space, ribbon feed, paper feed, paper lock release and paper end mechanisms; 8051, 8155, 2732, power supply and print head electronics 1-1 to 1-9
2 Silkscreen and schematic (oversize, folded in) 2-1
3 Maintenance, testing and troubleshooting: equipment, precautions, cleaning, diagnostic program, command codes, ROM self test, command code failures 3-1 to 3-7
4 Disassembly, adjustment and assembly, with exploded drawings: covers, board, printer unit, transformer, print head, carriage, space motor and belt, platen, and the four adjustments 4-1 to 4-19
5 Diagnostic flowchart 5-1 to 5-20
6 Symptom checklist 6-1
7 Parts list: mechanical and electronic 7-1 to 7-3
8 Service bulletins 8-1
  • Capacitor and resistor part numbers; the electronic parts list covers semiconductors only. Capacitor values appear on the schematic, without voltage ratings.
  • Ribbon or paper part numbers.
  • Any service bulletins; section 8 only describes the kinds of bulletin.
Pages that cite this manual
Download: Atari 1025 Printer Field Service Manual FD100290 Rev 01.pdf
Sams Computerfacts CP21, Atari Model 1025 Printer
Computerfacts CP21 is Howard W. Sams & Co.'s technical service data for the 1025, dated August 1986, 27 pages.
Contents
From the index (printed page numbers): schematics, 2 and 3 (page 3 is the power supply); main board photographs, 5, 6, 11 and 12; parts list, 7 to 9; test equipment and troubleshooting, 10; logic chart, safety precautions and schematic notes, 13; disassembly instructions and miscellaneous adjustments, 14; line definitions, 15; IC pinouts and terminal guides, 16; block diagram. An enclosed set of preliminary service checks gives the replacement parts list, adjustments, an interconnecting diagram and numbered service checks.
  • Voltage ratings for the large electrolytic capacitors; the parts list rates only C3, C4, C11, C12, C13 and C15.
  • Atari part numbers.
Pages that cite this document
Download: Sams Computerfacts CP21 Atari 1025 Printer.pdf
The Atari 1025 Printer Owner's Guide
The Atari 1025 Printer Owner's Guide is the 16-page guide packed with the printer. It covers the controls, connecting the printer, installing the ribbon and roll, fanfold or single-sheet paper, a first BASIC test, troubleshooting questions (faded print, paper feed, ribbon feed, no power and the fuse rating) and the control codes for print pitch, line spacing, line length and the European characters. The hosted PDF was assembled from page images.
Pages that cite this guide
Download: Atari 1025 Printer Owner's Guide.pdf
