Sinclair ZX80 General Maintenance
The Sinclair ZX80 is a simple machine to look after. It has one internal supply rail, two electrolytic capacitors, no custom silicon and no battery. Most of what goes wrong with one is mechanical — keyboard tails, edge-connector contacts, dry joints — or comes in from the external power supply.
Observe ESD precautions when the board is out of the case. Use a wrist strap and an antistatic mat.
What the ZX80 actually is
editKnowing this saves you from applying ZX81 or Spectrum advice to a machine that does not work that way.
- There is no ULA. The ZX80's logic is twenty standard 74LS parts. Sinclair combined them into a single ULA to make the ZX81; nothing on a ZX80 board can be diagnosed as "a failed ULA".[1][2]
- The RAM is static. IC3 and IC4 are 2114 (1K × 4) static RAMs, giving the standard 1 KB. There is no DRAM, so there is no −5 V and no +12 V rail anywhere on the machine.[2]
- The regulator is IC22, a 7805 bolted to an aluminium heatsink. It is not "IC3" — IC3 is a RAM chip.[2]
| Ref | Type | Ref | Type |
| IC1 | 780-1 (Z80 CPU) | IC12 | 74LS00 |
| IC2 | 8332 (4 KB mask ROM) | IC13 | 74LS04 |
| IC3 | 2114 RAM | IC14 | 74LS05 |
| IC4 | 2114-1 RAM | IC15 | 74LS05 |
| IC5 | 74LS373 | IC16 | 74LS10 |
| IC6 | 74LS157 | IC17 | 74LS32 |
| IC7 | 74LS157 | IC18 | 74LS74 |
| IC8 | 74LS157 | IC19 | 74LS74 |
| IC9 | 74LS166 | IC20 | 74LS86 |
| IC10 | 74LS365 | IC21 | 74LS93 |
| IC11 | 74LS00 | IC22 | 7805 regulator |
Board revisions. No Sinclair-published list of ZX80 board issues has been found, and the unsourced revision table that used to appear here has been removed rather than guessed at. Photographs of Issue 3 and Issue 3A boards are held in the Sinclair ZX Computers Archive.[3] Your board's issue number is silkscreened on it — work from what is in front of you.
editThe ZX80 runs from an external, unregulated DC adaptor through a 3.5 mm mono jack.
| Property | Value | Source |
| Connector | 3.5 mm mono jack — the same size as the EAR and MIC sockets, so it is easy to plug into the wrong one | [4] |
| Polarity | Centre pin positive, shaft ground | [4][2] |
| Voltage | Nominal 9 V DC unregulated; about 14 V open-circuit. Sinclair's circuit diagram marks the input "9 V – 11 V" | [4][2] |
| Current | Sinclair published a figure for the ZX81 — not less than 600 mA, or 1.2 A if the ZX printer shares the supply — but no equivalent published figure for the ZX80 has been found | [5] |
Get the polarity right. A supply re-terminated the wrong way round is a known killer of the 5 V regulator on this family. On these machines the regulator usually dies and saves the rest of the board, but that is luck, not protection.[6]
The adaptor itself contains a mains transformer and rectifier. There is no reason not to open one and service it — that is ordinary repair work — but the primary side is at mains potential and the reservoir capacitor holds charge after unplugging. Unplug it, wait, and verify the reservoir is discharged before putting a hand or a probe inside. On the closely related Spectrum supplies, shorted leads have been known to set the rectifier diodes on fire, so a lead in poor condition is worth replacing on sight.[7]
Supply and clock checkpoints
edit| Point | Expect | Source |
| Positive end of C8 | The incoming unregulated supply, nominally 9 V DC | [2] |
| IC22 (7805) output | +5 V | [2] |
| IC1 (Z80) pin 11 Vcc / pin 29 ground | +5 V | [2] |
| IC2 (8332 ROM) pin 24 Vcc / pin 12 ground | +5 V | [2] |
| IC3, IC4 (2114 RAM) pin 18 Vcc / pin 9 ground | +5 V | [2] |
| IC1 (Z80) pin 6 | 3·2 MHz, as Sinclair's diagram labels it — the 6.5 MHz oscillator X1 divided by two, i.e. 3.25 MHz | [2] |
| IC1 (Z80) pin 26 | /RESET — held low briefly at switch-on by R21 (220 k) and C10 (1 µF), then high | [2] |
The edge connector carries +5 V, +9 V and 0 V alongside the Z80 bus; the full pinout is printed on Sinclair's circuit diagram.[2] Note that /ROMCS does not exist on the ZX80 bus — that input was added for the ZX81, so ZX81-era expansion hardware that relies on it will not behave the same way.[4]
Capacitors
editThere are exactly two electrolytics: C8 (22 µF, 16 V) across the unregulated input, and C10 (1 µF) in the power-on reset network. Everything else is ceramic and is not a service item.[2]
Full detail, including replacement guidance, is in the Sinclair ZX80 Capacitor Replacement Guide. See also Capacitor Failure Symptoms.
Preventive maintenance
edit- Unplug the supply. Measure its output and check its polarity before plugging it into the machine.
- Open the case and inspect the board for corrosion, cracked tracks and burnt components.
- Inspect C8 and C10 for leakage or bulging.
- Inspect the keyboard tails at the connectors. They fail by cracking where they bend. Remove them straight, never at an angle, and never fold them double — a trapped, folded tail will go open circuit sooner or later.[6][8]
- Clean dust with a soft brush. Clean the edge connector fingers.
- Reseat any socketed ICs.
- Inspect solder joints under magnification, particularly around the power jack, the regulator fixings and the edge connector. Look for splashes as well as dry joints: a hairline solder splash measures a few ohms and produces very misleading symptoms.[6]
- Check the regulator is still firmly bolted to its heatsink before reassembly.
Things that are not faults
edit- The picture disappears while a program runs. The ZX80 cannot generate a TV signal and execute a program at the same time. The screen blanks while the program works and flickers when a key is pressed. This is how the machine was designed; the ZX81's SLOW mode is what fixed it.[1]
- The regulator runs warm. It should. On the ZX81, Sinclair told kit builders that a regulator which never warms up means the supply is not reaching it; a regulator so hot you cannot bear to touch it means it is not properly bolted to its heatsink.[5]
Common faults and first checks
edit| Symptom | Where to look first |
| Completely dead, regulator cold | Supply output and polarity; the power jack solder joints; C8; IC22[5][2] |
| Works then cuts out, regulator very hot | Regulator not properly bolted to the heatsink[5] |
| No picture at all | Tuning first — sweep UHF around channel 36. Then the +5 V rail, then the UM1233 modulator and the R30–R33 network feeding it[5][4][2] |
| Cursor on screen, keyboard does nothing | Keyboard tails seated in their connectors and not twisted; the matrix diodes D3–D10; IC10 (74LS365)[5][2] |
| Screen clears but no cursor | Unplug the supply, wait a few seconds, try again — then suspect the R21/C10 reset network[5][2] |
| Horizontal black and white stripes through the picture | The external supply: insufficient smoothing, or output too low on load[5] |
| Random resets or lockups with a RAM pack fitted | Edge-connector contacts and mechanical movement of the pack, before anything on the board |
For a symptom-by-symptom walk-through, see the Sinclair ZX80 Troubleshooting Guide.
Tools
editSee Recommended Tools. The ZX80-specific additions are a multimeter (for the supply check that should precede every session) and, if you intend to chase clock or video faults, an oscilloscope.
editReferences
edit- ↑ 1.0 1.1 Differences between ZX80, ZX81 and Timex 1000, The Sinclair ZX Computers Archive, k1.spdns.de. Secondary source: the ZX80's standard TTL logic was combined into one ULA for the ZX81; the ZX80's display blanks while a program runs.
- ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 2.15 2.16 2.17 2.18 Sinclair Research Ltd, ZX80 Circuit Diagram. Hosted on this wiki as File:Sinclair ZX80 circuit diagram.png. Source for the IC type list, the capacitor designators and values, the supply rails and every pin number quoted on this page.
- ↑ Sinclair ZX80 — PCB, The Sinclair ZX Computers Archive, k1.spdns.de: photographs of ZX80 Issue 3 and Issue 3A boards. Secondary source; the only board-issue evidence located.
- ↑ 4.0 4.1 4.2 4.3 4.4 Sinclair ZX80 Connectors, The Sinclair ZX Computers Archive, k1.spdns.de. Secondary source: connector types, supply polarity and open-circuit voltage.
- ↑ 5.0 5.1 5.2 5.3 5.4 5.5 5.6 5.7 Sinclair Research Ltd, ZX81 Service and Assembly Manual, section 6 (fault finding) and section 9 (power supply specification). Hosted on this wiki as File:Sinclair ZX81 Service and Assembly Manual.pdf. Cited on this page because Sinclair published no equivalent service document for the ZX80 and the two machines share the same supply arrangement and regulator; each such use is identified as a ZX81 figure.
- ↑ 6.0 6.1 6.2 "Servicing Sinclair Computers, Part 2", Television magazine, 1986. Trade servicing article on the ZX80/ZX81 family, mirrored in the Sinclair ZX Computers Archive at k1.spdns.de. Secondary source: keyboard tail handling, solder-splash faults, reverse-polarity damage, piggy-backing technique.
- ↑ "Micro Clinic", Television magazine, 1986 — collected repair notes on Sinclair machines, mirrored in the Sinclair ZX Computers Archive at k1.spdns.de. Secondary source: Sinclair power-supply lead failures and their consequences.
- ↑ ZX Spectrum / ZX Spectrum+ Service Manual, Sinclair Research Ltd, section 2.2 (assembly). Hosted on this wiki as File:Sinclair ZX Spectrum Service Manual.pdf. Cited here for Sinclair's own warning that a trapped, folded keyboard ribbon will go open circuit — the same ribbons and the same failure occur across the ZX80, ZX81 and Spectrum.
