Macintosh Performa 5400CD
Revision as of 12:00, 10 February 2026 by Josh (talk | contribs) (Updated infobox image to use Macintosh Performa 5200.jpg from Commons (same case design as 5400))
ReleasedApril 22, 1996
DiscontinuedFebruary 1, 1997
CPUPowerPC 603e @ 120 MHz
Memory16 MB RAM (expandable to 136 MB)
Storage1.6 GB IDE hard drive, 4X CD-ROM
Display15" shadow mask CRT (640ร—480 16-bit, 832ร—624 8-bit)
Sound16-bit stereo output, 16-bit mono input, SRS surround
Dimensions17.5" H ร— 15.1" W ร— 16.0" D (44.5 ร— 38.4 ร— 40.6 cm)
Weight47 lbs (21.3 kg)
OS / FirmwareSystem 7.5.3 โ€“ Mac OS 9.1
PredecessorPerforma 5300
SuccessorPerforma 5500
CodenameAlchemy, Excalibur
Model no.M3046
Model Variants
The Performa 5400 series includes several regional and speed variants sharing the same Alchemy logic board:
Model CPU Speed CD-ROM RAM HDD Case Region
Performa 5400CD 120 MHz 4X 16 MB 1.6 GB Platinum Worldwide
Performa 5410CD 120 MHz 4X 16 MB 1.6 GB Platinum Europe
Performa 5420CD 120 MHz 4X 16 MB 1.6 GB Platinum Asia
Performa 5400/160 160 MHz 8X 16 MB 1.6 GB Platinum Europe/Asia
Performa 5430 160 MHz 8X 16 MB 1.6 GB Platinum Europe
Performa 5440 180 MHz 8X 16 MB 1.6 GB Black Europe/Asia
The educational versions were sold as the Power Macintosh 5400/120, 5400/160, and 5400/180 in North America.
Processor
The Performa 5400CD uses a PowerPC 603e processor running at 120 MHz on a 40 MHz system bus.[1] The 603e is a 32-bit processor with a 64-bit data path and integrated floating-point unit. Higher-speed variants used 160 MHz or 180 MHz versions of the same processor.
Cache
The processor includes 32 KB of L1 cache (16 KB instruction, 16 KB data). An optional 256 KB L2 cache DIMM slot is available. The 120 MHz and 180 MHz models shipped without L2 cache by default, while higher configurations often included it.
Memory and Storage
RAM Configuration
The Performa 5400 series uses 168-pin 70 ns DIMM modules, the first use of this memory type in the LC line. The logic board includes 8 MB of soldered RAM with two DIMM expansion slots supporting up to 136 MB total.
Video RAM
1 MB of system RAM is dedicated to video function. This VRAM allocation cannot be expanded.
Storage Systems
The base 5400CD includes a 1.6 GB IDE hard drive and 4X CD-ROM. Later models shipped with 8X CD-ROM drives. A 1.44 MB manual-eject floppy drive is standard. External SCSI devices are supported via the DB-25 SCSI port.
Display and Graphics
The built-in 15" shadow mask CRT supports:
  • 640ร—480 at 16-bit color (thousands of colors)
  • 800ร—600 at 16-bit color (higher-speed models)
  • 832ร—624 at 8-bit color (256 colors)
  • 1024ร—768 at 8-bit color (higher-speed models, external mirror only)
An external display can mirror the internal display at supported resolutions.
Audio Capabilities
The Performa 5400 series features enhanced audio capabilities including:
  • 16-bit stereo output via 3.5mm jack
  • 16-bit mono input via 3.5mm jack
  • Built-in stereo speakers
  • SRS surround sound support (first Macintosh with this feature)
  • Microphone included
Input/Output and Expansion
Port Configuration
  • 1ร— ADB port (keyboard and mouse)
  • 2ร— GeoPort serial ports (modem and printer, Mini DIN-8)
  • 1ร— DB-25 SCSI port (external devices)
  • 10Base-T Ethernet (built-in on some models, optional on others)
  • 3.5mm stereo audio output
  • 3.5mm mono audio input
Expansion Slots
The Alchemy logic board includes:
  • 1ร— 7" PCI slot (first PCI slot in an LC)
  • 1ร— Communications slot
  • 1ร— Video I/O slot
  • 1ร— TV tuner slot
For detailed maintenance practices including cleaning, PRAM battery management, connector corrosion prevention, and voltage adjustments, refer to the dedicated Macintosh Performa 5400 General Maintenance page.
Apple Service Manual
The Performa 5400 series shares service documentation with the Power Macintosh 5400 line.
Detailed capacitor replacement guidelines for the logic board can be found on the Macintosh Performa 5400 Capacitor Replacement Guide page.
Retrobrite
To address plastic yellowing (particularly on platinum models), detailed instructions can be found on the Retrobrite page.
A comprehensive troubleshooting guide addressing no power, video issues, intermittent operation, and common failure points is available on the Macintosh Performa 5400 Troubleshooting page.
System Architecture
Sub-system Specification
CPU PowerPC 603e @ 120/160/180 MHz
Bus Speed 40 MHz
Data Path 64-bit
ROM 4 MB
RAM 8 MB onboard + 2ร— DIMM (max 136 MB)
Video 1 MB (from system RAM)
Storage IDE hard drive, ATAPI CD-ROM, 1.44 MB floppy
Expansion 1ร— PCI, Comm slot, Video I/O slot, TV slot
Processor Specifications
Component Specification
CPU PowerPC 603e
Clock Speed 120/160/180 MHz (by model)
L1 Cache 32 KB (16 KB I + 16 KB D)
L2 Cache 256 KB (optional)
FPU Integrated
Data Bus 64-bit
Address Bus 32-bit
  1. โ†‘ Macintosh Performa 5400CD Specs, EveryMac.comโ€”link(accessed 2026-02-10)
